THIS IS OPTIONAL FOR SYNTAX MODE AND IS NOT NEEDED TO USE THE PLUGIN.
Download
https://github.com/LinuxBeaver/Gimp_Gol ... n/releasesand paste this in the syntax box.
lb:ring
lb:gold
blendmode=colordodge
expand=2.5720000000000001
azimuth=67
elevation=10.460000000000001
medianradius=1
huerotate=0
desaturate=1.3999999999999999
light=1
dropshadow x=6 y=4 radius=3 opacity=0.5
Syntax to make plugin look like "Glossy Balloon" (requires no binaries, as it is a recreate of balloons raw graph)
color-overlay value=#f587ff median-blur percentile=20 alpha-percentile=30
gaussian-blur std-dev-x=2 std-dev-y=2
id=3
screen aux=[ ref=3 emboss type=bumpmap azimuth=90 elevation=15 ]
id=3
opacity value=10
median-blur radius=0
