It is currently Sun Nov 29, 2026 1:57 am
 Post subject: GEGL Glass Text (Gimp Plugin)
PostPosted: Sun Oct 01, 2023 10:54 am  (#1)
I made a new Gimp plugin that transforms plain text into Glass Text. It works instantly, but it has a special hard light slider that will then require the hard light blend mode in Gimp (not GEGL), but without moving the hardlight slider, Which is its default) it will work normal.
Download plugin here
https://github.com/LinuxBeaver/Glass_Te ... /GlassText
Image Previews
LOCATION TO PUT BINARIES
Windows
Linux
Code
Save for "source_code_of_glass_text" on Github. You will find the source code of glass text, glossy balloon, metallic and edge smoother.
Fun Facts about the plugin, this plugin ships with Glossy Balloon, Metallic and threshold alpha 2 and requires then to work. If you already have these binaries. OVERWRITE ALL OF THEM
2. fun fact, this plugin originally would have only worked with Gimp's hard light blend mode but then I learned that I can mimick the hard light blend mode by erasing certain gray colors; which I did with an internal GEGL color to alpha.
I'd be more then happy if users showed off the plugin in action or projects they made with it. Enjoy.
