It is currently Sun Nov 29, 2026 7:48 pm
 Post subject: GEGL Sparkle effect plugin - download provided
PostPosted: Thu Mar 16, 2023 10:24 pm  (#1)
Fun new filter Enjoy!
https://github.com/LinuxBeaver/GEGL_Spa ... mp_Plugin/
Windows Binaries here.
sparkle.zip [36.95 KiB]
Downloaded 325 times
NOTE ALL WINDOWS BINARIES ARE ALSO FOUND ON THE GITHUB RELEASE SECTION.
https://github.com/LinuxBeaver/GEGL_Spa ... n/releases
Put the file in
C:\Users\AppData\Local\gegl-0.4\plug-ins
and create the `plug-ins` folder if it doesn't exist.
 Post subject: Re: GEGL Sparkle effect plugin - download provided
PostPosted: Fri Mar 17, 2023 1:50 am  (#2)
Thank you for all your GEGL filters!
PostPosted: Fri Mar 17, 2023 7:02 am  (#3)
You can test this filter without installing by putting this inside Gimp's GEGL Graph.
color value=#ff7aff
id=sparkle gimp:layer-mode layer-mode=divide opacity=0.02  aux=[  ref=sparkle cell-noise shape=1 scale=0.14 seed=343 iterations=1     ]
id=1 gimp:layer-mode layer-mode=color-erase  aux=[  ref=1 color value=#ff7aff  ]
color-overlay value=#ffffff
dropshadow color=#ffdf86  x=5 y=126 opacity=1
PostPosted: Fri Mar 17, 2023 10:30 am  (#4)
Thank you.
Might be handy some time.
Regards
nelo
PostPosted: Fri Mar 17, 2023 6:56 pm  (#5)
GEGL sparkle should be applied to a transparent layer. Alpha channel must be enabled. It works best with normal, grain merge and linear light blend modes. Light colors work best as well.
One can run it entirely in GEGL using GEGL's normal blend mode option.
PostPosted: Tue Apr 18, 2023 1:25 am  (#6)
The version in the Github release section got a trivial change update that solves a invisible node connection error.
No changes have been made.
cron
