I modified my Jelly plugin with my "Glass Over Text" plugin using GEGL syntax and got this.
I could turn this into a filter but it would be
insanely slow. I'm trying to see if I can get it to look less like slime and more like rain drops.
Glass Over Text has its own thread here. You can try to create this effect manually by running Jelly then Glass Over Text on top of it. Here is Glass Over Text's thread which should not be confused with my other new plugin "Glass Text"
viewtopic.php?f=9&t=20386&p=279694#p279694
