It is currently Sun Nov 29, 2026 1:23 pm
 Post subject: Update Gimp/ some GEGL filters not working SOLVED
PostPosted: Tue Aug 15, 2023 3:56 pm  (#1)
I notice that after the update of Gimp, some GEGL filters no longer work. Starburst and Polygon generator...anyone else having problems with it?
Thanks for thinking along.. Re-installed everything today... all dll. files downloaded. And it's resolved for now.
 Post subject: Re: Update Gimp/ some GEGL filters not working
PostPosted: Tue Aug 15, 2023 7:01 pm  (#2)
Hi Jappaloe63! Do you placed the gegl plugins in the directory: "C:\YourName\YourName\AppData\Local\gegl-0.4" ? Like it shows here for Windows. viewtopic.php?f=9&t=20475
That is where you should place the third party gegl plugin, not on the "C:\Program Files\GIMP 2".
PostPosted: Tue Aug 15, 2023 7:37 pm  (#3)
No one else is reporting this on Gimp 2.10.34 but there was a problem with the latest 2.99.16 that I fixed last month.
The plugins would give an error upon opening them.
https://www.reddit.com/r/GIMP/comments/ ... o_prevent/
Everything is has been stable for over a month. update on my github
https://github.com/LinuxBeaver
https://cdn.discordapp.com/attachments/ ... lugins.zip
(top twenty something plugins for Windows)
Individual Starburst and Polygons latest versions
https://github.com/LinuxBeaver/gegl-starburst/releases/
https://github.com/LinuxBeaver/GEGL_Polygons/releases/
PostPosted: Tue Aug 15, 2023 7:40 pm  (#4)
Someone other them me needs to learn how to maintain GEGL filters. I can see a catastrophe if I wasn't here maintaining them.
PostPosted: Tue Aug 15, 2023 7:52 pm  (#5)
can someone please confirm if my starburst plugin works on Gimp 2.10.34 on Windows?
PostPosted: Tue Aug 15, 2023 8:28 pm  (#6)
Yes Starburst works OK for me on 2.10.34.
PostPosted: Tue Aug 15, 2023 9:24 pm  (#7)
Thank you for testing @oldmangrumpy.
The issue is still unknown.
PostPosted: Wed Aug 16, 2023 12:27 am  (#8)
All filters are in the correct folder. When I went back to the previous version of Gimp everything worked again.
PostPosted: Wed Aug 16, 2023 2:49 am  (#9)
Is this an installation of the latest Gimp 2.10.34 - version 3 (gimp-2.10.34-setup-2.exe) There seems to be a couple of files missing libicuin72.dll
libpcre2-16-0.dll
I do not know if this affects those GEGL filters, I do not use them but a possibility.
Keep your version 2 Gimp for now.
PostPosted: Wed Aug 16, 2023 4:07 am  (#10)
Tried it but didn't help...anyway...thanks.
PostPosted: Wed Aug 16, 2023 4:36 am  (#11)
I think you misunderstood, no matter, stick with your older version of Gimp 2.10.34
I am wrong (again ;) ) Not often I delve into Windows. This a clean install of the latest Gimp 2.10.34 and that GEGL starburst filter. Works here. As previous posts, check for old GEGL versions.
PostPosted: Wed Aug 16, 2023 10:45 pm  (#12)
ok awesome. Out of paranoia I'd like to know if GEGL Effects works, that's the main plugin
PostPosted: Wed Aug 16, 2023 10:53 pm  (#13)
If you remove my plugins from the directory does Gimp start up normal?
PostPosted: Thu Aug 17, 2023 3:12 am  (#14)
contrast_ wrote:
...snip...
This is from a very clean Gimp installation with nothing legacy remaining. Using your windows_top_twenty_gegl_plugins.zip
Effects works and the others, I went down the list one at a time. Seem to be ok, except I cannot see "common adjustments".
PostPosted: Thu Aug 17, 2023 12:23 pm  (#15)
Answer for Contrast: Gimp works perfectly well (with or without plugins)
PostPosted: Thu Aug 17, 2023 1:58 pm  (#16)
rich2005 wrote:
contrast_ wrote:
...snip...
Common adjustments was deprecated long ago and replaced with this.
https://github.com/LinuxBeaver/GEGL-Col ... n/releases
