It is currently Sun Nov 29, 2026 12:57 am
 Post subject: Neon Sign on wall plugin with animation option update #1
PostPosted: Thu Dec 01, 2022 11:53 am  (#1)
The plugin creates a brick wall and neon sign with an option of 3 frames shapes: Rounded square, Square and Rounded.
It also have an option to create small blinking animation.
This is an English and Non-English version
Animation:
1. Place an option for a solid Backwall.
2. The default frame rate is 1000ms but you can change it to you prefered frame rate (between parenthesis) Higher number slower animation. Lower number faster animation.
pm_neon_sign_on_wall.zip [6.09 KiB]
Downloaded 223 times
 Post subject: Re: Neon Sign on wall plugin with animation option
PostPosted: Thu Dec 01, 2022 3:08 pm  (#2)
Thank you Pocholo. it is very nice and it works well.
PostPosted: Thu Dec 01, 2022 5:50 pm  (#3)
This makes the effect quick and easy.
PostPosted: Fri Dec 02, 2022 1:39 pm  (#4)
Nice one, thanks Pocholo.
PostPosted: Fri Dec 02, 2022 3:51 pm  (#5)
This one is great again Pocholo...
PostPosted: Sat Dec 03, 2022 12:24 pm  (#6)
Interesting. If i use black for both grout and wall it crashes. When i select white and white i get this.Which is more of a gray on black grout. But it does run the plugin through its entirety.
Here is the error traceback for black and black.
  File "C:\Program Files\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 743, in response
  File "C:\Program Files\GIMP 2\lib\gimp\2.0\python/gimpfu.py", line 361, in run_script
  File "C:\Users\Rod\AppData\Roaming\GIMP\2.10\plug-ins\pm_neon_sign_on_wall.py", line 149, in pm_neon_sign_on_wall
    pdb.gimp_image_select_item(img, 2, vectors)
RuntimeError: Procedure 'gimp-image-select-item' has been called with value '-1' for argument 'item' (#3, type GimpItemID). This value is out of range.
PostPosted: Sat Dec 03, 2022 12:33 pm  (#7)
Doesn't work with this color either.
Hoping to create a solid wall behind the neon effect. Doesn't seem to work with any color but white. And then that isn't really a solid color. More like a 3D grayish brick wall.
Hope that all helps for fixing the error. Great plugin though! :bigthup thx!
PostPosted: Sat Dec 03, 2022 1:16 pm  (#8)
That is because the Brick pattern that is created before for the wall have a transparency on the shape, and black at the edges of the shape.
P.s If you want a solid color then it will be a separate option in the script.
PostPosted: Sat Dec 03, 2022 1:25 pm  (#9)
Another problem is that the top left corner of round rectangle isn't correct, there is a slight angle:
A problem with sel2path but then such paths can be created directly.
PostPosted: Sat Dec 03, 2022 2:32 pm  (#10)
That is an issue that I have to bring up with the Neon Sign Welder. :hehe
I guess "Rounded Rectangle" or the "Rectangle select tool" doesn't respod smoothly on corners.
When you Select to Path the selection the Path is deformed as you see in the image.
PostPosted: Sat Dec 03, 2022 2:36 pm  (#11)
Thank you for your input, Rod. :tyspin I edited the plugin and inserted an option for a solid wall color. I will posted in a few.
PostPosted: Sat Dec 03, 2022 3:06 pm  (#12)
On a text layer you should get the path using pdb.gimp_vectors_new_from_text_layer(image, layer).
PostPosted: Sat Dec 03, 2022 4:13 pm  (#13)
Yes, you're right. Thank you for pointing that out. When I zoomed it, I notice the jaggety edges and distortion. :bigthup
 Post subject: Re: Neon Sign on wall plugin with animation option update #1
PostPosted: Sun Dec 04, 2022 4:19 am  (#14)
Thank you Pocholo, it is a nice effect. I like it a lot. :coolthup
PostPosted: Sun Dec 04, 2022 7:37 am  (#15)
Probably better to use the plugin to create one image, then use the parts to create an animation. Then you can use whatever background you'd like.
PostPosted: Sun Dec 04, 2022 9:08 am  (#16)
Thank you Pocholo! Works excellent. :bigthup
PostPosted: Sun Dec 04, 2022 12:07 pm  (#17)
I suppose a better example would be.......
PostPosted: Mon Dec 05, 2022 3:09 am  (#18)
I like it, racer. :coolthup
PostPosted: Sun Oct 08, 2023 9:04 pm  (#19)
Rich Feldman wrote:
Thank you for sharing this exciting plugin update! The addition of a brick wall and neon sign with three frame shape options is fantastic. The versatility offered by rounded square, square, and rounded frames allows for creative customization. Moreover, the small blinking animation feature is a game-changer, adding dynamic charm to designs. Kudos to the developers for continually enhancing functionality. Can't wait to explore the possibilities this plugin brings to our projects!
Um... Are you human?
I start to see way too much AI texts everywhere, like on Youtube (for example)...
AI(s) have a very specific way of writing, and now I could say that I can smell those from 3 km away (even when re-written), but... I can be wrong! -> thus I wanted to check...
Patrice
PostPosted: Mon Oct 09, 2023 11:03 am  (#20)
Nice one Patrice. AI is used to write books and articles now-a-days.
Charles
