It is currently Tue Nov 24, 2026 7:21 am
 Post subject: Honeycomb text effect plugin
PostPosted: Wed Jul 20, 2022 4:19 pm  (#1)
This text will create a Room and a honeycomb text effect. This a nice text effect! Try it. :bigthup
pm_create_a_honey_comb_text.zip [279.97 KiB]
Downloaded 138 times
 Post subject: Re: Honeycomb text effect plugin
PostPosted: Thu Jul 21, 2022 2:43 am  (#2)
From Honeycomb to Snakify. :coolthup
PostPosted: Thu Jul 21, 2022 10:12 am  (#3)
If you're asking me is called Vagabond. If you're asking Rod, then i don't know :hehe
PostPosted: Thu Jul 21, 2022 10:14 am  (#4)
What do you mean? I don't have that in my script. :shock:
PostPosted: Thu Jul 21, 2022 10:21 am  (#5)
It looks like he's tweaking from the use of sinus (wrong plugin) mosaic?
PostPosted: Fri Jul 22, 2022 1:36 am  (#6)
I used "barbecue font", ran your script then ran redfield on it. :) Probably could have used rodilius too.
PostPosted: Fri Jul 22, 2022 1:38 am  (#7)
Redfields Fractalius plugin. :)
PostPosted: Fri Jul 22, 2022 2:15 am  (#8)
I tried and not sure what happened here?
I was using 2.10.21 portable.
:hehe
PostPosted: Fri Jul 22, 2022 2:51 am  (#9)
:hehe
Looks to me like you have a honey bee infestation Wallace :P
PostPosted: Fri Jul 22, 2022 2:55 am  (#10)
Is that so?
:hehe
PostPosted: Tue Dec 17, 2024 6:14 am  (#11)
Is there any additional work being done?
PostPosted: Tue Dec 17, 2024 2:54 pm  (#12)
:gaah
mosaic win 64bit.zip [28.85 KiB]
Downloaded 66 times
PostPosted: Tue Dec 17, 2024 3:24 pm  (#13)
Here the mosaic plugin from GIMP 2.8 for linux users:
(put it in plug-ins dir and make executable)
File comment: mosaic filter for linux
mosaic_from_2.8.zip [18.86 KiB]
Downloaded 67 times
PostPosted: Tue Dec 17, 2024 4:05 pm  (#14)
I have my own honey intruding, If i were to make this a plugin would anyone be interested?
PostPosted: Tue Dec 17, 2024 4:23 pm  (#15)
Without the goo
PostPosted: Wed Dec 18, 2024 1:36 am  (#16)
Yeah i'd be interested. Love me some gooey honey. :)
PostPosted: Wed Dec 18, 2024 3:32 am  (#17)
Thank you Pocholo :jumpclap
Thank you MareroQ :jumpclap
