It is currently Fri Aug 14, 2026 1:43 pm
 Post subject: One Side Fold - Paper Folding Simulation Plug-in
PostPosted: Sun Apr 23, 2023 9:20 pm  (#1)
I thought it would be fun to digitally simulate a pieces of paper being folded randomly by selecting a random rotation then apply a vertical fold.
And allow user to enter number of random folds they'd like to apply.
So here it is.
Plug-in is located in /Python-Fu/One Side Fold...
Just have an image with 2 layers, top layer respresenting one side of paper and bottom layer representing the other side of paper and run it.
Here's the code
#!/usr/bin/env python
# 1-side-fold.py
# Created by TT
# License: GPLv3
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY# without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# To view a copy of the GNU General Public License
# visit: http://www.gnu.org/licenses/gpl.html
#| Change Log |
# Rel 1: Initial release
from gimpfu import *
import random
import math
def python_1_side_fold(image, layer, howmany):
   # pdb.gimp_image_undo_group_start(image)
   # pdb.gimp_context_push()
   #YOUR CODE BEGINS=======================
   howmany = int(howmany)
   pdb.gimp_selection_none(image)
   for layer in image.layers:
      if (pdb.gimp_drawable_has_alpha(layer) == FALSE):
         pdb.gimp_layer_add_alpha(layer)
   for i in range(0,howmany):
      pdb.gimp_progress_update(float(i)/howmany)
      #first rotate it randomly
      radians = random.randrange(0,360)/360.0 * 2.0 * math.pi
         layer = pdb.gimp_item_transform_rotate(layer,radians,TRUE,0,0)
      pdb.gimp_image_resize_to_layers(image)
      #now do fold vertically randomly from min_crease to max_crease
      min_crease = 0.5; #at half point of width
      max_crease = 0.9; #at 90% of width
      crease_x = random.randrange(int(image.width*min_crease),int(image.width*max_crease))
         pdb.gimp_image_select_rectangle(image,CHANNEL_OP_REPLACE,crease_x,0,image.width-crease_x,image.height)
         pdb.gimp_edit_cut(layer)
         float_sel = pdb.gimp_edit_paste(layer,FALSE)
         pdb.gimp_floating_sel_to_layer(float_sel)
         pdb.gimp_item_transform_flip_simple(float_sel,ORIENTATION_HORIZONTAL,FALSE,crease_x)
         pdb.gimp_image_raise_layer_to_top(image,float_sel)
         #layer = pdb.gimp_image_merge_down(image,float_sel,EXPAND_AS_NECESSARY)
         #pdb.plug_in_autocrop_layer(image,float_sel)
      #autocrop to clean up.
      visible = pdb.gimp_layer_new_from_visible(image,image,"visible")
      pdb.gimp_image_insert_layer(image,visible,None,0)
      pdb.plug_in_autocrop(image,visible) #after we autocrop to visible
      pdb.gimp_image_remove_layer(image,visible);
      #do resize layers to image size so that layers can rotate together the same again next time
         pdb.gimp_layer_resize_to_image_size(layer)
   #YOUR CODE ENDS ========================
   # pdb.gimp_context_pop()
   # pdb.gimp_image_undo_group_end(image)
   pdb.gimp_displays_flush()
    #return
register(
   "python_fu_1_side_fold",
   "1 Side Folds a layer",
   "TT",
   "TT",
   "April 23, 2023",
   "<Image>/Python-Fu/One Side Fold...",
   "*",      # Create a new image, don't work on an existing one
   #INPUT BEGINS
   (PF_INT, "howmany", "Random Fold How many times?:", 1),
   # (PF_INT, "ytiles", "ytiles:", 8),
   # (PF_INT, "spacing", "spacing:", 70),
   # (PF_TOGGLE, "shuffle", "Shuffle order:", 1),
   # (PF_SPINNER, "colors", "Number of Maximum Colors (randomly):", 16, (1, 32, 1)),
   # (PF_TOGGLE, "varysize",   "Vary up sizes:", 1), # initially True, checked.  Alias PF_BOOL
   # (PF_TOGGLE, "colorbackground",   "Color background randomly:", 0), # initially True, checked.  Alias PF_BOOL
   #(PF_SPINNER, "inc", "Increments (pixels):", 15, (1, 1000, 1)),
   #(PF_SPINNER, "outof", "Best out of:", 100, (1, 1000, 1)),
   #(PF_OPTION, "arrow_side", "Arrows Ends:", SIDE_END, SIDE_NAMES),
   #(PF_TOGGLE, "arrow_close", "Arrows Close:", 0),
   #(PF_SPINNER, "ignorelayers", "Ignore first (no of layers):", 2, (0, 200, 1)),
   #(PF_SPINNER, "shadow_offset_x", "Shadow Offset X:", 6, (-4096,4096,1)),
   #(PF_SPINNER, "shadow_offset_y", "Shadow Offset Y:", 6, (-4096,4096,1)),
   #(PF_SPINNER, "shadow_blur_radius", "Shadow Blur Radius:", 15, (0,1024,1)),
   #(PF_SPINNER, "shadow_opacity", "Shadow Opacity:", 100, (0,100,1)),
   #INPUT ENDS
   python_1_side_fold)
main()
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
TinT
 Post subject: Re: One Side Fold - Paper Folding Simulation Plug-in
PostPosted: Thu Apr 27, 2023 8:01 am  (#2)
Here's the code to fold n times then unfold random(0-n) times.
# 1-side-fold2.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
def python_1_side_fold2(image, layer, howmany):
   rotatedradians = []
   creases = []
      rotatedradians.append(radians) #save the rotated radians for later use to unfold
      creases.append(crease_x) #save the crease for later use to unfold
         pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,layer)
         pdb.gimp_image_select_rectangle(image,CHANNEL_OP_INTERSECT,crease_x-1,0,1,image.height)
         not_empty,x1,y1,x2,y2 = pdb.gimp_selection_bounds(image)
         if not_empty == TRUE:
            pdb.gimp_context_set_foreground((0,0,0))
            pdb.gimp_edit_fill(layer,FILL_FOREGROUND)
   unfolds = random.randrange(0,howmany+1)
   for i in range(0,unfolds):
      layercount = len(image.layers)
      for l in range(0,layercount/2):
         layer = image.layers[0]
         #pdb.gimp_item_transform_flip_simple(layer,ORIENTATION_HORIZONTAL,FALSE,creases[howmany-1-i])
         pdb.gimp_item_transform_flip_simple(layer,ORIENTATION_HORIZONTAL,FALSE,image.width)
         pdb.gimp_image_lower_item_to_bottom(image,layer)
         for j in range(0,l+1): #raise to right layer
            pdb.gimp_image_raise_item(image,layer)
         pdb.gimp_image_merge_down(image,layer,EXPAND_AS_NECESSARY)
      #rotate in reverse
         layer = pdb.gimp_item_transform_rotate(layer,-rotatedradians[howmany-1-i],TRUE,0,0)
    #return
register(
   "python_fu_1_side_fold2",
   "TT",
   "TT",
   "April 23, 2023",
   "<Image>/Python-Fu/One Side Fold2...",
   #INPUT BEGINS
   #INPUT ENDS
   python_1_side_fold2)
main()
#           # PF_VALUE
Then here's the code that calls above code (n x m times) and make a n by m grid of it
# grid-of-folded.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
def python_grid_of_folded(image, layer, xtiles, ytiles):
   xtiles = int(xtiles)
   ytiles = int(ytiles)
   diameter = (image.width**2 + image.height**2)**0.5;
   workingimage = pdb.gimp_image_new(diameter*xtiles,diameter*ytiles,RGB)
   pdb.gimp_display_new(workingimage)
   for y in range(0,ytiles):
      for x in range(0,xtiles):
         new_image = pdb.gimp_image_duplicate(image)
         dp = pdb.gimp_display_new(new_image)
         pdb.python_fu_1_side_fold2(new_image,None,random.randrange(2,6))
         visible = pdb.gimp_layer_new_from_visible(new_image,workingimage,"r" + str(y) + " " + " c" + str(x))
         pdb.gimp_image_insert_layer(workingimage,visible,None,0)
         pdb.gimp_layer_set_offsets(visible,x*diameter+diameter/2-visible.width/2,y*diameter+diameter/2-visible.height/2)
         pdb.gimp_display_delete(dp)
    #return
register(
   "python_fu_grid_of_folded",
   "Grid of Folded",
   "Grid of Folded",
   "TT",
   "TT",
   "April 24, 2023",
   "<Image>/Python-Fu/One Side Folded Grid...",
   #INPUT BEGINS
   (PF_INT, "xtiles", "xtiles:", 3),
   (PF_INT, "ytiles", "ytiles:", 3),
   #INPUT ENDS
   python_grid_of_folded)
main()
#           # PF_VALUE
And here's an example output of using it (plus some manual drop shadow and setting background layer to nicely display result).
TinT
PostPosted: Sat Apr 29, 2023 11:33 am  (#3)
This is a really neat functionality. One could do a lot of fun things with this :)
PostPosted: Sat Apr 29, 2023 12:11 pm  (#4)
I don't what else it can be used for other than making some grid of random folds and sharing it on reddit.com/r/generative hehe.
Can you mention some ideas this can be used for?
TinT
PostPosted: Sun Apr 30, 2023 6:51 am  (#5)
I think its a brilliant plug-in, though I am not sure what I could use it for except as a prop. Have you considered adding a shadow to the fold to give the result an extra dimension?
Charles
PostPosted: Sun Apr 30, 2023 8:28 am  (#6)
Thank you for your suggestion. I think it's a great idea.
Here's the first plug-in (which folds only, no creases) with shadows (I'll work on the creased version now).
# 1-side-fold.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
      showlayers = [];
      shadowinsert = 0;
         layerName = pdb.gimp_item_get_name(layer)
         if layerName.startswith("Drop Shadow"):
            #if it's shadow layer simply cut it
         else:
            showlayers.append(float_sel)
            shadowinsert += 1;
      #hide all layers first
         pdb.gimp_item_set_visible(layer,FALSE)
      for layer in showlayers:
         pdb.gimp_item_set_visible(layer,TRUE)
      #new from visible to see shadow off
      pdb.gimp_image_insert_layer(image,visible,None,shadowinsert)
      #drop shawdow
      pdb.script_fu_drop_shadow(image,visible,0,0,15,(0,0,0),60,TRUE)
      pdb.gimp_edit_cut(image.layers[shadowinsert+1])
      #remove the visible as we don't need it anymore
    #return
register(
   "TT",
   "TT",
   "April 23, 2023",
   #INPUT BEGINS
   #INPUT ENDS
   python_1_side_fold)
main()
#           # PF_VALUE
example outputs
TinT
PostPosted: Sun Apr 30, 2023 9:08 am  (#7)
Well I tried but unsuccessfully to make the fold with creases look good with shadows because of so many operations it's all off by the time I am done unfolding so refolding with creases looked funky (not good).
I guess we'll just have to live with shadows for the folds only version.
TinT
PostPosted: Tue May 02, 2023 9:48 am  (#8)
Gave it a try, too. Here's my outcome.
Nice to play with. Thank you Tim.
Regards
nelo
