It is currently Sun Nov 29, 2026 6:37 pm
 Post subject: Long time GEGL Graph Glitch solved. Need Help testing bevel update
PostPosted: Sun Apr 30, 2023 9:56 pm  (#1)
A long time bug is solved and Custom Bevel and Glossy Balloon might be able to be called from my GEGL Effects plugin. But first I need others to test it.
Regarding these two filters
https://github.com/LinuxBeaver/GEGL-Custom-Bevel/
https://github.com/LinuxBeaver/GEGL-glo ... xt-styling
Being apart of a giga text styling filter
https://github.com/LinuxBeaver/GEGL-Eff ... alEdition/
because before this would happen but now it is solved.
I solved it by replacing gegl:opacity with
id=forceopacity dst-in  aux=[ ref=forceopacity ] id=makeopacity over  aux=[ ref=makeopacity ] id=forceopacity dst-in  aux=[ ref=forceopacity ] id=makeopacity over  aux=[ ref=makeopacity ] id=forceopacity dst-in  aux=[ ref=forceopacity ] id=makeopacity over  aux=[ ref=makeopacity ] id=forceopacity dst-in  aux=[ ref=forceopacity ] id=makeopacity over  aux=[ ref=makeopacity ]
In a nutshell it is just stacking layers on top of each other until the opacity is higher. It can't be adjusted.
In the mean time Glossy Balloon and Custom Bevel have a test update that I will finalize this week but first I need people to test it.
It should work the same as before and if it doesn't I won't update the Github.
You will see a binaries folder and source code. Here is the directory to put the binaries.
Directory to put binaries
Windows
C:\Users\USERNAME\AppData\Local\gegl-0.4\plug-ins
Linux
Linux (Flatpak)
Overwrite Glossy Balloon and Custom Bevel's binary if it exist. you can't have both versions.
Fun Fact I've been aware of this bug for over a year before I even started making plugins.
 Post subject: Re: Long time GEGL Graph Glitch solved. Need Help testing bevel update
PostPosted: Sun Apr 30, 2023 11:56 pm  (#2)
I just pushed the update on Github consider this thread closed.
PostPosted: Thu May 04, 2023 5:50 am  (#3)
The final update that happened may 2d is here.
This adds custombevel restorepuff=true/false checkboxes that revert back to legacy mode. In default custom bevel and glossy balloon are in legacy mode, the checkbox when enabled stacks a bunch of duplicate layers to kill transparency. I regret posting the April 30th update that has known problems. May 2'd update fixes everything. I urge everyone to update to the may second version that is here and on Github
https://github.com/LinuxBeaver/GEGL-glo ... g/releases
https://github.com/LinuxBeaver/GEGL-Cus ... l/releases
The drop shadow glitch is solved when the checkbox is enabled. This can be done in a GUI and the graph.
glossy-balloon removetransparency=true
dropshadow opacity=2
custom-bevel restorepuff=false
custom_bevel_glossy_balloon_update_windows.zip [75.85 KiB]
Downloaded 100 times
