It is currently Wed Aug 12, 2026 4:07 pm
 Post subject: Echo Trail Text plugin (updated to V2)
PostPosted: Wed Sep 28, 2022 4:51 pm  (#1)
Me and my wife had been busy with the grandchildren lately and as a grandpa, :pipe I love it. But I caught a break, so I wrote :keybdtype another simple Text effect. This plugin will create a repeated text above an below the original text. I hope is useful for someone here!
*** Please make sure you have G'MIC install before running this script***
Version 2 change log:
Added a few options: Background color, Noise and round shape
pm_echo_trail_text_v2.zip [3.37 KiB]
Downloaded 118 times
pm_echo_trail_text.zip [2.94 KiB]
Downloaded 95 times
 Post subject: Re: Echo Trail Text plugin
PostPosted: Fri Sep 30, 2022 2:56 am  (#2)
Pocholo, Thanks for your new plug-in. :tyspin :hi5
PostPosted: Fri Sep 30, 2022 10:20 am  (#3)
Nice! ;)
PostPosted: Fri Sep 30, 2022 12:45 pm  (#4)
@ Issabella: Thank you for your comment and for testing the plugin. I love the cylinder shape concept. :clap If you don't mind, I will like to implement the plugin with your Idea.
@Rod: Thanks for the the, Nice! expression. :tyspin
PostPosted: Fri Sep 30, 2022 3:55 pm  (#5)
Yes, of course. It's a nice effect. I used Rectangle to Circle by Tin.
:coolthup
PostPosted: Fri Sep 30, 2022 8:59 pm  (#6)
Theilr- Pan to Rainbow shape. (will also do 360)
script-fu-pan-to-bow.scm [5.01 KiB]
Downloaded 65 times
PostPosted: Fri Sep 30, 2022 10:48 pm  (#7)
Thank you for the script info, Issabella. You can do the same with the G'MIC filter found in, Kaleidoscope [Reptorian-Polar]
That is what I'm going to use since most users have G'MIC, it will save me time by not including a third party script.
This is the result with G'MIC
 Post subject: Re: Echo Trail Text plugin (updated to V2)
PostPosted: Sat Oct 01, 2022 3:14 am  (#8)
Great! Good idea and thanks for your plug-ins. :coolthup
PostPosted: Sat Oct 01, 2022 8:16 am  (#9)
You're re-inventing the wheel ;)
Filters > Map > Recursive transform not only does exactly what your script do but does have more options...
Patrice
PostPosted: Sat Oct 01, 2022 9:41 am  (#10)
You are right, Patrice ahh... but my script have a name. My script have Colors, Noise, and a Round shape :hehe.
Coders create codes to automate what other users can do manually using GIMP resources, like the same "Gegl Recursive Transform plugin" you used. For example; there is a few bevel scripts around, maybe you have one like "Select Bevel, GT Bevel, Add bevel. "But I can do what those script can do manually". Then again, whoever wrote the scripts try to make it easier (for other users like you and me), so we don't have to make our effects manually using that many plugins or steps,. Now we have it at a touch of one button.
Anyway, thank you for your information.
PostPosted: Sat Oct 01, 2022 12:15 pm  (#11)
Pocholo, BTW, thanks a lot for mentioning the G'MIC filter, I always over looked at this Reptorian's filter, and today trying it, that's a cool one :coolthup
Patrice
