It is currently Thu Aug 13, 2026 2:24 pm
 Post subject: GEGL Bokeh
PostPosted: Thu Jun 30, 2022 7:29 pm  (#1)
https://github.com/LinuxBeaver/GEGL-Bokeh/
GEGL bokeh is here. Make sure you have an alpha channel or this will happen.
 Post subject: Re: GEGL Bokeh
PostPosted: Thu Jun 30, 2022 9:04 pm  (#2)
Nice! Thank you for creating the plugins and sharing them, contrast_! :tyspin Now, it would be neat if you add an option for colors and a line stroke, just like here:
PostPosted: Thu Jun 30, 2022 9:29 pm  (#3)
My reply to your comment.
PostPosted: Fri Jul 01, 2022 9:08 pm  (#4)
Version for Gimp-2.10.32 Win 64 Bit attached.
Place the file in Gegl plugins in a directory: C:\Users\YourName\AppData\Local\gegl-0.4\plug-ins
If you're missing the plugin-ins folder, create one.
In menu Tools➤GEGL Operation➤Bokeh Effect
bokeh.zip [39.17 KiB]
Downloaded 56 times
PostPosted: Thu Sep 08, 2022 8:39 pm  (#5)
UPDATE. GEGL BOKEH has two changes other then no hidden operations.
1. Bokeh got an update that allows the additional opacity meter to fix a glitch in which an alpha channel and transparent image render the master opacity meter useless.
2. Bokeh can now be recolored if you don't have mcol. (multiply of color overlay) which it does not include by default.
Other then that Bokeh now no longer uses any hidden operations.
PostPosted: Fri Sep 09, 2022 1:45 am  (#6)
Bokeh dll attached for Windows 64 bit.
Bokeh-Win64-dll_RD.7z [30.54 KiB]
Downloaded 71 times
PostPosted: Fri Sep 09, 2022 8:10 am  (#7)
Make sure they know to put the plugin in
C:\Users\YourName\AppData\Local\gegl-0.4\plug-ins NOT GIMP's regular plugin folder
