It is currently Sun Nov 29, 2026 4:58 am
 Post subject: GEGL "Glass over Text' is STAND ALONE BUT NOW PART OF GEGL EFFECTS
PostPosted: Thu May 18, 2023 7:12 pm  (#1)
*June 10 2023 update. This plugin is now part of GEGL Effects and can be downloaded by downloading GEGL Effects here.
https://github.com/LinuxBeaver/GEGL-Eff ... L/releases
New plugin here. Inspired by Plastic and Glass. Goes on layer above or use the normal blend mode. Also feel free to experiment with other blend modes.
Preview
Video of the plugin here.
https://twitter.com/LinuxBeaver/status/ ... 4016882694
Code
https://github.com/LinuxBeaver/GEGL-Eff ... _text_here
Binaries for Windows and Linux (it is with GEGL Effects)
Directory to put binaries
Windows
C:\\Users\(USERNAME)\AppData\Local\gegl-0.4\plug-ins
Linux
 Post subject: Re: GEGL "Glass over Text'plugin
PostPosted: Thu May 18, 2023 11:21 pm  (#2)
PostPosted: Fri May 26, 2023 12:45 am  (#3)
Sometimes I follow a Photoshop tutorial... see how far I can get. Now I've given it a twist with GEGL glass over text.
PostPosted: Fri May 26, 2023 1:09 am  (#4)
What a cool outcome! :coolthup
Regards
nelo
 Post subject: Re: GEGL "Glass over Text' is STAND ALONE BUT NOW PART OF GEGL EFFECTS
PostPosted: Sat Jun 10, 2023 3:47 pm  (#5)
Glass on Text is now part of GEGL Effects but still has a stand alone plugin.
https://github.com/LinuxBeaver/GEGL-Eff ... ne10th2023
PostPosted: Sat Sep 02, 2023 5:25 pm  (#6)
I'm trying to promote my glass on text plugin as it is a counterpart to a old script fu named "shine". As I've said countless times this plugin ships with my layer effects engine - GEGL Effects, but below I have decided to provide stand alone binaries for this plugin. If you already have a modern version of my layer effects engine with glass on text tab, you can ignore this.
REMEMBER, this download is for people that do not have my layer effects engine and just want glass on text as a stand alone filter.
Windows download of glass on text as a stand alone.
glass_on_text_windows.zip [37.03 KiB]
Downloaded 212 times
Linux download of glass on text as stand alone.
glass_on_text_linux.zip [8.88 KiB]
Downloaded 216 times
Directory to put binary. They do not work in the normal plugins folder.
**Windows**
**Linux**
**Linux (Flatpak includes Chromebook)**
Enjoy, this filter does not shine people properly. Only text and shapes. Remember to use blending options/blend modes other then the default "replace".
