It is currently Wed Aug 12, 2026 11:31 pm
 Post subject: Pocholo's HULK Text Now Available at gimpscripts.net
PostPosted: Fri Jul 01, 2022 11:52 pm  (#1)
Like text style plugins? Yes? Check out Pocholo's new HULK plugin at gimpscripts.net.
 Post subject: Re: Pocholo's HULK Text Now Available at gimpscripts.net
PostPosted: Sat Jul 02, 2022 2:28 am  (#2)
No "Homelander" or "The Deep" or any of the Seven version?
Patrice
PostPosted: Tue Jul 05, 2022 4:18 am  (#3)
One issue though:
you can set another colour like blue or so, but it's not respected in the script. The output remains green.
Obviously not important. Only good for stupid jokes.
Regards
nelo
PostPosted: Tue Jul 05, 2022 4:27 am  (#4)
PostPosted: Tue Jul 05, 2022 4:34 am  (#5)
Yes... sure
but Pocholo made a field to select the colour ... what for? if it remains green...
The textcolor variable that he sets is not used, so to say
Regards
nelo
PostPosted: Tue Jul 05, 2022 7:46 am  (#6)
Guys you did not upgrade to version 2, in the menu >> Pyhton-Fu >> Thanos-Hulked (Thanosed is already taken :hehe )
Even Lou Ferrigno upgraded
:troll :teeth :rofl
Patrice
PostPosted: Tue Jul 05, 2022 8:44 am  (#7)
Downloaded from gimpscripts.net
Can't see any version 2 there.
Regards
nelo
PostPosted: Tue Jul 05, 2022 9:08 am  (#8)
I believe this was a joke.
PostPosted: Tue Jul 05, 2022 10:04 am  (#9)
ok
Regards
nelo
PostPosted: Tue Jul 05, 2022 10:40 am  (#10)
Indeed nelo, it was a joke (Lou Ferrigno upgraded, the 6 purple Hulk from Tas_mania), at the end I did put the troll (I did not find the "joke" smiley, though)
:puzzled
Patrice
PostPosted: Tue Jul 05, 2022 6:35 pm  (#11)
:rofl That was funny PixLab. I hope Pocholo is getting some ideas:
'The Incredible HULK Expansion Pack' - only 1.4Gb in size and comes with it's own operating system.
PostPosted: Wed Jul 06, 2022 10:35 am  (#12)
The new version 3 is up at gimpscripts.net.
PostPosted: Wed Jul 06, 2022 11:10 pm  (#13)
Thanks Tas_mania, but you should warn to not drink while reading your comment, my screen and keyboard are full of coffee now :rofl
Patrice
PostPosted: Fri Jul 08, 2022 9:28 am  (#14)
Anon user at gimpscripts.net reported this plugin doesn't work with non-english installations.
PostPosted: Fri Jul 08, 2022 9:56 am  (#15)
Old GIMP translation issue for gradients :mrgreen:
viewtopic.php?f=9&t=16818&hilit=layerfx.scm&start=10#p235529
PostPosted: Fri Jul 08, 2022 12:06 pm  (#16)
Script has been updated on gimpscripts.net to work with all languages.
PostPosted: Fri Jul 08, 2022 12:12 pm  (#17)
So Sorry Mahvin. Don't called victory yet, there one more thing to do add in the plugin in order to work in a non-English.
http://gimpchat.com/viewtopic.php?f=9&t=18697&hilit=Icon&start=20
I learned from MareroQ that for some non English translation you have to write: an underscore character _ and enclose the phrase with parenthesis like: _("FG to BG (RGB)"). So in line 176 pdb.python_layerfx_gradient_overlay, change the 3rd parameter to: _("FG to BG (RGB)"). I tested it with this and did not have any error.
PostPosted: Fri Jul 08, 2022 12:46 pm  (#18)
Done
PostPosted: Sat Jul 09, 2022 10:53 pm  (#19)
To get pm_hulk_v3.py to appear in my GImp menus I modified line 176.
"_("FG to BG (RGB)")", #gradient
to
"_(FG to BG (RGB))", #gradient
It still throws an error regarding line 186 but after the script has run so no worries.
Can you check it out Pocholo?
PostPosted: Sat Jul 09, 2022 11:18 pm  (#20)
My bad. I’ll take a look at it.
Weird, 186 is just merge gradient with layer set to FALSE.
