It is currently Sat Aug 15, 2026 5:25 pm
 Post subject: Candy Cane Text plugin (Mint?)
PostPosted: Mon Aug 15, 2022 3:28 pm  (#1)
OK, I seen the Sweet Candy script and I was not satisfied with the little flat look. So... I wrote this simple plugin by taking a little hint from that old tutorial
Create sweet candy text]Create sweet candy text. This plugin creates two different kind of patterns; The regular mint stripes and a Christmas mint.
I think on both scripts, SamJ and mine are better by using any medium rounded bold font. Anyway, can anyone download it and let me know how you like it? Cheers!
pm_candy_cane_text.zip [249.36 KiB]
Downloaded 78 times
 Post subject: Re: Candy Cane Text plugin (Mint?)
PostPosted: Mon Aug 15, 2022 3:58 pm  (#2)
I was going to ask if you could do a thin stripe with this effect, but saw the last example image , and can see that option is available. :tyspin
PostPosted: Mon Aug 15, 2022 9:46 pm  (#3)
You're welcome, AdmFubar! :bigthup
PostPosted: Tue Aug 16, 2022 12:40 am  (#4)
You really do need to use a nice round and bold font for this effect to look natural. But this isn't all that shabby Pocholo. ;)
PostPosted: Tue Aug 16, 2022 1:30 am  (#5)
Works well... can now use any font.
