It is currently Wed Nov 25, 2026 9:19 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Rotate Hue Script
PostPosted: Tue Jun 20, 2023 2:21 pm  (#1)
Links to plugin versions, suggest using the last one:
Version 1.0.0 Menu: Python-Fu -> Rotate Hue
Version 2.0.0 Menu: Filters -> Animation -> Rotate Hue...
Version 3.0.0 Menu: Filters -> Animation -> Rotate Hue...
Example outcome from the plugin saved as a gif:
The conversation was originally here.
Original post:
:coolthup :clap teapot, you rocks!
I'd like to know how to do it. :hi5
Thanks Issabella.
I used Colours -> Hue Saturation and repeatedly changed the hue.
The hue goes from -180 to 180 so that's a total change of 360.
To wrap cleanly change the hue in steps that divide into 360.
For example I used a step of 20 which gave me 360 / 20 = 18 gif frames.
The process is:
Make some text filled with a colourful pattern, I used a pattern made with the Full saturation spectrum gradient.
Duplicate the text layer.
Set hue to -180
Duplicate the original text layer.
Set hue to -180 + 1 * step (in my case step was 20)
Set hue to -180 + 2 * step
Repeat duplicating the original text layer and setting the hue incrementing hue by step each time until it's 180 - step.
Delete the original text layer.
Add a background to all the layers.
Save as a gif.
 Post subject: Re: Different Effects Gimp Text (Show us yours using gimp)
PostPosted: Wed Jun 21, 2023 2:04 am  (#2)
Thanks, thanks a lot.
teapot, I'll try your process to get that nice effect. :coolthup :tyspin :hi5
PostPosted: Wed Jun 21, 2023 2:55 pm  (#3)
My humble first try. No so nice as yours. Your tut has been great help. Thanks teapot. :tyspin :coolthup
PostPosted: Thu Jun 22, 2023 5:05 am  (#4)
Experimented with teapot's method of making hue saturation gifs. There are a lot of possibilities and for me quite tricky to get right. :)
PostPosted: Thu Jun 22, 2023 5:52 am  (#5)
Result with color changes after adding rainbow color to monochrome rock painting and then processing negation without gmic dream smoothing
PostPosted: Thu Jun 22, 2023 7:40 pm  (#6)
Hue saturation gifs
You only need to divide 360 by how many frames you want (18 x 20 = 360).
Duplicate first layer 17 times and go thru the -180 to + 180 in increments of 20.
I also processed the frames with G'MIC smooth abstract and then did the hue saturation again. I probably should not have used drop shadow on the first try :)
BTW thanks teapot for doing this.
diagrajamal1 thats cool.
PostPosted: Fri Jun 23, 2023 1:35 pm  (#7)
Nice outcomes Issabella :jumpclap Tas_mania :jumpclap diagrajamal1 :jumpclap
Tas_mania, Your update is easier manually but given it's still tedious here's a plugin to do it, menu item is Python-Fu -> Rotate Hue:
rotatehue-1.0.0.zip [1.58 KiB]
Downloaded 632 times
Example input layer:
Output saved as a gif:
PostPosted: Fri Jun 23, 2023 8:32 pm  (#8)
Patrice
PostPosted: Fri Jun 23, 2023 10:21 pm  (#9)
Nice one Teapot!
:paint
PostPosted: Sat Jun 24, 2023 1:33 am  (#10)
Thanks teapot for making a cool filter and learning to code python :bigthup
Rotated hues on 2 canvases. On the first I selected by color on text with a clear background. On the 2nd applied a different gradient in the opposite direction. Used ofnut's 'interleave layers' to merge. Also used 'rename layers' with (20ms)(replace).
BTW. I open images like this one in a new tab and then bookmark it. Then I can post it without uploading again when a newbie arrives :)
PostPosted: Sat Jun 24, 2023 2:16 am  (#11)
teapot Thanks!!!!! I love it and it is very nice of you to give us even a filter to do it so quickly. :hi5 :coolthup
PostPosted: Sat Jun 24, 2023 8:14 am  (#12)
teapot, your script is addictive :hehe
Patrice
PostPosted: Sat Jun 24, 2023 9:44 am  (#13)
:wow PixLab, Wallace, Tas_mania, Issabella great outcomes :jumpclap
PostPosted: Sat Jun 24, 2023 2:52 pm  (#14)
PostPosted: Sat Jun 24, 2023 4:33 pm  (#15)
diagrajamal1 wrote:
Your image could make for a nice lens flare.
Nicely done!
:paint
PostPosted: Sat Jun 24, 2023 6:48 pm  (#16)
Very interesting plugin, thanks teapot!
PostPosted: Sat Jun 24, 2023 7:55 pm  (#17)
Yes it works well on any image. This was a HiRes 3D fractal image. No Gradient applied at all :)
PostPosted: Sat Jun 24, 2023 10:25 pm  (#18)
racer-x, That's an awesome frog :yes
PostPosted: Sun Jun 25, 2023 5:22 am  (#19)
Nicely done!
:paint
Thank You Purple Master
I did a little experiment. but I don't like it. You are an expert in these matters. I need to work harder.
PostPosted: Sun Jun 25, 2023 7:31 am  (#20)
You are too kind.
I wish to always remain humble; there are many here for whom I own gratitude.
For the knowledge they have passed on to us all. We are nothing without them.
It's always surprising to me when I see these wonderful creations.
After all, this is Gimp Chat, Where imagination Meets Innovation,
and we have GnuTux our founder, to thank for that.
:paint
