It is currently Sat Nov 28, 2026 11:01 pm
 Post subject: Calendar month and year plugin (script .scm) updated - modified
PostPosted: Sat Oct 07, 2023 1:54 am  (#1)
Origin:
The original script is from https://www.gimphelp.org/other_calendar_month.html (I have it from ages)
Then recently I discovered the same but with the possibility for the year to chose from month to month https://www.gimpscripts.net/2020/12/sg-calendar.html this later script has no Ctrl+Z capabilities (I did try to fix it, but nope I got more errors) and can be buggy as well as you do need to go to Select > None after that script did run)
Why:
It all started when I tried the script from gimpscripts, I saw there was a Russian version in this script, I told myself, "it misses the Ukrainian language!".
Then I just wanted to add a slider or two and change some default values and extend the max year on the one I did have from gimphelp, then testing it many times, I did many things to suit my needs like changing some others default values, then finally add the Ukrainian language, fixing a bug in the "Date position" as it was a mess in the drop-down list about the order, changing labels to be more specific as my test gave me a better understanding how it works, etc... (once I was in, I couldn't stop :hehe )
So two scripts -> which one:
I did work and tested thoroughly on the one from gimphelp sg-calendar-from-gh-210.scm, and just reported few changes on the other one sg-calendar-from-gs.scm, I did took some translations from the later that sg-calendar-from-gh-210.scm did not have, add also Ukrainian to the one from gimpscripts...
But overall this one -> sg-calendar-from-gh-210.scm is the one I use, is less buggy (maybe a point of view?), has the Ctrl+Z option working, and left the canvas without an active selection thus I like it better -> for sure it's just because I did all with it that I like it better :hehe , I'm not fair at this point.
On the other hand -> sg-calendar-from-gs.scm can make a year calendar from a month and ends to another month that you chose, where the other one gives you a full year. And let's face it, I just reported few things on it, not really doing things, and just tried it not fully testing it! Thus I don't really know this one.
I'm not a programmer:
I did not touch the core code, nor algorithms, etc... I did made a lot of changes from line 1 to 176 and from 761 to 812 in sg-calendar-from-gh-210.scm.
THUS, the usual warning -> if you download those scripts, you should know that they WILL BURN your computer, maybe your house with it...
So if you want to keep your car, park it outside of your garage, two or three blocks away from your house.
Both scripts are inside, you should not put them together, but I did some slight changes and they can be installed together in the script directory/folder.
On the menu Filters > Render > Calendar > (the entries starting with "Gs" is the script from gimpscript)
calendars.7z [11.91 KiB]
Downloaded 263 times
Example Year 2077
Example January 2099
Few things to know that can help:
There is an option called "Right Justify:...", this option affect only the numbers composed with one digit only -> if UNchecked, numbers 1 to 9 will be aligned vertically on the first digit of the numbers with 2 digits.
See?
When checked this option will align vertically the numbers composed with 1 digit, in the middle of the numbers composed with 2 digits
See?
Also the "Padding" in the year calendar (only in the year), will increase the space of the banner for the month's name, as well as the space BETWEEN rows, but it has a counter effect, it will decrease the size of the month's grids.
Roughly a month's name cannot be larger than the month's grid (see November/December, the biggest names), thus when a big name reach the wideness of its grid, if you continue to increase the Padding, this will start to add more space between rows -> thus decreasing the size of the months grid even faster -> as a name cannot be bigger that its grid -> now also decrease the month's name and increase even more the space between rows.
I don't know if you understand my explanations... but I discovered this during my tests. I found it quite genius once I understood, tough, but you should understand how it works, it's quite simple :mrgreen:
Padding at 10 100% view
Padding at 30 100% view (see the month's grid already decrease while the month's names did increase
You will find bugs, ants, and maybe some fishes!
Please I can only help (a very little) with sg-calendar-from-gh-210.scm, that's the only one I truly tested up to the other side of our galaxy.
Patrice
 Post subject: Re: Calendar month and year plugin (script .scm) updated - modified
PostPosted: Sat Oct 07, 2023 3:09 am  (#2)
First step of becoming a programmer, in spite of your reluctance...
Welcome!
PostPosted: Sat Oct 07, 2023 4:17 am  (#3)
Hats off to you for playing with the scm format!
PostPosted: Sat Oct 07, 2023 9:28 pm  (#4)
Welcome!
:rofl :rofl
I know absolutely nothing in Python, but I found python "easier"/ more readable could be the word, maybe because from my point of view, Python looks a lot more human ;)
Thank you very much Diego and Skinnyhouse for your kind words. :tyspin
Patrice
PostPosted: Sun Oct 08, 2023 1:52 am  (#5)
Patrice, you have given a great step to much more. Congrats!
I'll test it. I'll do my next planning with your plug-in. Thanks :clap :tyspin
PostPosted: Sun Oct 08, 2023 2:10 am  (#6)
Welcome!
:rofl :rofl
Second step towards entering programming: comparing script-fu and python and selecting python. Go on... :gimp
PostPosted: Sun Oct 08, 2023 9:30 pm  (#7)
Happily that I was not drinking some coffee while reading :rofl :rofl
I literally bursted into laughter
Thanks a lot for the laughter, Diego, that were very good ones :yes
Patrice
PostPosted: Sun Oct 08, 2023 9:52 pm  (#8)
Thank you very much Issabella for your kind words, do not hesitate if you see a problem (no sure I can solve it, though, but find some "trick" solution, yes it's possible)
:tyspin
Patrice
PostPosted: Thu Oct 19, 2023 8:37 pm  (#9)
My instinct would be to do this kind of thing as a plugin for Inkscape rather than GIMP. Why? Because it’s the kind of thing that you might want to edit/tweak by hand after it’s been generated. Inkscape documents are SVG, as you may know, and SVG is resolution-independent, so you can do this kind of editing without loss of quality. You can include the GIMP graphic (or any other graphic) as a background layer.
PostPosted: Thu Oct 19, 2023 10:23 pm  (#10)
No need, it exists in Inkscape, just go to the top menu Extensions > Render > Calendar...
On a side note:
Not everyone is willing to learn both GIMP and Inkscape.
And what about not savvy computer users who knows only GIMP.
On different forums or reddit, some people said it's better to do it in LibreOffice/Calc or Writer, so for them even Inkscape is not good enough... ;)
Patrice
PostPosted: Thu Oct 19, 2023 10:59 pm  (#11)
I wouldn’t do it in LibreOffice anything. You want a proper design/layout tool, which means something like the align/distribute functions in Inkscape. GIMP is more for your painterly pixel-oriented imagery.
PostPosted: Fri Oct 20, 2023 12:33 pm  (#12)
Anyway, the script exists for GIMP, so I find it nice of Pixlab to give it a little love and update it (and maybe start his programming for GIMP career this way).
Nobody must use it, if they find other ways.
But It's nice to have.
Regards
nelo
PostPosted: Sat Oct 21, 2023 1:22 am  (#13)
:hoh
:rofl :rofl :rofl
Thank you nelo for the kind words and the laughter :bigthup
Patrice
