It is currently Wed Nov 18, 2026 6:56 pm
 Post subject: Custom Font Tools Release 15 for Gimp 2.10
PostPosted: Sun Nov 06, 2022 3:33 am  (#1)
Custom Font Tools R15 Plug-ins.zip [411.96 KiB]
Downloaded 193 times
This release of custom font tools contains the two tools added since Release 14 with a number of updated tools. All the tools now have a new menu location (to reduce the size of the menu) so I would consider deleting any existing plug-ins of the same name and replacing them with the new unless you want versions of the tools to live in different locations.
Download the zipped folder, extract what you want and add them to your user plug-ins folder.
Access the tools from:
Filters>>Custom Fonts
The pdf tool overview comes in two parts...
Tool Guide Part 1.pdf [2.93 MiB]
Downloaded 222 times
Tool Guide Part 2.pdf [4.77 MiB]
Downloaded 213 times
 Post subject: Re: Custom Font Tools Release 15 for Gimp 2.10
PostPosted: Mon Nov 07, 2022 3:27 pm  (#2)
Thank you again for all your knowledge and hard work. You are greatly appreciated.
PostPosted: Mon Feb 02, 2026 11:57 am  (#3)
does anyone know if this tool works with GIMP 3.0?
Thanks
PostPosted: Mon Feb 02, 2026 12:16 pm  (#4)
No - only 2.10...
