It is currently Tue Nov 24, 2026 4:07 am
 Post subject: Pattern Editor
PostPosted: Tue Aug 02, 2022 6:36 am  (#1)
Probably most of our users have never tried it.
And nowVer.5 is available.
Cleaned up some code to prepare for implementing Tim's amazing pattern making capabilities (as I see the possibility) in Paper Weave using the definition layer.
File comment: GimpLearn not exist - add plugins here
GimpLearn Paper-weave 4 version.zip [12.17 KiB]
Downloaded 99 times
 Post subject: Re: Pattern Editor
PostPosted: Wed Aug 03, 2022 12:10 pm  (#2)
I've given it a try, and now need to play with the paper weave plugin.
PostPosted: Thu Oct 24, 2024 4:37 am  (#3)
The latest version available only here is MrQ Pattern Editor.py Ver.10.
In menu: Edit/Pattern Editor...
The most important changes in this version:
-bug fix for some layer order,
-delete option 'PREPARE SQUARE' - this automatic for Symmetry by Diagonal,
-reorganize tab order,
-add options: Recolor by Gradient, Recolor by Palette.
Hint: you can specify the initial size of the plugin window on lines 745 [dialog.la_previ.set_size_request(512,512)] and 750 [dialog.set_default_size(1100, 700)] of the code.
MrQ Pattern Editor Ver.10.zip [18.14 KiB]
Downloaded 134 times
PostPosted: Thu Oct 24, 2024 5:07 am  (#4)
Whoever has the paper weave plug-in code should post it here please.
PostPosted: Thu Oct 24, 2024 5:56 am  (#5)
I added the 4 versions I have in #1
PostPosted: Thu Oct 24, 2024 10:08 am  (#6)
Thanks MareroQ :D
PostPosted: Sun Jan 26, 2025 5:56 am  (#7)
Ver.11.
Changes:
- to tab "Symetrize" add: MIRROR BY CARTESIAN TRANSFORM, RADIAL SLICE
- to tab "Deform" add: "Cartesian", "Circular Ripple","Spiral Riple","Horizontal Sine Wave Ripple","Vertical Sine Wave Ripple", "Sinus Warp ","Concave Warp (-)","Convex Warp (+)","45° Internal Rotation (Left)" ,"45° Internal Rotation (Right)".
Example:
MrQ Pattern Editor Ver.11.zip [18.96 KiB]
Downloaded 74 times
