It is currently Sun Nov 29, 2026 1:45 am
 Post subject: GEGL Plastic Wrap plugin
PostPosted: Tue Oct 03, 2023 3:57 pm  (#1)
Download plugin here.
https://github.com/LinuxBeaver/Plastic_ ... n/releases
Previews
Location to put binaries, they do NOT go in the normal plugins folder.
Windows
Linux
Then restart Gimp and go to GEGL Operations and look for "Plastic wrap" if you use Gimp 2.99.16+ you will see this filter in filters>light and shadow>plastic wrap. In 2.10 it is only in GEGL Operations drop down list.
Fun facts and comments about this plugin
This plugin is directly inspired by Adobe Photoshop CS2's "plastic wrap" filter.
During development it was planned for this plugin to use both my bevel and threshold alpha 2 plugin before I ditched them in favor of really complex node connections. This means my plugin only needs one binary to work "plastic_wrapping"
I spent over a year trying to make a plastic wrap plugin like this but failed until today.
Feel welcome to post screenshots of you using the plugin or work you did with it.
 Post subject: Re: GEGL Plastic Wrap plugin
PostPosted: Tue Oct 03, 2023 4:34 pm  (#2)
Nice to have this in GEGL.
