It is currently Sun Nov 29, 2026 4:50 pm
 Post subject: Pack sprites G'mic
PostPosted: Thu Jun 22, 2023 2:12 pm  (#1)
I would love to use pack sprites in G'mic...but it keeps crashing.I followed the video tutorial on Youtube.Would anyone like to test it?
 Post subject: Re: Pack sprites G'mic
PostPosted: Thu Jun 22, 2023 9:58 pm  (#2)
Been a while; tried packed spites with base layer mask and it never finishes after a long time (use to be quite fast as I recall). Might be a bug. Will post at PixLS's site to see if it may have degraded. I'll post a link to that thread once I do. :)
PostPosted: Thu Jun 22, 2023 10:04 pm  (#3)
OK; posted a thread at PixLS's G'MIC forum. Below's that link. :)
https://discuss.pixls.us/t/has-packed-s ... aded/38156
PostPosted: Fri Jun 23, 2023 12:38 am  (#4)
Thank you for passing on the question... we're waiting!
PostPosted: Fri Jun 23, 2023 4:32 am  (#5)
David fixed the issue (see PixLS link per previous post for details; Gotta thank David); just refresh your presets, Jappaloe63. If that doesn't work, make sure you have the latest version of G'MIC. :)
PostPosted: Fri Jun 23, 2023 8:37 am  (#6)
Pack sprites with shells... and a little shimmer on top!
PostPosted: Fri Jun 23, 2023 11:58 pm  (#7)
Saw your shells result while at work, earlier. Looks great. :)
PostPosted: Sat Jun 24, 2023 3:52 am  (#8)
Lylejk ,vitforlinux thanks!
One more then... , no masking
PostPosted: Sat Jun 24, 2023 4:55 am  (#9)
Sorry, I don't get any result as I must have some concept wrong. Can someone help me?
Pack-Sprite-Issa.zip [27.65 KiB]
Downloaded 53 times
PostPosted: Sat Jun 24, 2023 6:24 am  (#10)
I pretty much stick to these settings
PostPosted: Sat Jun 24, 2023 6:34 am  (#11)
It is very picky for parameters, try
Increase Number of Scales to about 10 or 12
Reduce Minimal scale (%) to about 10
Spacing is important, reduce to (minus) -3 or -4
Masking use mask as bottom layer
Input all layers
Output New Image
example: https://i.imgur.com/CDNCmnd.mp4
PostPosted: Sat Jun 24, 2023 6:56 am  (#12)
Thanks a lot vitforlinux, rich2005 and Jappaloe63. :coolthup
Everything is great help and I will practice it today. :tyspin
PostPosted: Sat Jun 24, 2023 7:29 am  (#13)
I use a true b/w mask (no gray levels; black being what you want filled) Issabella. :)
PostPosted: Sat Jun 24, 2023 8:28 am  (#14)
Yes!!!!! I got it with your help!!!!! Thank you all of you. :jumpclap
