It is currently Sun Nov 29, 2026 7:09 pm
 Post subject: GEGL Gold Bevel Text Gimp Plugin
PostPosted: Thu Sep 21, 2023 1:33 pm  (#1)
Download binaries and code here
https://github.com/LinuxBeaver/Gimp_Gol ... n/releases
This is a very slow plugin with very high quality results. It depends on my plugins sharp bevel and metallic that are two high quality filters of their own. As well as mini operations of mine threshold alpha 2 and smooth edge. They all ship with it in one zip file.
The beta version source code I posted in another thread got a bug fix update that fixed the elevation and depth sliders. This is the final version that has binaries and completed source code.
Location to put binaries
Windows
C:\Users\USERNAME\AppData\Local\gegl-0.4\plug-ins
Linux
Linux (Flatpak)
This filter has two presets that can be downloaded by following additional instructions about (GimpGegl-lb-gmm-config.settings)
Windows (GimpGegl-lb-gmm-config.settings)
C:\Users\USERNAME\AppData\Roaming\GIMP\2.10\filters
Linux (GimpGegl-lb-gmm-config.settings)
/home/USERNAME/.config/GIMP/2.10/filters
Linux Flatpak and Chrome book (GimpGegl-lb-gmm-config.settings)
/home/USERNAME/.var/app/org.gimp.GIMP/config/GIMP/2.10/filters
Once you are done with all of this restart Gimp and go to GEGL Operations and look for "Gold Bevel Text" if you use Gimp 2.99.16+ you will see Gold Bevel in filters>Text Styling.
Let me know what you guys think about the plugin or consider showing off previews of it in use. This plugin is a fusion of my existing plugins "metallic and sharp bevel" found here independently.
https://github.com/LinuxBeaver/GEGL_sha ... mp_plugin/
https://github.com/LinuxBeaver/gegl-met ... -with-GEGL
 Post subject: Re: GEGL Gold Bevel Text in Gimp
PostPosted: Thu Sep 21, 2023 1:39 pm  (#2)
Preview of plugin in alt ruby red color
 Post subject: Re: GEGL Gold Bevel Text Gimp Plugin
PostPosted: Sat Dec 23, 2023 2:03 pm  (#3)
I am going to see if I can make a non (gimp:) namespace variation of this plugin so it can be called in Pixelitor's GEGL and python's GEGL that way people can use it outside of Gimp or in Gimp with python. Currently it cannot work outside of Gimp.
to learn more about calling GEGL in Pixelitor go here.
viewtopic.php?f=22&t=3247&p=286097#p286084
to learn more about GEGL in python go here
viewtopic.php?f=9&t=20613&start=90
btw, I'm surprised this thread has such little interest. This is the most realistic gold plugin I ever made
Example of a previous Gimp only operation being called in Pixelitor's GEGL
