It is currently Sun Nov 29, 2026 10:24 am
 Post subject: Water displacement map (SOLVED)
PostPosted: Sun Aug 27, 2023 12:04 pm  (#1)
I am looking for the water displacement map script used in Mahvin's tutorial. The link there no longer works.
http://gimpchat.com/viewtopic.php?f=10&t=993#p25248
 Post subject: Re: Water displacement map
PostPosted: Sun Aug 27, 2023 12:40 pm  (#2)
Download
Here > http://web.archive.org/web/201204211401 ... node/13778
Or here > viewtopic.php?f=8&t=2735#p35272
Patrice
PostPosted: Sun Aug 27, 2023 12:46 pm  (#3)
I found this!
Full Water reflection with map.scm [10 KiB]
Downloaded 73 times
PostPosted: Sun Aug 27, 2023 2:50 pm  (#4)
Thank you very much PixLab and Jappaloe63. I have both now. :coolthup :tyspin
 Post subject: Re: Water displacement map (SOLVED)
PostPosted: Sun Aug 27, 2023 5:56 pm  (#5)
Also thank you to Diego. :hi5
