Hello, I have debuted a new GEGL Plugin that makes Glass, Metallic and Marble text all in one and it has built in presets if you follow the short instructions
https://github.com/LinuxBeaver/Glass_Me ... n/releasesAttachment:
*if you already have any of these binaries provided from this plugin, overwrite all of them.
*if you have a version of GEGL Effects before June 2023 this plugin will break GEGL Effects. To fix this update GEGL Effects here.
https://github.com/LinuxBeaver/GEGL-Eff ... L/releasesLocation to put **GimpGegl-lb-gmm-config.settings** The presets, (this works regardless of what OS you are on) overwrite with the latest version if you already have it.
*if you have Gimp 2.99 replace `2.10` with `2.99` or `3.0` when Gimp 3 is released.
Windows Normal (GimpGegl-lb-gmm-config.settings)C:\Users\USERNAME\AppData\Roaming\GIMP\2.10\filters
Linux Normal (GimpGegl-lb-gmm-config.settings) /home/USERNAME/.config/GIMP/2.10/filters
Linux Flatpak (GimpGegl-lb-gmm-config.settings) /home/USERNAME/.var/app/org.gimp.GIMP/config/GIMP/2.10/filters
Binaries for Plugin Instructions
You should have **bevel**, **cbevel** and **goldmetallicmeme** in the .zip for your respected OS.
Location to put the binaries
WindowsC:\Users\USERNAME\AppData\Local\gegl-0.4\plug-ins
Linux /home/(USERNAME)/.local/share/gegl-0.4/plug-ins
Linux (Flatpak) /home/(USERNAME)/.var/app/org.gimp.GIMP/data/gegl-0.4/plug-ins
**Source Code**
Grab `source_code_of_marble_metal.zip` on Github
Enjoy.
