It is currently Sun Nov 29, 2026 5:02 pm
 Post subject: Gradient from image
PostPosted: Thu Jun 15, 2023 1:00 am  (#1)
I found this file and I'm happy with it. Can anyone still use it?
gradient-from-image.scm [2.7 KiB]
Downloaded 113 times
 Post subject: Re: Gradient from image
PostPosted: Thu Jun 15, 2023 5:44 am  (#2)
Manually it's also quite simple: scale the image to 1px × colors (or colors × 1px ), then "Palettes > Import palette" , and "Palettes > Palette to gradient".
PostPosted: Thu Jun 15, 2023 8:10 am  (#3)
Thanks for your explanation. Had never used it this way before. It was a bit of a puzzle, but it worked!
