It is currently Sun Nov 29, 2026 11:09 am
Post new topic Reply to topic  [ 52 posts ]  Go to page 1, 2, 3  Next
 Post subject: GEGL Clay Bevel effect
PostPosted: Sat Jun 04, 2022 7:38 pm  (#1)
*download latest version (windows and linux binaries) here.
https://github.com/LinuxBeaver/GEGL-Clay-Bevel/releases
GEGL has another classic. A clay bevel filter!
 Post subject: Re: GEGL Clay Bevel effect
PostPosted: Sat Jun 04, 2022 8:12 pm  (#2)
Version for Gimp-2.10.30 Win 64 bit attached.
In menu: Tools➤GEGL Operation➤Clay Bevel
Place the file in gegl plugins in a directory: C:\Users\<your-user-name>\AppData\Local\gegl-0.4\plug-ins
claytext.zip [111.13 KiB]
Downloaded 257 times
PostPosted: Sat Jun 04, 2022 10:42 pm  (#3)
Just for clarification purposes:
The location given by Mahvin is global (other than local: ... \lib\gegl-0.4 \) - also works for portable versions of Gimp (eg Samj).
PostPosted: Sat Jun 04, 2022 11:03 pm  (#4)
PostPosted: Sun Jun 05, 2022 1:04 pm  (#5)
Totally having fun with this bevel effect.
PostPosted: Sun Jun 05, 2022 3:49 pm  (#6)
This also works in Linux: /home/yourname/.local/share/gegl-0.4/plug-ins/
It's a much better option than the root directory.
PostPosted: Sun Jun 05, 2022 5:33 pm  (#7)
C:\Users\<your-user-name>\AppData\Local\gegl-0.4\plug-ins --->This is local, not global.
PostPosted: Sun Jun 05, 2022 8:20 pm  (#8)
claytext.zip
How do you compile the file for .dll Windows 64bit? I will like to learn!
PostPosted: Sun Jun 05, 2022 8:25 pm  (#9)
For starters, you will need Msys2, but do not download the newest release. Nov 2021 release is the release I am using, currently.
PostPosted: Sun Jun 05, 2022 11:40 pm  (#10)
I got zzmediangraph.so and zzopacity.so that are cluttering the menu...
Is there a way to make them disappear from the menu?
Ubuntu-MATE 20.04 GIMP 2.10.30, I did not compile just put the 3 .so in gegl-0.4 system wide /usr/lib/x86_64-linux-gnu/gegl-0.4 my kids have their account as well and can use it.
Patrice
PostPosted: Sun Jun 05, 2022 11:52 pm  (#11)
They are a part of gegl effects, and any other paired dll's for other effects you download will show up at the bottom as well, which is why I think Contrast named them with z, to place them at the bottom. I would leave them there.
PostPosted: Mon Jun 06, 2022 12:45 am  (#12)
No dll here, I'm on Linux, I just did put the three ".so" files in the gegl directory.
There should be a way to group them all in just one entry in the menu, maybe with one file or a declaration to not go in the menu?
The OP has other gegl scripts, with multiple entries in the menu and/files as well, still just for 1 filter.... at this cadence it's gonna be a huge scrolling list if for 1 filter we got three entries in the menu, I can't imagine if others dev do that as well, that is NOT sustainable.
Patrice
PostPosted: Mon Jun 06, 2022 1:08 am  (#13)
We are in the early days of GEGL's take over. I am confident that in a few years new GEGL filter authors better then me will show up and they won't have to use the hacky zzmethod.
PostPosted: Mon Jun 06, 2022 1:19 am  (#14)
One of the GImp devs I am friends with might incorporate a built in blacklist and filters with the name 'internal" will be hidden by default. Then everything will have to update so zz is replaced with internal.
PostPosted: Mon Jun 06, 2022 2:00 am  (#15)
@Patrice.
That question (and answer) has already been asked here.
I still find it strange since all plugins (* .exe, * .py, * .scm) do not need to register in the menu - why does GEGL Operation have to?
I tried to change the C code:
this:
"categories", "generic",
on:
"categories", "hidden",
and that seems to have worked as well.
However, it needs more testing.
@Contrast_
You are trying? (or consult a developer friend).
PostPosted: Mon Jun 06, 2022 10:01 am  (#16)
Thank you for your discovery. He probably didn't know about that either.
Also, Congrats on editing GEGL's source code.
PostPosted: Mon Jun 06, 2022 6:30 pm  (#17)
cell noise set to grain merge and division makes glitter.
PostPosted: Sun Jun 12, 2022 9:49 am  (#18)
I'm going to give clay bevel the ability to use an image file overlay but the image file overlay will work best if the color is white.
PostPosted: Thu Jun 30, 2022 10:14 am  (#19)
Clay Bevel got an update that allows the radius to contract up to -10. Before it would lock at 0. This is useful for making the clay bevel effect work better on larger text.
PostPosted: Sat Jul 09, 2022 1:14 pm  (#20)
Clay Bevel can now change colors of grayscale bevels and do image file overlays of grayscale bevels. I even added a
desaturate slider to make this process easier.
