It is currently Sun Nov 29, 2026 10:52 am
 Post subject: GEGL Extrusion 2 (Fork of Long Shadow) USE BEHIND BLEND MODE!
PostPosted: Tue Nov 08, 2022 11:42 pm  (#1)
This filter was easy to make and it is so much easier to use then my original extrusion filter. It is better then the original in the sense that it is far more simple, has a fading mode, and a circular slider.
https://github.com/LinuxBeaver/GEGL-Ext ... ong-Shadow
Windows Binary
https://cdn.discordapp.com/attachments/ ... adowpd.dll
Where does it go?
Windows C:\Users<YOUR NAME>\AppData\Local\gegl-0.4\plug-ins
Linux /home/(USERNAME)/.local/share/gegl-0.4/plug-ins
Linux (Flatpak) /home/(USERNAME)/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
Remember this filter and the original extrusion work best with Gimp's 3d transform tool. Secondly, due to technical limitations I could not get the effect to go really long or do an infinite. When I do that it looks bad with a black color fill damaging the pixel data gradient. Lastly, it is odd I made a filter this late in time as I thought I was passed that stage. I hope this is my last filter as I have already done enough.
Enjoy.
 Post subject: Re: GEGL Extrusion 2 (Fork of Long Shadow) USE BEHIND BLEND MODE!
PostPosted: Wed Nov 09, 2022 4:41 am  (#2)
Tested on Windows 10 64 bit. :bigthup
PostPosted: Wed Nov 09, 2022 5:34 am  (#3)
Thanks for Testing my Filter, Rod.
I prefer a duplicate layer below but this works too. I put this here as I know many people will be wondering why this happens.
PostPosted: Wed Nov 09, 2022 1:17 pm  (#4)
Is there a version for windows users?
PostPosted: Wed Nov 09, 2022 8:11 pm  (#5)
Yes. I posted the dll in the Original post.
PostPosted: Thu Nov 10, 2022 1:20 pm  (#6)
Thank you.
PostPosted: Mon Mar 06, 2023 12:21 pm  (#7)
Windows Binaries here.
NOTE ALL WINDOWS BINARIES ARE ALSO FOUND ON THE GITHUB RELEASE SECTION.
https://github.com/LinuxBeaver/GEGL-Ext ... /releases/
Put the file in
C:\Users\AppData\Local\gegl-0.4\plug-ins
and create the `plug-ins` folder if it doesn't exist.
longshadowpd.zip [36.13 KiB]
Downloaded 105 times
PostPosted: Fri Aug 25, 2023 4:51 pm  (#8)
Extrusion 2 being used inside my layer effects engine.
Extrusion 2 and many other plugins of mine can now be used inside an experimental branch of GEGL Effects along with other major text styling plugins of mine. This version of GEGL Effects will replace default GEGL Effects if you already have it. OVERWRITE ALL BINARIES.
Read instructions to download it is not in the normal release section.
Source Code
https://github.com/LinuxBeaver/GEGL-Eff ... tal-update
Windows Binaries
https://github.com/LinuxBeaver/GEGL-Eff ... naries.zip
Linux Binaries
LOCATION TO PUT BINARIES. THEY DO NOT GO IN THE DEFAULT PLUGINS DIRECTORY
Windows
Linux
