EDIT:
Big huge update, I did re-do all, not the same script anymore (same purpose, though), but now your can use your own setting to export all opened images at once in GIMP
I did updated the manual as well (you won't believe it, but I think it's the longest part when you write a script or plugin, and the worse is that we know that nobody will read it
Latest version to download is over there >
https://gitlab.com/_PixLab/GIMP-Export-All-Images-AsRead my latest comments about this update
------------------ Original Post Below -------------------
Everything happened on G-F, inspired by
Rich2005, and
Ofnuts trying to put me on the right Path
Starting from a script batch exporting only the selected layer in an image to a full export export of the image with more options.
Purpose.Batch export all opened images in GIMP at once to JPG, PNG, WebP, TIFF, BMP, without the need to export them one by one, nor the need to interact with the user interface each time an image is exported as everything can be automated.
Use case example: you sliced your image from a guide’s grid of 10x10, and you have 100 new opened images (red rectangle below). Or simply, like everyday, you just did work on a dozen of images at a time and want them to be exported ASAP just to check the final image, but you need to work more on them and re-export them with the same setting at once.
This script will do the job in a matter of seconds.
Recommendation: This script will override existing image with the same name and extension, even though it will auto-number each exported image to not match an existing name, it’s better that you create a new folder for the exported images to not override the original images.
Download (I did wrote a manual in PDF included, inspired by Ofnuts but I'm less technical
I'm thinking about Tin (trandoductin), and for me it's a good idea to put also the code written in the comment like he does, because Wayback Machine, rarely save the zips, thus in case of, people can still access the code, even if archive.org did not save the zip
; This program is free software; you can redistribute it and/or modify it under the terms of the GNU General Public License
; as published by the Free Software Foundation; either version 2 of the License, or (at your option) any later version.
; This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY;
; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
; See the GNU General Public License for more details
; Original script from Lauchlin Wilkinson (& Saul Goode) from 2014/04/21 see at the end
; added section for webp - rich 2023/08/06
; Now Export full images with options PixLab 2023/08/10 & 2023/12/06
; changed numbers of numbering to higger numbering (substring "00000" (string-length and (list 0 0 9000 1 100 0 SF-SPINNER)
; changed menu entry "<Image>/File/Save ALL As" and added (script-fu-menu-register "script-fu-save-all-images" "<Image>/File/E_xport") to not be at the bottom
; 2023/12/06 changed (car (gimp-image-get-active-layer image)) to (car (gimp-layer-new-from-visible image image "export")), changed the default directory to Desktop
; 2023/12/06 Added JPG, PNG, WEBP, BMP, TIF to be customizable, changed file-webp-save to file-webp-save2 latest version + settings, commented all settings by image type from procedure browser
; 2023/12/07 Added choice for the user to choose all auto (RUN-NONINTERACTIVE), or from image setting all auto (RUN-WITH-LAST-VALS) or manually (RUN-INTERACTIVE)
(define (pxl-script-fu-save-all-images-as inDir inSaveType
inFileName inFileNumber runChoice)
(let* (
(i (car (gimp-image-list)))
(ii (car (gimp-image-list))) ; I did not pay attention but I could use this one instead of creating j
; (j (car (gimp-image-list))) ; to keep the total image number to compare to "i" minused by 1 with each loop
(image)
(isInteractive) ; declare isInteractive to set it later on
(newFileName "")
(saveString "")
(pathchar (if (equal?
(substring gimp-dir 0 1) "/") "/" "\\"))
(set! saveString
(cond
(( equal? inSaveType 0 ) ".jpg" )
(( equal? inSaveType 1 ) ".webp" )
(( equal? inSaveType 2 ) ".png" )
(( equal? inSaveType 3 ) ".tif" )
(( equal? inSaveType 4 ) ".bmp" )
(set! isInteractive ; no more, the other isInteractive works as intended https://www.gimp-forum.net/Thread-RUN-WITH-LAST-VALS-in-Script-Fu-is-not-what-you-might-think
(cond
(( equal? runChoice 0 ) RUN-NONINTERACTIVE )
(( equal? runChoice 1 ) RUN-INTERACTIVE )
(( equal? runChoice 2 ) RUN-WITH-LAST-VALS )
(while (> i 0)
;(set! isInteractive
; (cond
; ((= i j) RUN-INTERACTIVE)
; (else RUN-WITH-LAST-VALS) ; last vals is the last values used IF the image has already been exported, then runs auto, but if never export during SESSION it will ask for settings
(set! image (vector-ref (cadr (gimp-image-list)) (- i 1)))
(set! newFileName (string-append inDir
pathchar inFileName
(substring "0000000" (string-length
(number->string (+ inFileNumber i))))
(number->string (+ inFileNumber i)) saveString))
(cond
((equal? saveString ".webp")
(file-webp-save2 isInteractive ;RUN-NONINTERACTIVE
newFileName
newFileName
1 ; preset 0=default 1=pic 2=photo 3=drawing 4=icon 5=text
0 ; Use lossless encoding (0/1)
90 ; Quality of the image (0 <= quality <= 100)
90 ; alpha-quality 0<>100
0 ; Use layers for animation (0/1)
0 ; Loop animation infinitely (0/1)
0 ; Minimize animation size (0/1)
0 ; Maximum distance between key-frames (>=0)
0 ; Toggle saving exif data (0/1)
0 ; Toggle saving iptc data (0/1) works only if save XMP data is also checked ?
0 ; Toggle saving xmp data (0/1)
0 ; Toggle saving thumbnail (0/1)
0 ; Delay to use when timestamps are not available or forced
0 ; Force delay on all frames (0/1)
((equal? saveString ".jpg")
(file-jpeg-save isInteractive ;RUN-NONINTERACTIVE
newFileName
newFileName
0.88 ; Float Quality of saved image (0 => quality <= 1)
0 ; Float Smoothing factor for saved image (0 => smoothing <= 1)
1 ; Use optimized tables during Huffman coding (0/1)
1 ; Create progressive JPEG images (0/1)
"" ; String Image comment (if you want to put "Image made by me!")
2 ; Sub-sampling type { 0, 1, 2, 3 } 0 == 4:2:0 (chroma quartered), 1 == 4:2:2 Horizontal (chroma halved), 2 == 4:4:4 (best quality), 3 == 4:2:2 Vertical (chroma halved)
1 ; Force creation of a baseline JPEG (non-baseline JPEGs can't be read by all decoders) (0/1)
0 ; Interval of restart markers (in MCU rows, 0 = no restart markers)
2 ; DCT method to use { INTEGER (0), FIXED (1), FLOAT (2) }
((equal? saveString ".png")
(file-png-save2 isInteractive ;RUN-NONINTERACTIVE
newFileName
newFileName
1 ; Use Adam7 interlacing? (0/1)
9 ; Deflate Compression factor (0--9)
1 ; Write bKGD chunk? (0/1)
0 ; Write gAMA chunk? (0/1)
0 ; Write oFFs chunk? (0/1)
0 ; Write pHYs chunk? (0/1)
1 ; Write tIME chunk? (0/1)
0 ; Write comment?
0 ; Preserve color of transparent pixels? (0/1)
((equal? saveString ".tif")
(file-bigtiff-save isInteractive ;RUN-NONINTERACTIVE
newFileName
newFileName
3 ; Compression type: { NONE (0), LZW (1), PACKBITS (2), DEFLATE (3), JPEG (4), CCITT G3 Fax (5), CCITT G4 Fax (6) }
1 ; Keep the color data masked by an alpha channel intact (do not store premultiplied components) (0/1)
0 ; Export in BigTIFF variant file format (0/1)
(else
(gimp-file-save isInteractive ;RUN-NONINTERACTIVE
newFileName
newFileName
(gimp-image-clean-all image)
(set! i (- i 1))
(script-fu-register "pxl-script-fu-save-all-images-as"
"Export All Images As..."
"Export all opened images at once\nSupported Export types: WebP, JPG, PNG, BMP, and TIF\nBigTiff accessible in manual mode first "
"PixLab (& Rich (& Lauchlin Wilkinson (& Saul Goode)))"
"2023/12/07"
SF-DIRNAME "Select a Directory to Export Images" "Desktop"
SF-OPTION "Select an Image Type to Export" (list "JPG" "WebP" "PNG" "TIFF" "BMP")
SF-STRING "Input an Image Base Name" "IMAGE-"
SF-ADJUSTMENT "Input a Start Number (Auto-Numbering)" (list 0 0 999999 1 100 0 SF-SPINNER)
SF-OPTION "Select How to Export:\n[1] Settings from the script (recommended):\n[2] You confirm settings for each image:\n[3] Image Was Never Exported = Manual\n Image Was Exported Before = Auto"
(list "[1] Default (fully automated)" "[2] Full control (Manual Mode)" "[3] Settings From Latest Export per Image\n\n First Time Image is Exported is Manual\n Then, All Next Export are Automated")
(script-fu-menu-register "pxl-script-fu-save-all-images-as" "<Image>/File/E_xport")
;;;;;;;;;;;;;;;;;;;;;;;;;;;; ORIGINAL SCRIPT ;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;;
; (define (script-fu-save-all-images inDir inSaveType
; inFileName inFileNumber)
; (let* (
; (i (car (gimp-image-list)))
; (ii (car (gimp-image-list)))
; (image)
; (newFileName "")
; (saveString "")
; (pathchar (if (equal?
; (substring gimp-dir 0 1) "/") "/" "\\"))
; (set! saveString
; (cond
; (( equal? inSaveType 0 ) ".jpg" )
; (( equal? inSaveType 1 ) ".bmp" )
; (( equal? inSaveType 2 ) ".png" )
; (( equal? inSaveType 3 ) ".tif" )
; (while (> i 0)
; (set! image (vector-ref (cadr (gimp-image-list)) (- i 1)))
; (set! newFileName (string-append inDir
; pathchar inFileName
; (substring "00000" (string-length
; (number->string (+ inFileNumber i))))
; (number->string (+ inFileNumber i)) saveString))
; (gimp-file-save RUN-NONINTERACTIVE
; image
; (car (gimp-image-get-active-layer image))
; newFileName
; newFileName
; (gimp-image-clean-all image)
; (set! i (- i 1))
;(script-fu-register "script-fu-save-all-images"
; "<Image>/File/Save ALL As"
; "Save all opened images as ..."
; "Lauchlin Wilkinson (& Saul Goode)"
; "2014/04/21"
; SF-DIRNAME "Save Directory" ""
; SF-OPTION "Save File Type" (list "jpg" "bmp" "png" "tif")
; SF-STRING "Save File Base Name" "IMAGE"
; SF-ADJUSTMENT "Save File Start Number"
; (list 0 0 9000 1 100 0 SF-SPINNER)
