It is currently Mon Nov 23, 2026 3:07 am
 Post subject: Colorful Pattern from Text (Text Pattern) Plug-in
PostPosted: Wed Mar 08, 2023 1:38 pm  (#1)
After doing Easter Egg Design from Text/Font Tutorial I thought it would help to create a plug-in
that generates a colorful pattern from text. Then all the user has to do is use Sphere Map Object to get a beautiful egg.
Okay so here it is (just put this code in a .py file)
#!/usr/bin/env python
# text-pattern.py
# Created by TT
# License: GPLv3
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY# without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# To view a copy of the GNU General Public License
# visit: http://www.gnu.org/licenses/gpl.html
#| Change Log |
# Rel 1: Initial release
from gimpfu import *
import random
colors = [["1","Blue Green","#199ebd"],
["2","Black","#232323"],
["3","Blue Violet","#7366bd"],
["4","Violet(Purple)","#926eae"],
["5","Green","#1cac78"],
["6","Blue","#1f75fe"],
["7","Yellow Green","#c5e384"],
["8","White","#ededed"],
["9","Yellow","#fce883"],
["10","Carnation Pink","#ffaacc"],
["11","Yellow Orange","#ffb653"],
["12","Red","#ee204d"],
["13","Brown","#b5674d"],
["14","Orange","#ff7538"],
["15","Red Orange","#ff5349"],
["16","Red Violet","#c0448f"],
["17","Gray","#95918c"],
["18","Cerulean","#1dacd6"],
["19","Indigo","#5d76cb"],
["20","Green Yellow","#f0e891"],
["21","Dandelion","#fddb6d"],
["22","Apricot","#fdd9b5"],
["23","Violet Red","#f75394"],
["24","Scarlet","#fc2847"],
["25","Wisteria","#cda4de"],
["26","Sky Blue","#80daeb"],
["27","Cadet Blue","#b0b7c6"],
["28","Timberwolf","#dbd7d2"],
["29","Melon","#fdbcb4"],
["30","Peach","#ffcfab"],
["31","Tan","#faa76c"],
["32","Chestnut","#bc5d58"],
def hexToRGB(h):
   h = h.lstrip('#')
   return tuple(int(h[i:i+2], 16) for i in (0, 2, 4))
def python_text_pattern(image, layer,string):
   pdb.gimp_image_undo_group_start(image)
   pdb.gimp_context_push()
   #YOUR CODE BEGINS=======================
   words = string
   starty = 0
   count = 0;
   while starty < image.height:
      #main work of each letter goes here ==========
      #get random color
      c = random.randrange(0,len(colors))
      pdb.gimp_context_set_foreground(hexToRGB(colors[c][2]))
      text = words[random.randrange(len(words))]
      text_layer = pdb.gimp_text_fontname(image,layer,0,0,text,0,TRUE,80,0,"Sans-serif")
      pdb.gimp_floating_sel_to_layer(text_layer)
      pdb.gimp_image_raise_item_to_top(image,text_layer)
      pdb.plug_in_autocrop_layer(image,text_layer)
      layer_copy = pdb.gimp_layer_new_from_drawable(text_layer,image)
      pdb.gimp_image_insert_layer(image,layer_copy,None,0)
      layer_copy = pdb.gimp_item_transform_flip_simple(layer_copy,ORIENTATION_VERTICAL,TRUE,0)
      layer_copy = pdb.gimp_item_transform_translate(layer_copy,0,layer_copy.height*2/3)
      layer_copy = pdb.gimp_image_merge_down(image,layer_copy,EXPAND_AS_NECESSARY)
      pdb.gimp_layer_set_offsets(layer_copy,0,0)
      height = layer_copy.height
      pdb.gimp_image_select_rectangle(image,CHANNEL_OP_REPLACE,0,height/5.0,layer_copy.width,height*3/5.0)
      pdb.gimp_selection_invert(image)
      pdb.gimp_edit_clear(layer_copy)
      pdb.gimp_selection_none(image)
      pdb.plug_in_autocrop_layer(image,layer_copy)
      pdb.gimp_item_transform_rotate_simple(layer_copy,ROTATE_90,TRUE,0,0)
      pdb.gimp_image_select_rectangle(image,CHANNEL_OP_REPLACE,0,0,layer_copy.width,layer_copy.height)
      pdb.gimp_edit_copy(layer_copy)
      new_layer = pdb.gimp_layer_new(image,image.width,layer_copy.height,RGBA_IMAGE,"text pattern",100,LAYER_MODE_NORMAL)
      pdb.gimp_image_insert_layer(image,new_layer,None,0)
      pdb.gimp_edit_fill(new_layer,FILL_PATTERN)
      pdb.gimp_layer_set_offsets(new_layer,0,starty)
      starty += new_layer.height
      pdb.gimp_image_remove_layer(image,layer_copy)
   #YOUR CODE ENDS ========================
   pdb.gimp_context_pop()
   pdb.gimp_image_undo_group_end(image)
   pdb.gimp_displays_flush()
    #return
register(
   "python_fu_text_pattern",
   "Create Text Pattern",
   "TT",
   "TT",
   "March 8, 2023",
   "<Image>/Python-Fu/Text Pattern...",
   "*",      # Create a new image, don't work on an existing one
   #INPUT BEGINS
   (PF_STRING, "string", "Characters to use (randomly):", "GimpChat*Rocks"),  # alias PF_VALUE
   #(PF_SPINNER, "inc", "Increments (pixels):", 15, (1, 1000, 1)),
   #(PF_SPINNER, "outof", "Best out of:", 100, (1, 1000, 1)),
   #(PF_OPTION, "arrow_side", "Arrows Ends:", SIDE_END, SIDE_NAMES),
   #(PF_TOGGLE, "arrow_close", "Arrows Close:", 0),
   #(PF_SPINNER, "ignorelayers", "Ignore first (no of layers):", 2, (0, 200, 1)),
   #(PF_SPINNER, "shadow_offset_x", "Shadow Offset X:", 6, (-4096,4096,1)),
   #(PF_SPINNER, "shadow_offset_y", "Shadow Offset Y:", 6, (-4096,4096,1)),
   #(PF_SPINNER, "shadow_blur_radius", "Shadow Blur Radius:", 15, (0,1024,1)),
   #(PF_SPINNER, "shadow_opacity", "Shadow Opacity:", 100, (0,100,1)),
   #INPUT ENDS
   python_text_pattern)
main()
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
Instructions:
1. Have an image opened (1200px by 1200px) with a white layer.
1B. Set fill pattern to Clipboard by Windows/Dockable Dialogs/Patterns and click on the very 1st one, top left pattern.
2. Run plug-in (Python-fu/Text Pattern...), Enter a text string with no spaces, plug-in will randomly choose characters from this string to create beautiful design. OK to run plug-in.
3. That's it, you'll many layers that will fill the whole 1200x1200 area. You'll just have to merge them all as one layer before using Object Map Sphere (or other uses of the pattern.
I hope you like it.
Oh yeah and if you use this to make money like selling, Please donate $1/sale to GIMP foundation Thanks (Must keep GIMP alive).
Here are some results I created by using/testing this plug-in.
 Post subject: Re: Colorful Pattern from Text Plug-in
PostPosted: Wed Mar 08, 2023 2:15 pm  (#2)
Okay after some more playing I thought I would improve the pattern
here's version 2.
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 2: Adjust pattern so that it's repeated more often to look nicer.
import random
def hexToRGB(h):
   h = h.lstrip('#')
   words = string
   starty = 0
   count = 0;
      #get random color
      pdb.gimp_image_select_rectangle(image,CHANNEL_OP_REPLACE,0,height*3/10.0,layer_copy.width,height*2/5.0)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
Here's what a sample of version 2 looks like (much more repetition so nicer looking I think):
PostPosted: Wed Mar 08, 2023 2:23 pm  (#3)
version 3 allows ability to choose number of maximum colors to randomly choose from.
Here's a sample with using 3 as maximum colors to choose from.
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 3: Added ability to choose number of random colors
import random
def hexToRGB(h):
   h = h.lstrip('#')
def python_text_pattern(image, layer,string,cols):
   words = string
   starty = 0
   count = 0;
   random.shuffle(colors)
      #get random color
      c = random.randrange(0,int(cols))
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   (PF_SPINNER, "colors", "Number of Maximum Colors (randomly):", 16, (1, 32, 1)),
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Wed Mar 08, 2023 6:00 pm  (#4)
Version 4 allows option to turn on to get various sizes (from 80% to 180%).
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 4: Added various random sizes for kicks
import random
def hexToRGB(h):
   h = h.lstrip('#')
def python_text_pattern(image, layer,string,cols,varysize):
   words = string
   starty = 0
   count = 0;
      #get random color
      #vary up the size for kicks
      if (int(varysize) == 1):
         size = random.randrange(80,180) / 100.0
         layer_copy = pdb.gimp_item_transform_scale(layer_copy,0,0,layer_copy.width*size,layer_copy.height*size)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   (PF_TOGGLE, "varysize",   "Vary up sizes:", 1), # initially True, checked.  Alias PF_BOOL
   #INPUT ENDS
main()
#           # PF_VALUE
Here's a sample result with it turned on:
 Post subject: Re: Colorful Pattern from Text (Text Pattern) Plug-in
PostPosted: Wed Mar 08, 2023 6:12 pm  (#5)
There's artifact line between pattern which bothers me.
So this version fixes that (v5)
Here's the code:
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 5: Bug fix so that there's no white line showing between copies of pattern.
import random
def hexToRGB(h):
   h = h.lstrip('#')
   words = string
   starty = 0
   count = 0;
      #get random color
         layer_copy = pdb.gimp_item_transform_scale(text_layer,0,0,text_layer.width*size,text_layer.height*size)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Wed Mar 08, 2023 8:12 pm  (#6)
Nice patterns :bigthup
You probably want the plug-in to set the active pattern to the Clipboard Image pattern or for the instructions to tell the user to do it.
PostPosted: Wed Mar 08, 2023 8:58 pm  (#7)
Thanks teapot, Oh yeah I always have it set as clipboard so I forgot about that I'll add that to instructions.
PostPosted: Wed Mar 08, 2023 10:50 pm  (#8)
This is what I got.... just default setting, default text
Tried on your number 5 script/latest :puzzled
I did more tries, and whatever options, number, text I change, input, the result will always be the same existing very-pattern from GIMP (that fake wood)
Patrice
PostPosted: Wed Mar 08, 2023 11:09 pm  (#9)
Click on the clipboard pattern in your patterns dockable window as it needs to use that. You probably have it set on fake wood pattern right now.
PostPosted: Wed Mar 08, 2023 11:33 pm  (#10)
Oh... OK, thank you. :bigthup
I did this to be sure to not forget ;)
register(
   "Create Text Pattern\n WARNING: \nSelect the CLIPBOARD Pattern before running me!",
Patrice
PostPosted: Wed Mar 08, 2023 11:35 pm  (#11)
register(
Here's version 6, which defaults to clip board automatically and allows you choose a font (type).
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 6: Default to "Clip board" pattern so user doesn't have to select it and allow user to choose the font
import random
["18","Cerulean","1dacd6"],
["19","Indigo","5d76cb"],
["20","Green Yellow","f0e891"],
["21","Dandelion","fddb6d"],
["22","Apricot","fdd9b5"],
["23","Violet Red","f75394"],
["24","Scarlet","fc2847"],
["33","Purple Mountains Majesty","#9d81ba"],
["34","Sea Green","#9fe2bf"],
["35","Cornflower","#9aceeb"],
["36","Granny Smith Apple","#a8e4a0"],
["37","Olive Green","#bab86c"],
["38","Spring Green","#eceabe"],
["39","Lavender","#fcb4d5"],
["40","Mauvelous","#ef98aa"],
["41","Goldenrod","#fcd975"],
["42","Salmon","#ff9baa"],
["43","Sepia","#a5694f"],
["44","Tumbleweed","#deaa88"],
["45","Macaroni and Cheese","#ffbd88"],
["46","Burnt Sienna","#ea7e5d"],
["47","Raw Sienna","#d68a59"],
["48","Mahogany","#cd4a4a"],
["49","Pacific Blue","#1ca9c9"],
["50","Robin Egg Blue","#1fcecb"],
["51","Turquoise","#77dde7"],
["52","Forest Green","#6dae81"],
["53","Silver","#cdc5c2"],
["54","Orchid","#c0448f"],
["55","Plum","#8e4584"],
["56","Periwinkle","#c5d0e6"],
["57","Asparagus","#87a96b"],
["58","Magenta","#f664af"],
["59","Tickle Me Pink","#fc89ac"],
["60","Wild Strawberry","#ff43a4"],
["61","Gold","#e7c697"],
["62","Bittersweet","#fd7c6e"],
["63","Burnt Orange","#ff7f49"],
["64","Brick Red","#cb4154"],
["65","Tropical Rain Forest","#17806d"],
["66","Pine Green","#158078"],
["67","Royal Purple","#7851a9"],
["68","Jungle Green","#3bb08f"],
["69","Denim","#2b6cc4"],
["70","Navy Blue","#1974d2"],
["71","Midnight Blue","#1a4876"],
["72","Shamrock","#45cea2"],
["73","Wild Blue Wonder","#a2add0"],
["74","Fuchsia","#c364c5"],
["75","Shocking Pink","#fb7efd"],
["76","Screamin Green","#76ff7a"],
["77","Inchworm","#b2ec5d"],
["78","Razzle Dazzle Rose","#ff48d0"],
["79","Hot Magenta","#ff1dce"],
["80","Purple Pizzazz","#ff1dce"],
["81","Electric Lime","#1df914"],
["82","Cerise","#ff43a4"],
["83","Laser Lemon","#fdfc74"],
["84","Unmellow Yellow","#fdfc74"],
["85","Razzmatazz","#e3256b"],
["86","Sunglow","#ffcf48"],
["87","Atomic Tangerine","#ffa474"],
["88","Vivid Tangerine","#ffa089"],
["89","Wild Watermelon","#fc6c85"],
["90","Jazzberry Jam","#ca3767"],
["91","Neon Carrot","#ffa343"],
["92","Mango Tango","#ff8243"],
["93","Radical Red","#ff496c"],
["94","Maroon","#c8385a"],
["95","Copper","#dd9475"],
["96","Outrageous Orange","#ff6e4a"],
["97","Outer Space","#414a4c"],
["98","Manatee","#979aaa"],
["99","Purple Heart","#7442c8"],
["100","Caribbean Green","#1cd3a2"],
["101","Eggplant","#6e5160"],
["102","Blue Bell","#adadd6"],
["103","Vivid Violet","#8f509d"],
["104","Mountain Meadow","#30ba8f"],
["105","Aquamarine","#78dbe2"],
["106","Pink Flamingo","#fc74fd"],
["107","Fern","#71bc78"],
["108","Canary","#ffff99"],
["109","Piggy Pink","#fdd7e4"],
["110","Shadow","#8a795d"],
["111","Banana Mania","#fae7b5"],
["112","Almond","#efdbc5"],
["113","Cotton Candy","#ffbcd9"],
["114","Blush","#de5d83"],
["115","Beaver","#9f8170"],
["116","Desert Sand","#efcdb8"],
["117","Pink Sherbet","#f780a1"],
["118","Antique Brass","#cd9575"],
["119","Sunset Orange","#fd5e53"],
["120","Fuzzy Wuzzy","#cc6666"],
def hexToRGB(h):
   h = h.lstrip('#')
def python_text_pattern(image, layer,fontname,string,cols,varysize):
   words = string
   starty = 0
   count = 0;
   #set pattern to clip board (1st item)
   num_patterns,pattern_list = pdb.gimp_patterns_get_list("")
   pdb.gimp_context_set_pattern(pattern_list[0])
      #get random color
      text_layer = pdb.gimp_text_fontname(image,layer,0,0,text,0,TRUE,80*image.width/1200,0,fontname)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   (PF_FONT, "fontname", "Font", 0),
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Wed Mar 08, 2023 11:50 pm  (#12)
version 7 (50% of the time move the copy down, 50% of the time move the original character down to get more variations).
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 7: 50% of the time move the copy down, 50% move the original down to get upside down variations.
import random
def hexToRGB(h):
   h = h.lstrip('#')
   words = string
   starty = 0
   count = 0;
      #get random color
      #50% of the time move the copy, the other 50% of the time move the original to get upside variations
      if (random.randrange(0,100)<50):
      else:
         text_layer = pdb.gimp_item_transform_translate(text_layer,0,text_layer.height*2/3)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Thu Mar 09, 2023 2:24 am  (#13)
Maybe as an option to tick? for people who want consistency or re-do the pattern for some reason like bigger or whatever and not getting a random luck :mrgreen:
Patrice
PostPosted: Thu Mar 09, 2023 6:21 am  (#14)
There's lots of randomness already, that redoing won't produce same pattern.
PostPosted: Thu Mar 09, 2023 6:46 am  (#15)
Oh... indeed, you're right :bigthup
I did change line 208 in your latest (203 in V6) just to have the html name and the hexa name as layer's name instead of the repetitive "text pattern #x" :mrgreen:
      new_layer = pdb.gimp_layer_new(image,image.width,layer_copy.height,RGBA_IMAGE,colors[c][1]+" / "+colors[c][2],100,LAYER_MODE_NORMAL)
When I saw that you have inputted all those html names > I was too sad to not use them :mrgreen:
EDIT: 120 was not enough :oops:
Yeah... OK, 650+ it's a bit over the top :hehe
colors = [
["1","Black (W3C)","#000000"],
["2","Night","#0C090A"],
["3","Charcoal","#34282C"],
["4","Oil","#3B3131"],
["5","Dark Gray","#3A3B3C"],
["6","Light Black","#454545"],
["7","Black Cat","#413839"],
["8","Iridium","#3D3C3A"],
["9","Black Eel","#463E3F"],
["10","Black Cow","#4C4646"],
["11","Gray Wolf","#504A4B"],
["12","Vampire Gray","#565051"],
["13","Iron Gray","#52595D"],
["14","Gray Dolphin","#5C5858"],
["15","Carbon Gray","#625D5D"],
["16","Ash Gray","#666362"],
["17","DimGray or DimGrey (W3C)","#696969"],
["18","Nardo Gray","#686A6C"],
["19","Cloudy Gray","#6D6968"],
["20","Smokey Gray","#726E6D"],
["21","Alien Gray","#736F6E"],
["22","Sonic Silver","#757575"],
["23","Platinum Gray","#797979"],
["24","Granite","#837E7C"],
["25","Gray or Grey (W3C)","#808080"],
["26","Battleship Gray","#848482"],
["27","Gunmetal Gray","#8D918D"],
["28","DarkGray or DarkGrey (W3C)","#A9A9A9"],
["29","Gray Cloud","#B6B6B4"],
["30","Silver (W3C)","#C0C0C0"],
["31","Pale Silver","#C9C0BB"],
["32","Gray Goose","#D1D0CE"],
["33","Platinum Silver","#CECECE"],
["34","LightGray or LightGrey (W3C)","#D3D3D3"],
["35","Silver White","#DADBDD"],
["36","Gainsboro (W3C)","#DCDCDC"],
["37","Platinum","#E5E4E2"],
["38","Metallic Silver","#BCC6CC"],
["39","Blue Gray","#98AFC7"],
["40","Roman Silver","#838996"],
["41","LightSlateGray or LightSlateGrey (W3C)","#778899"],
["42","SlateGray or SlateGrey (W3C)","#708090"],
["43","Rat Gray","#6D7B8D"],
["44","Slate Granite Gray","#657383"],
["45","Jet Gray","#616D7E"],
["46","Mist Blue","#646D7E"],
["47","Marble Blue","#566D7E"],
["48","Slate Blue Grey","#737CA1"],
["49","Light Purple Blue","#728FCE"],
["50","Azure Blue","#4863A0"],
["51","Blue Jay","#2B547E"],
["52","Charcoal Blue","#36454F"],
["53","Dark Blue Grey","#29465B"],
["54","Dark Slate","#2B3856"],
["55","Deep-Sea Blue","#123456"],
["56","Night Blue","#151B54"],
["57","MidnightBlue (W3C)","#191970"],
["58","Navy (W3C)","#000080"],
["59","Denim Dark Blue","#151B8D"],
["60","DarkBlue (W3C)","#00008B"],
["61","Lapis Blue","#15317E"],
["62","New Midnight Blue","#0000A0"],
["63","Earth Blue","#0000A5"],
["64","Cobalt Blue","#0020C2"],
["65","MediumBlue (W3C)","#0000CD"],
["66","Blueberry Blue","#0041C2"],
["67","Canary Blue","#2916F5"],
["68","Blue (W3C)","#0000FF"],
["69","Samco Blue","#0002FF"],
["70","Bright Blue","#0909FF"],
["71","Blue Orchid","#1F45FC"],
["72","Sapphire Blue","#2554C7"],
["73","Blue Eyes","#1569C7"],
["74","Bright Navy Blue","#1974D2"],
["75","Balloon Blue","#2B60DE"],
["76","RoyalBlue (W3C)","#4169E1"],
["77","Ocean Blue","#2B65EC"],
["78","Blue Ribbon","#306EFF"],
["79","Blue Dress","#157DEC"],
["80","Neon Blue","#1589FF"],
["81","DodgerBlue (W3C)","#1E90FF"],
["82","Glacial Blue Ice","#368BC1"],
["83","SteelBlue (W3C)","#4682B4"],
["84","Silk Blue","#488AC7"],
["85","Windows Blue","#357EC7"],
["86","Blue Ivy","#3090C7"],
["87","Blue Koi","#659EC7"],
["88","Columbia Blue","#87AFC7"],
["89","Baby Blue","#95B9C7"],
["90","CornflowerBlue (W3C)","#6495ED"],
["91","Sky Blue Dress","#6698FF"],
["92","Iceberg","#56A5EC"],
["93","Butterfly Blue","#38ACEC"],
["94","DeepSkyBlue (W3C)","#00BFFF"],
["95","Midday Blue","#3BB9FF"],
["96","Crystal Blue","#5CB3FF"],
["97","Denim Blue","#79BAEC"],
["98","Day Sky Blue","#82CAFF"],
["99","LightSkyBlue (W3C)","#87CEFA"],
["100","SkyBlue (W3C)","#87CEEB"],
["101","Jeans Blue","#A0CFEC"],
["102","Blue Angel","#B7CEEC"],
["103","Pastel Blue","#B4CFEC"],
["104","Light Day Blue","#ADDFFF"],
["105","Sea Blue","#C2DFFF"],
["106","Heavenly Blue","#C6DEFF"],
["107","Robin Egg Blue","#BDEDFF"],
["108","PowderBlue (W3C)","#B0E0E6"],
["109","Coral Blue","#AFDCEC"],
["110","LightBlue (W3C)","#ADD8E6"],
["111","LightSteelBlue (W3C)","#B0CFDE"],
["112","Gulf Blue","#C9DFEC"],
["113","Pastel Light Blue","#D5D6EA"],
["114","Lavender Blue","#E3E4FA"],
["115","White Blue","#DBE9FA"],
["116","Lavender (W3C)","#E6E6FA"],
["117","Water","#EBF4FA"],
["118","AliceBlue (W3C)","#F0F8FF"],
["119","GhostWhite (W3C)","#F8F8FF"],
["120","Azure (W3C)","#F0FFFF"],
["121","LightCyan (W3C)","#E0FFFF"],
["122","Light Slate","#CCFFFF"],
["123","Electric Blue","#9AFEFF"],
["124","Tron Blue","#7DFDFE"],
["125","Blue Zircon","#57FEFF"],
["126","Aqua or Cyan (W3C)","#00FFFF"],
["127","Bright Cyan","#0AFFFF"],
["128","Celeste","#50EBEC"],
["129","Blue Diamond","#4EE2EC"],
["130","Bright Turquoise","#16E2F5"],
["131","Blue Lagoon","#8EEBEC"],
["132","PaleTurquoise (W3C)","#AFEEEE"],
["133","Pale Blue Lily","#CFECEC"],
["134","Light Teal","#B3D9D9"],
["135","Tiffany Blue","#81D8D0"],
["136","Blue Hosta","#77BFC7"],
["137","Cyan Opaque","#92C7C7"],
["138","Northern Lights Blue","#78C7C7"],
["139","Blue Green","#7BCCB5"],
["140","MediumAquaMarine (W3C)","#66CDAA"],
["141","Magic Mint","#AAF0D1"],
["142","Light Aquamarine","#93FFE8"],
["143","Aquamarine (W3C)","#7FFFD4"],
["144","Bright Teal","#01F9C6"],
["145","Turquoise (W3C)","#40E0D0"],
["146","MediumTurquoise (W3C)","#48D1CC"],
["147","Deep Turquoise","#48CCCD"],
["148","Jellyfish","#46C7C7"],
["149","Blue Turquoise","#43C6DB"],
["150","DarkTurquoise (W3C)","#00CED1"],
["151","Macaw Blue Green","#43BFC7"],
["152","LightSeaGreen (W3C)","#20B2AA"],
["153","Seafoam Green","#3EA99F"],
["154","CadetBlue (W3C)","#5F9EA0"],
["155","Deep-Sea","#3B9C9C"],
["156","DarkCyan (W3C)","#008B8B"],
["157","Teal Green","#00827F"],
["158","Teal (W3C)","#008080"],
["159","Teal Blue","#007C80"],
["160","Medium Teal","#045F5F"],
["161","Dark Teal","#045D5D"],
["162","Deep Teal","#033E3E"],
["163","DarkSlateGray or DarkSlateGrey (W3C)","#25383C"],
["164","Gunmetal","#2C3539"],
["165","Blue Moss Green","#3C565B"],
["166","Beetle Green","#4C787E"],
["167","Grayish Turquoise","#5E7D7E"],
["168","Greenish Blue","#307D7E"],
["169","Aquamarine Stone","#348781"],
["170","Sea Turtle Green","#438D80"],
["171","Dull-Sea Green","#4E8975"],
["172","Dark Green Blue","#1F6357"],
["173","Deep-Sea Green","#306754"],
["174","Bottle Green","#006A4E"],
["175","SeaGreen (W3C)","#2E8B57"],
["176","Elf Green","#1B8A6B"],
["177","Dark Mint","#31906E"],
["178","Jade","#00A36C"],
["179","Earth Green","#34A56F"],
["180","Chrome Green","#1AA260"],
["181","Emerald","#50C878"],
["182","Mint","#3EB489"],
["183","MediumSeaGreen (W3C)","#3CB371"],
["184","Metallic Green","#7C9D8E"],
["185","Camouflage Green","#78866B"],
["186","Sage Green","#848B79"],
["187","Hazel Green","#617C58"],
["188","Venom Green","#728C00"],
["189","OliveDrab (W3C)","#6B8E23"],
["190","Olive (W3C)","#808000"],
["191","DarkOliveGreen (W3C)","#556B2F"],
["192","Military Green","#4E5B31"],
["193","Green Leaves","#3A5F0B"],
["194","Army Green","#4B5320"],
["195","Fern Green","#667C26"],
["196","Fall Forest Green","#4E9258"],
["197","Irish Green","#08A04B"],
["198","Pine Green","#387C44"],
["199","Medium Forest Green","#347235"],
["200","Jungle Green","#347C2C"],
["201","Cactus Green","#227442"],
["202","ForestGreen (W3C)","#228B22"],
["203","Green (W3C)","#008000"],
["204","DarkGreen (W3C)","#006400"],
["205","Deep Green","#056608"],
["206","Deep Emerald Green","#046307"],
["207","Hunter Green","#355E3B"],
["208","Dark Forest Green","#254117"],
["209","Lotus Green","#004225"],
["210","Seaweed Green","#437C17"],
["211","Shamrock Green","#347C17"],
["212","Green Onion","#6AA121"],
["213","Moss Green","#8A9A5B"],
["214","Grass Green","#3F9B0B"],
["215","Green Pepper","#4AA02C"],
["216","Dark Lime Green","#41A317"],
["217","Parrot Green","#12AD2B"],
["218","Clover Green","#3EA055"],
["219","Dinosaur Green","#73A16C"],
["220","Green Snake","#6CBB3C"],
["221","Alien Green","#6CC417"],
["222","Green Apple","#4CC417"],
["223","LimeGreen (W3C)","#32CD32"],
["224","Pea Green","#52D017"],
["225","Kelly Green","#4CC552"],
["226","Zombie Green","#54C571"],
["227","Green Peas","#89C35C"],
["228","Dollar Bill Green","#85BB65"],
["229","Frog Green","#99C68E"],
["230","Turquoise Green","#A0D6B4"],
["231","DarkSeaGreen (W3C)","#8FBC8F"],
["232","Basil Green","#829F82"],
["233","Gray Green","#A2AD9C"],
["234","Iguana Green","#9CB071"],
["235","Citron Green","#8FB31D"],
["236","Acid Green","#B0BF1A"],
["237","Avocado Green","#B2C248"],
["238","Pistachio Green","#9DC209"],
["239","Salad Green","#A1C935"],
["240","YellowGreen (W3C)","#9ACD32"],
["241","Pastel Green","#77DD77"],
["242","Hummingbird Green","#7FE817"],
["243","Nebula Green","#59E817"],
["244","Stoplight Go Green","#57E964"],
["245","Neon Green","#16F529"],
["246","Jade Green","#5EFB6E"],
["247","Lime Mint Green","#36F57F"],
["248","SpringGreen (W3C)","#00FF7F"],
["249","MediumSpringGreen (W3C)","#00FA9A"],
["250","Emerald Green","#5FFB17"],
["251","Lime (W3C)","#00FF00"],
["252","LawnGreen (W3C)","#7CFC00"],
["253","Bright Green","#66FF00"],
["254","Chartreuse (W3C)","#7FFF00"],
["255","Yellow Lawn Green","#87F717"],
["256","Aloe Vera Green","#98F516"],
["257","Dull Green Yellow","#B1FB17"],
["258","Lemon Green","#ADF802"],
["259","GreenYellow (W3C)","#ADFF2F"],
["260","Chameleon Green","#BDF516"],
["261","Neon Yellow Green","#DAEE01"],
["262","Yellow Green Grosbeak","#E2F516"],
["263","Tea Green","#CCFB5D"],
["264","Slime Green","#BCE954"],
["265","Algae Green","#64E986"],
["266","LightGreen (W3C)","#90EE90"],
["267","Dragon Green","#6AFB92"],
["268","PaleGreen (W3C)","#98FB98"],
["269","Mint Green","#98FF98"],
["270","Green Thumb","#B5EAAA"],
["271","Organic Brown","#E3F9A6"],
["272","Light Jade","#C3FDB8"],
["273","Light Mint Green","#C2E5D3"],
["274","Light Rose Green","#DBF9DB"],
["275","Chrome White","#E8F1D4"],
["276","HoneyDew (W3C)","#F0FFF0"],
["277","MintCream (W3C)","#F5FFFA"],
["278","LemonChiffon (W3C)","#FFFACD"],
["279","Parchment","#FFFFC2"],
["280","Cream","#FFFFCC"],
["281","Cream White","#FFFDD0"],
["282","LightGoldenRodYellow (W3C)","#FAFAD2"],
["283","LightYellow (W3C)","#FFFFE0"],
["284","Beige (W3C)","#F5F5DC"],
["285","Cornsilk (W3C)","#FFF8DC"],
["286","Blonde","#FBF6D9"],
["287","Champagne","#F7E7CE"],
["288","AntiqueWhite (W3C)","#FAEBD7"],
["289","PapayaWhip (W3C)","#FFEFD5"],
["290","BlanchedAlmond (W3C)","#FFEBCD"],
["291","Bisque (W3C)","#FFE4C4"],
["292","Wheat (W3C)","#F5DEB3"],
["293","Moccasin (W3C)","#FFE4B5"],
["294","Peach","#FFE5B4"],
["295","Light Orange","#FED8B1"],
["296","PeachPuff (W3C)","#FFDAB9"],
["297","Coral Peach","#FBD5AB"],
["298","NavajoWhite (W3C)","#FFDEAD"],
["299","Golden Blonde","#FBE7A1"],
["300","Golden Silk","#F3E3C3"],
["301","Dark Blonde","#F0E2B6"],
["302","Light Gold","#F1E5AC"],
["303","Vanilla","#F3E5AB"],
["304","Tan Brown","#ECE5B6"],
["305","Dirty White","#E8E4C9"],
["306","PaleGoldenRod (W3C)","#EEE8AA"],
["307","Khaki (W3C)","#F0E68C"],
["308","Cardboard Brown","#EDDA74"],
["309","Harvest Gold","#EDE275"],
["310","Sun Yellow","#FFE87C"],
["311","Corn Yellow","#FFF380"],
["312","Pastel Yellow","#FAF884"],
["313","Neon Yellow","#FFFF33"],
["314","Yellow (W3C)","#FFFF00"],
["315","Canary Yellow","#FFEF00"],
["316","Banana Yellow","#F5E216"],
["317","Mustard Yellow","#FFDB58"],
["318","Golden Yellow","#FFDF00"],
["319","Bold Yellow","#F9DB24"],
["320","Rubber Ducky Yellow","#FFD801"],
["321","Gold (W3C)","#FFD700"],
["322","Bright Gold","#FDD017"],
["323","Chrome Gold","#FFCE44"],
["324","Golden Brown","#EAC117"],
["325","Deep Yellow","#F6BE00"],
["326","Macaroni and Cheese","#F2BB66"],
["327","Saffron","#FBB917"],
["328","Neon Gold","#FDBD01"],
["329","Beer","#FBB117"],
["330","Yellow Orange or Orange Yellow","#FFAE42"],
["331","Cantaloupe","#FFA62F"],
["332","Cheese Orange","#FFA600"],
["333","Orange (W3C)","#FFA500"],
["334","Brown Sand","#EE9A4D"],
["335","SandyBrown (W3C)","#F4A460"],
["336","Brown Sugar","#E2A76F"],
["337","Camel Brown","#C19A6B"],
["338","Deer Brown","#E6BF83"],
["339","BurlyWood (W3C)","#DEB887"],
["340","Tan (W3C)","#D2B48C"],
["341","Light French Beige","#C8AD7F"],
["342","Sand","#C2B280"],
["343","Sage","#BCB88A"],
["344","Fall Leaf Brown","#C8B560"],
["345","Ginger Brown","#C9BE62"],
["346","Bronze Gold","#C9AE5D"],
["347","DarkKhaki (W3C)","#BDB76B"],
["348","Olive Green","#BAB86C"],
["349","Brass","#B5A642"],
["350","Cookie Brown","#C7A317"],
["351","Metallic Gold","#D4AF37"],
["352","Bee Yellow","#E9AB17"],
["353","School Bus Yellow","#E8A317"],
["354","GoldenRod (W3C)","#DAA520"],
["355","Orange Gold","#D4A017"],
["356","Caramel","#C68E17"],
["357","DarkGoldenRod (W3C)","#B8860B"],
["358","Cinnamon","#C58917"],
["359","Peru (W3C)","#CD853F"],
["360","Bronze","#CD7F32"],
["361","Tiger Orange","#C88141"],
["362","Copper","#B87333"],
["363","Dark Gold","#AA6C39"],
["364","Metallic Bronze","#A97142"],
["365","Dark Almond","#AB784E"],
["366","Wood","#966F33"],
["367","Oak Brown","#806517"],
["368","Antique Bronze","#665D1E"],
["369","Hazel","#8E7618"],
["370","Dark Yellow","#8B8000"],
["371","Dark Moccasin","#827839"],
["372","Khaki Green","#8A865D"],
["373","Millennium Jade","#93917C"],
["374","Dark Beige","#9F8C76"],
["375","Bullet Shell","#AF9B60"],
["376","Army Brown","#827B60"],
["377","Sandstone","#786D5F"],
["378","Taupe","#483C32"],
["379","Mocha","#493D26"],
["380","Milk Chocolate","#513B1C"],
["381","Gray Brown","#3D3635"],
["382","Dark Coffee","#3B2F2F"],
["383","Old Burgundy","#43302E"],
["384","Western Charcoal","#49413F"],
["385","Bakers Brown","#5C3317"],
["386","Dark Brown","#654321"],
["387","Sepia Brown","#704214"],
["388","Dark Bronze","#804A00"],
["389","Coffee","#6F4E37"],
["390","Brown Bear","#835C3B"],
["391","Red Dirt","#7F5217"],
["392","Sepia","#7F462C"],
["393","Sienna (W3C)","#A0522D"],
["394","SaddleBrown (W3C)","#8B4513"],
["395","Dark Sienna","#8A4117"],
["396","Sangria","#7E3817"],
["397","Blood Red","#7E3517"],
["398","Chestnut","#954535"],
["399","Coral Brown","#9E4638"],
["400","Chestnut Red","#C34A2C"],
["401","Mahogany","#C04000"],
["402","Red Gold","#EB5406"],
["403","Red Fox","#C35817"],
["404","Dark Bisque","#B86500"],
["405","Light Brown","#B5651D"],
["406","Petra Gold","#B76734"],
["407","Rust","#C36241"],
["408","Copper Red","#CB6D51"],
["409","Orange Salmon","#C47451"],
["410","Chocolate (W3C)","#D2691E"],
["411","Sedona","#CC6600"],
["412","Papaya Orange","#E56717"],
["413","Halloween Orange","#E66C2C"],
["414","Neon Orange","#FF6700"],
["415","Bright Orange","#FF5F1F"],
["416","Pumpkin Orange","#F87217"],
["417","Carrot Orange","#F88017"],
["418","DarkOrange (W3C)","#FF8C00"],
["419","Construction Cone Orange","#F87431"],
["420","Indian Saffron","#FF7722"],
["421","Sunrise Orange","#E67451"],
["422","Mango Orange","#FF8040"],
["423","Coral (W3C)","#FF7F50"],
["424","Basket Ball Orange","#F88158"],
["425","Light Salmon Rose","#F9966B"],
["426","LightSalmon (W3C)","#FFA07A"],
["427","DarkSalmon (W3C)","#E9967A"],
["428","Tangerine","#E78A61"],
["429","Light Copper","#DA8A67"],
["430","Salmon Pink","#FF8674"],
["431","Salmon (W3C)","#FA8072"],
["432","Peach Pink","#F98B88"],
["433","LightCoral (W3C)","#F08080"],
["434","Pastel Red","#F67280"],
["435","Pink Coral","#E77471"],
["436","Bean Red","#F75D59"],
["437","Valentine Red","#E55451"],
["438","IndianRed (W3C)","#CD5C5C"],
["439","Tomato (W3C)","#FF6347"],
["440","Shocking Orange","#E55B3C"],
["441","OrangeRed (W3C)","#FF4500"],
["442","Red (W3C)","#FF0000"],
["443","Neon Red","#FD1C03"],
["444","Scarlet Red","#FF2400"],
["445","Ruby Red","#F62217"],
["446","Ferrari Red","#F70D1A"],
["447","Fire Engine Red","#F62817"],
["448","Lava Red","#E42217"],
["449","Love Red","#E41B17"],
["450","Grapefruit","#DC381F"],
["451","Cherry Red","#C24641"],
["452","Chilli Pepper","#C11B17"],
["453","FireBrick (W3C)","#B22222"],
["454","Tomato Sauce Red","#B21807"],
["455","Brown (W3C)","#A52A2A"],
["456","Carbon Red","#A70D2A"],
["457","Cranberry","#9F000F"],
["458","Saffron Red","#931314"],
["459","Crimson Red","#990000"],
["460","Red Wine or Wine Red","#990012"],
["461","DarkRed (W3C)","#8B0000"],
["462","Maroon (W3C)","#800000"],
["463","Burgundy","#8C001A"],
["464","Vermilion","#7E191B"],
["465","Deep Red","#800517"],
["466","Red Blood","#660000"],
["467","Blood Night","#551606"],
["468","Dark Scarlet","#560319"],
["469","Black Bean","#3D0C02"],
["470","Chocolate Brown","#3F000F"],
["471","Midnight","#2B1B17"],
["472","Purple Lily","#550A35"],
["473","Purple Maroon","#810541"],
["474","Plum Pie","#7D0541"],
["475","Plum Velvet","#7D0552"],
["476","Dark Raspberry","#872657"],
["477","Velvet Maroon","#7E354D"],
["478","Rosy-Finch","#7F4E52"],
["479","Dull Purple","#7F525D"],
["480","Puce","#7F5A58"],
["481","Rose Dust","#997070"],
["482","Pastel Brown","#B1907F"],
["483","Rosy Pink","#B38481"],
["484","RosyBrown (W3C)","#BC8F8F"],
["485","Khaki Rose","#C5908E"],
["486","Lipstick Pink","#C48793"],
["487","Pink Brown","#C48189"],
["488","Old Rose","#C08081"],
["489","Dusty Pink","#D58A94"],
["490","Pink Daisy","#E799A3"],
["491","Rose","#E8ADAA"],
["492","Dusty Rose","#C9A9A6"],
["493","Silver Pink","#C4AEAD"],
["494","Gold Pink","#E6C7C2"],
["495","Rose Gold","#ECC5C0"],
["496","Deep Peach","#FFCBA4"],
["497","Pastel Orange","#F8B88B"],
["498","Desert Sand","#EDC9AF"],
["499","Unbleached Silk","#FFDDCA"],
["500","Pig Pink","#FDD7E4"],
["501","Pale Pink","#F2D4D7"],
["502","Blush","#FFE6E8"],
["503","MistyRose (W3C)","#FFE4E1"],
["504","Pink Bubble Gum","#FFDFDD"],
["505","Light Rose","#FBCFCD"],
["506","Light Red","#FFCCCB"],
["507","Warm Pink","#F6C6BD"],
["508","Deep Rose","#FBBBB9"],
["509","Pink (W3C)","#FFC0CB"],
["510","LightPink (W3C)","#FFB6C1"],
["511","Soft Pink","#FFB8BF"],
["512","Donut Pink","#FAAFBE"],
["513","Baby Pink","#FAAFBA"],
["514","Flamingo Pink","#F9A7B0"],
["515","Pastel Pink","#FEA3AA"],
["516","Rose Pink or Pink Rose","#E7A1B0"],
["517","Cadillac Pink","#E38AAE"],
["518","Carnation Pink","#F778A1"],
["519","Pastel Rose","#E5788F"],
["520","Blush Red","#E56E94"],
["521","PaleVioletRed (W3C)","#DB7093"],
["522","Purple Pink","#D16587"],
["523","Tulip Pink","#C25A7C"],
["524","Bashful Pink","#C25283"],
["525","Dark Pink","#E75480"],
["526","Dark Hot Pink","#F660AB"],
["527","HotPink (W3C)","#FF69B4"],
["528","Watermelon Pink","#FC6C85"],
["529","Violet Red","#F6358A"],
["530","Hot Deep Pink","#F52887"],
["531","Bright Pink","#FF007F"],
["532","DeepPink (W3C)","#FF1493"],
["533","Neon Pink","#F535AA"],
["534","Chrome Pink","#FF33AA"],
["535","Neon Hot Pink","#FD349C"],
["536","Pink Cupcake","#E45E9D"],
["537","Royal Pink","#E759AC"],
["538","Dimorphotheca Magenta","#E3319D"],
["539","Pink Lemonade","#E4287C"],
["540","Red Pink","#FA2A55"],
["541","Raspberry","#E30B5D"],
["542","Crimson (W3C)","#DC143C"],
["543","Bright Maroon","#C32148"],
["544","Rose Red","#C21E56"],
["545","Rogue Pink","#C12869"],
["546","Burnt Pink","#C12267"],
["547","Pink Violet","#CA226B"],
["548","Magenta Pink","#CC338B"],
["549","MediumVioletRed (W3C)","#C71585"],
["550","Dark Carnation Pink","#C12283"],
["551","Raspberry Purple","#B3446C"],
["552","Pink Plum","#B93B8F"],
["553","Orchid (W3C)","#DA70D6"],
["554","Deep Mauve","#DF73D4"],
["555","Violet (W3C)","#EE82EE"],
["556","Fuchsia Pink","#FF77FF"],
["557","Bright Neon Pink","#F433FF"],
["558","Fuchsia or Magenta (W3C)","#FF00FF"],
["559","Crimson Purple","#E238EC"],
["560","Heliotrope Purple","#D462FF"],
["561","Tyrian Purple","#C45AEC"],
["562","MediumOrchid (W3C)","#BA55D3"],
["563","Purple Flower","#A74AC7"],
["564","Orchid Purple","#B048B5"],
["565","Rich Lilac","#B666D2"],
["566","Pastel Violet","#D291BC"],
["567","Mauve Taupe","#915F6D"],
["568","Viola Purple","#7E587E"],
["569","Eggplant","#614051"],
["570","Plum Purple","#583759"],
["571","Grape","#5E5A80"],
["572","Purple Navy","#4E5180"],
["573","SlateBlue (W3C)","#6A5ACD"],
["574","Blue Lotus","#6960EC"],
["575","Blurple","#5865F2"],
["576","Light Slate Blue","#736AFF"],
["577","MediumSlateBlue (W3C)","#7B68EE"],
["578","Periwinkle Purple","#7575CF"],
["579","Very Peri","#6667AB"],
["580","Bright Grape","#6F2DA8"],
["581","Purple Amethyst","#6C2DC7"],
["582","Bright Purple","#6A0DAD"],
["583","Deep Periwinkle","#5453A6"],
["584","DarkSlateBlue (W3C)","#483D8B"],
["585","Purple Haze","#4E387E"],
["586","Purple Iris","#571B7E"],
["587","Dark Purple","#4B0150"],
["588","Deep Purple","#36013F"],
["589","Midnight Purple","#2E1A47"],
["590","Purple Monster","#461B7E"],
["591","Indigo (W3C)","#4B0082"],
["592","Blue Whale","#342D7E"],
["593","RebeccaPurple (W3C)","#663399"],
["594","Purple Jam","#6A287E"],
["595","DarkMagenta (W3C)","#8B008B"],
["596","Purple (W3C)","#800080"],
["597","French Lilac","#86608E"],
["598","DarkOrchid (W3C)","#9932CC"],
["599","DarkViolet (W3C)","#9400D3"],
["600","Purple Violet","#8D38C9"],
["601","Jasmine Purple","#A23BEC"],
["602","Purple Daffodil","#B041FF"],
["603","Clematis Violet","#842DCE"],
["604","BlueViolet (W3C)","#8A2BE2"],
["605","Purple Sage Bush","#7A5DC7"],
["606","Lovely Purple","#7F38EC"],
["607","Neon Purple","#9D00FF"],
["608","Purple Plum","#8E35EF"],
["609","Aztech Purple","#893BFF"],
["610","MediumPurple (W3C)","#9370DB"],
["611","Light Purple","#8467D7"],
["612","Crocus Purple","#9172EC"],
["613","Purple Mimosa","#9E7BFF"],
["614","Periwinkle","#CCCCFF"],
["615","Pale Lilac","#DCD0FF"],
["616","Lavender Purple","#967BB6"],
["617","Rose Purple","#B09FCA"],
["618","Lilac","#C8A2C8"],
["619","Mauve","#E0B0FF"],
["620","Bright Lilac","#D891EF"],
["621","Purple Dragon","#C38EC7"],
["622","Plum (W3C)","#DDA0DD"],
["623","Blush Pink","#E6A9EC"],
["624","Pastel Purple","#F2A2E8"],
["625","Blossom Pink","#F9B7FF"],
["626","Wisteria Purple","#C6AEC7"],
["627","Purple Thistle","#D2B9D3"],
["628","Thistle (W3C)","#D8BFD8"],
["629","Purple White","#DFD3E3"],
["630","Periwinkle Pink","#E9CFEC"],
["631","Cotton Candy","#FCDFFF"],
["632","Lavender Pinocchio","#EBDDE2"],
["633","Dark White","#E1D9D1"],
["634","Ash White","#E9E4D4"],
["635","White Chocolate","#EDE6D6"],
["636","Soft Ivory","#FAF0DD"],
["637","Off White","#F8F0E3"],
["638","Pearl White","#F8F6F0"],
["639","Red White","#F3E8EA"],
["640","LavenderBlush (W3C)","#FFF0F5"],
["641","Pearl","#FDEEF4"],
["642","Egg Shell","#FFF9E3"],
["643","OldLace (W3C)","#FEF0E3"],
["644","Linen (W3C)","#FAF0E6"],
["645","SeaShell (W3C)","#FFF5EE"],
["646","Bone White","#F9F6EE"],
["647","Rice","#FAF5EF"],
["648","FloralWhite (W3C)","#FFFAF0"],
["649","Ivory (W3C)","#FFFFF0"],
["650","White Gold","#FFFFF4"],
["651","Light White","#FFFFF7"],
["652","WhiteSmoke (W3C)","#F5F5F5"],
["653","Cotton","#FBFBF9"],
["654","Snow (W3C)","#FFFAFA"],
["655","Milk White","#FEFCFF"],
["656","Half White","#FFFEFA"],
["657","White (W3C)","#FFFFFF"],
Patrice
PostPosted: Thu Mar 09, 2023 7:43 am  (#16)
hehehe.
Just means it's virtually impossible to get same pattern as some other runs.
PostPosted: Thu Mar 09, 2023 8:05 am  (#17)
version 8 (allows user to say YES to coloring background layer - the initial white layer to random colors as well).
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 8: Toggle to color the white background layer randomly as well
import random
def hexToRGB(h):
   h = h.lstrip('#')
def python_text_pattern(image, layer,fontname,string,cols,varysize,colorbackground):
   words = string
   starty = 0
   count = 0;
      #get random color
      if (int(colorbackground)==1):
         b = c;
         while b==c:
            b = random.randrange(0,int(cols))
      else:
      #fill the layer with background color
         pdb.gimp_context_set_foreground(hexToRGB(colors[b][2]))
         pdb.gimp_image_select_rectangle(image,CHANNEL_OP_REPLACE,0,starty,image.width,new_layer.height)
         pdb.gimp_edit_fill(layer,FILL_FOREGROUND)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   (PF_TOGGLE, "colorbackground",   "Color background randomly:", 0), # initially True, checked.  Alias PF_BOOL
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Thu Mar 09, 2023 8:33 am  (#18)
Version 10 (includes v9 as I didn't share v9): (More variations through rotations 50/50 of the time and default to the whole alphabet lower and upper case instead of the string GimpChat Rocks)
# text-pattern.py
# Created by TT
# License: GPLv3
#| Change Log |
# Rel 9: Just default as the whole alphabet, and let user override with less letters
# Rel 10: Add variations with other side rotations
import random
def hexToRGB(h):
   h = h.lstrip('#')
   words = string
   starty = 0
   count = 0;
      #get random color
         b = c;
         while b==c:
      else:
      #add variation with sideway rotations
      else:
         pdb.gimp_item_transform_rotate_simple(layer_copy,ROTATE_270,TRUE,0,0)
    #return
register(
   "TT",
   "TT",
   "March 8, 2023",
   #INPUT BEGINS
   (PF_STRING, "string", "Characters to use (randomly):", "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz"),  # alias PF_VALUE
   #INPUT ENDS
main()
#           # PF_VALUE
Here a pattern is show with many variations with just one single capital B
PostPosted: Thu Mar 09, 2023 11:29 am  (#19)
Thank you Tin. Are you sure that it is your last version? :hehe
I've played it and all of the results are different and very nice. :coolthup
I did some ones without using your plug-in and it was fun, too.
PostPosted: Thu Mar 09, 2023 1:32 pm  (#20)
I don't guarantee anything about that being the last version :D
Nice bump map you got going.
