It is currently Sun Nov 29, 2026 5:43 pm
 Post subject: GEGL Glowstick - Inspired by trandoductin's GlowStick
PostPosted: Tue Sep 13, 2022 8:38 pm  (#1)
GEGL is glowing in the dark and doing all sorts of cool neon effects with 9 BLEND MODES TO CHOOSE FROM! In this new filter I made inspired by trandoductin's Glowstick.
Inspiration here
viewtopic.php?f=9&t=17412&hilit=glowstick
Filter here
https://github.com/LinuxBeaver/GEGL-Glo ... ing-filter
With the help of Gimp dev BarefootLiam, I figured out how to use Gimp blend modes in GEGL. These are the same blend modes that are used in the final blend mode that each GEGL filter has. We have Soft light, HSL Color, Grain Merge, Overlay, Burn, LCh Color, Multiply, Linear Light, and Hard Light.
If you set the glowstick color to 0 you can add whatever blend mode or gradient overlay you want manually. This is best used for gradient overlays.
Enjoy!
 Post subject: Re: GEGL Glowstick - Inspired by trandoductin's GlowStick
PostPosted: Wed Sep 14, 2022 3:03 am  (#2)
Lava Girl. :)
PostPosted: Fri Sep 23, 2022 11:54 pm  (#3)
Custom Bevel, Color Lighting Fusion, Photo to Cartoon , Glow Stick and GEGL Effects have an emergency update.
If two filters have the same name of a blend mode enum list it will result in the blend mode switch option being hidden. Check these filters to make sure they have their blend mode switchers. Updating to the latest version solves the problem.
PostPosted: Sat Jun 03, 2023 11:10 am  (#4)
Glow stick just updated and now it applies to transparent images without giving them a color fill background.
Windows and Linux binaries here
https://github.com/LinuxBeaver/GEGL-Glo ... r/releases
Place to Put Binaries
Windows
Linux
