It is currently Tue Nov 17, 2026 10:06 am
 Post subject: GEGL marble wallpaper/background plugin
PostPosted: Mon Aug 28, 2023 9:19 pm  (#1)
MARBLE WALLPAPER GEGL GIMP PLUGIN
GEGL instantly generates marble backgrounds with this plugin. It was inspired by a Gimp tutorial for marble wallpaper done entirely in GEGL syntax. It has a color overlay with six blend modes to choose from. If the colors opacity is 0. It will be gray
DOWNLOAD WINDOWS AND LINUX BINARIES HERE (.so) is for Linux (.dll) is for Windows
https://github.com/LinuxBeaver/Gimp_Mar ... n/releases
LOCATION TO PUT BINARIES (.so or .dll) they do not go in the normal plugins folder.
Windows
Linux
Then Restart Gimp and go to GEGL Operations to find the plugins. Its name is "Marble"
If you use Gimp 2.99.16+ you will find them in the menu under filters>render>fun
This is only in the menu of 2.99.16+, 2.10 users go to GEGL Operations.
More Previews
 Post subject: Re: GEGL marble wallpaper/background plugin
PostPosted: Mon Aug 28, 2023 11:34 pm  (#2)
Is it a great plugin? Yes
Was it needed? Yes, I seriously think so.
But
"gimp:menu-path", "<Image>/Filters/Render/Fun" :bluesad
"Textures" instead of "Fun" would have been a real meaning name for a sub-menu.
Now that GIMP gave the right to put GEGL in the menu, I wonder how many strange, numerous menu/sub-menus' names cluttering our interface we will have.
If python and scheme we can change it on the fly without affecting anything, with GEGL we cannot...
Just my 2 cents...
Patrice
PostPosted: Mon Aug 28, 2023 11:40 pm  (#3)
Was it needed? I think so.
But
Just my 2 cents...
I have used Render>Fun for all my rendering plugins.
Open my .c file and edit the last two lines then recompile.
"name", "lb:gumballs",
"title", _("Gum Balls"),
"reference-hash", "confejkaefkftdtetti",
"description", _("Renfer balls on canvas"),
"gimp:menu-path", "<Image>/Filters/Render/Fun",
"gimp:menu-label", _("Gum Balls..."),
PostPosted: Tue Aug 29, 2023 3:30 am  (#4)
This only applies to Gimp-2.99.
99.9% right for PixLab (use existing menus, not create new "entities").
0.1% for LinuxBeaver, because that's how much I assess the willingness of users to compile their own (especially for Win: no knowledge or willingness to install ~3 Gb msys64/mingw64).
Also in Gimp-2.10, Beaver plugins that will not become an official part of GEGL should be distinguished by a different icon - some sort of G+B combination - rather than the absence of an icon).
PostPosted: Tue Aug 29, 2023 11:38 am  (#5)
I cannot set the icons. That is impossible. Only plugins with the (gegl:) name space have that icon. Plugins that use name spaces other then gegl: have no icon. Gimp's team instructed me to change all my plugins from (gegl:) to my own name space. So eventually all my plugins will lack the icon.
This is not my own doing and future versions of Gimp may block all plugins that use the gegl: name space. The only reason I have not changed the name space of GEGL Effects and major text styling plugins is because I don't want to break presets for most normal users. I already have a separate branch on my own computer where all my plugins are lb: and lack icons.
PostPosted: Sat Oct 07, 2023 12:05 pm  (#6)
Don't forget that you can manually add a gradient on top of my marble plugin for even better results. GEGL is not capable of calling Gimp Gradients, but in the future it could be. ( I notified Gimp's team on it) so in the future it may be possible to auto call gradients inside the filter.
PostPosted: Sun Jul 14, 2024 2:18 am  (#7)
I am really sad this plugin causes a crash on close in GIMP 3 and nothing I can do will solve it. This is one of my favorite plugins to use personally. I literally want to cry.
PostPosted: Sun Jul 14, 2024 1:25 pm  (#8)
Let the time to the GIMP team to fix their thing. I saw you have opened many issues there > https://gitlab.gnome.org/GNOME/gimp/-/i ... ge_size=50 where a lot were closed because you did not answer their questions, maybe a good start would be to answer those questions? :bigthup
Patrice
PostPosted: Sun Jul 14, 2024 5:40 pm  (#9)
I am doing one last attempt to solve it's crash on close. If this doesn't work it will be removed.
PostPosted: Sun Jul 14, 2024 8:48 pm  (#10)
You should stop to remove your filters IMO, a lot of people will use 2.10.xx when 3 will go out, just because lots of plugin won't work.
Also people can go back in history to download older version to try them.
Patrice
PostPosted: Sun Jul 14, 2024 9:01 pm  (#11)
Why not just use gimp's render > noise > solid noise and colorize (remembering you can change the sliders to suit.
like this?
PostPosted: Sun Jul 14, 2024 9:42 pm  (#12)
Even if the actual one has a bug, it's still usable :mrgreen:
Patrice
PostPosted: Sun Jul 14, 2024 9:47 pm  (#13)
Good try Contrast. Samj has one in GMIC already with colorization
PostPosted: Mon Jul 15, 2024 1:52 am  (#14)
uh... that wasn't intended but I see the src blend mode variations cause that.
Anyhow if you want to use marble don't use the 2.99.19 exclusive build with that bug. Use this normal healthy build
Marble will work in 2.99.19 but it has the potential to cause a crash on closing a tab. Meaning GIMP will freeze when a tab closes.
PostPosted: Mon Jul 15, 2024 1:54 am  (#15)
I'm not removing anything lol. All my GIMP 3 safe plugins are here. All other repos are normal. Though I did update a few repos to remove crop.
https://github.com/LinuxBeaver/GIMP_3_G ... R/releases
PostPosted: Thu Aug 29, 2024 4:54 am  (#16)
Marble should work once again on GIMP 3 without crash on close, also its hard to believe but Marble is one year old today.
PostPosted: Fri Aug 30, 2024 4:02 am  (#17)
Happy birthday to Marble :clap
:hbd
Patrice
PostPosted: Sat Mar 21, 2026 10:30 pm  (#18)
Update for Windows to use gettext, Source Code is here if you need it
https://github.com/LinuxBeaver/GEGL-GIM ... e/releases
marble_windows_binaries_gegl_plugin.zip [1.04 MiB]
Downloaded 80 times
LOCATION TO PUT BINARY
