It is currently Sat Nov 28, 2026 7:08 pm
 Post subject: Light-Sabre - glow your existing selection
PostPosted: Thu Nov 09, 2023 3:11 pm  (#1)
The technique is described on reddit's "Is there an easy way to add a fancy glow effect?" by Davjwx.
I just thought it would be fun to turn it into a plug-in with live preview and editable
1. Glow Size Factor
2. Glow Opacity
that works on your existing selection
It'll be under Python-Fu/Live Preview/Light Sabre Live
File comment: fixed a bug that used to not look the same as preview
light-sabre-live (Rel 1.01).zip [3.37 KiB]
Downloaded 277 times
 Post subject: Re: Light-Sabre - glow your existing selection
PostPosted: Thu Nov 09, 2023 4:11 pm  (#2)
Rel 1.01 fixes the non-consistent look between result and preview
PostPosted: Fri Dec 01, 2023 3:00 pm  (#3)
What makes this different from dropshadow with blend modes?
PostPosted: Fri Dec 01, 2023 4:09 pm  (#4)
I have no idea, it might be the same. I just used it as opportunity to play with live preview.
