Download binaries and code here
https://github.com/LinuxBeaver/Colored_ ... /releases/New Gimp Plugin that makes a colored pencil sketch effect
Location to put binariesWindows
Linux
Stuff to know about this plugin
1. The colored Pencil mode is a slider to enable/disable
2. The sketch effect is made by linear motion blur
3. If you have Gimp 2.10 you will find this in GEGL Operation under the name Charcoal Sketch. If you use Gimp 2.99.16+ you will find this filter in filters/artistic/sketched image.
