Download plugin here (follow basic instructions)
https://github.com/LinuxBeaver/Neon_Edg ... n/releasesHere is a really cool edge detect plugin I made that is way better then the default and it has a glow option.
It has two modes
DefaultAttachment:
Restore Original ColorAttachment:
This is directly inspired by a Glow filter found in Adobe Photoshop CS5.
LOCATION TO PUT BINARIESWindows
Linux
If you use Gimp 2.99.16+ you will find this in Filters>Edge Detect. On Gimp 2.10 it is in GEGL Operation drop down list under the name
Neon Edge Detect
