It is currently Sun Nov 29, 2026 2:53 am
 Post subject: GEGL Color Light Fusion (12 blend modes for color overlay)
PostPosted: Wed Sep 14, 2022 12:03 am  (#1)
(Recolor with 12 Gimp blend modes) Add or subtract saturation, light adjustment, sharpen and use Shadow highlight settings in this new GEGL filter that fuses together many existing GEGL and Gimp operations. Setting the opacity of color overlay below 100% can lead to all sorts of interesting scenarios.
https://github.com/LinuxBeaver/GEGL-Col ... ing-Fusion
Have fun.
 Post subject: Re: GEGL Color Light Fusion (12 blend modes for color overlay)
PostPosted: Wed Sep 14, 2022 12:11 am  (#2)
PostPosted: Wed Sep 14, 2022 1:14 am  (#3)
Nice. :bigthup Sort of a 300 overlay. :)
PostPosted: Fri Sep 23, 2022 11:54 pm  (#4)
Custom Bevel, Color Lighting Fusion, Photo to Cartoon , Glow Stick and GEGL Effects have an emergency update.
If two filters have the same name of a blend mode enum list it will result in the blend mode switch option being hidden. Check these filters to make sure they have their blend mode switchers. Updating to the latest version solves the problem.
PostPosted: Sat Sep 24, 2022 12:49 pm  (#5)
I have recompiled all of these for Windows 64 if anyone is interested.
PostPosted: Sat Sep 24, 2022 3:15 pm  (#6)
I am. :)
PostPosted: Tue Sep 27, 2022 8:08 pm  (#7)
Thank you, Rod. Very much appreciated!
PostPosted: Wed Mar 01, 2023 12:14 pm  (#8)
Color Light Fusion just got an update that gives it a brightness and contrast meter.
PostPosted: Fri Mar 17, 2023 3:35 pm  (#9)
Windows Binary here
https://github.com/LinuxBeaver/GEGL-Col ... tments.dll
Linux Binary here
https://github.com/LinuxBeaver/GEGL-Col ... stments.so
dll is for Windows and .so is for Linux
Location to put Binaries
Windows
C:\Users\AppData\Local\gegl-0.4\plug-ins
Linux
Linux (Flatpak)
I consider Color Light Fusion to be a major filter of mine as it is the "adjustment layer" filter.
PostPosted: Tue Sep 26, 2023 5:18 pm  (#10)
Color Lighting fusion got an update that makes Grain Merge and linear light color overlay look exactly like doing it in Gimp manually. Before it was using an oddball variation of the grain merge and linear light blend mode. Remember when using Color Lighting Fusion that left clicking the color box and sliding down the A slider can lower the color's opacity. That is the hidden "color opacity slider" that has been there since day one.
update here with binaries for Windows and Linux
https://github.com/LinuxBeaver/GEGL-Col ... ght_Fusion
I also limited the UI parameters on the lighting slider but it still can go up to values of 100.
