It is currently Thu Nov 26, 2026 5:52 am
 Post subject: Map Transform - using Template
PostPosted: Fri Dec 29, 2023 8:12 am  (#1)
You know how map object does different kinds of maps.
I thought what if people could create templates that define how to do a collection of perspective transforms using paths.
Then it allows for others to use their own image and apply to the template.
For example:
Here I have an active vectors/path named 'original' (It's important that this is active [it doens't have to be named 'original' just has to be active layer] for the plug-in to work properly telling it that's the original so don't do any work on it but use it as reference or to select the area to be transformed)
Also it's important that this path is a 4 point path starting in the top left corner and going clock-wise.
It'll then loop through all other paths which I created by duplicating the 'original' path and then manually moving the points around to define my transforms and apply the perspective transform using the defined path. It's like making a collage out of different 4 pointed shapes.
Then select the layer that you want to use as transformations to make it active. In my case i selected the layer that contained the leopard with the side-way white T.
Then run plug-in.
And you'll get something like this:
Here's the .xcf for my example that you can run plug-in on (or change the content of the active layer to map your own texture).
vitruvian-man.xcf [3.2 MiB]
Downloaded 83 times
Here's the Plug-in Code below (Plug-in will be available under /Python-Fu/Map Transform...):
#!/usr/bin/env python
# map-transform.py
# Created by TT
# License: GPLv3
# This program is free software: you can redistribute it and/or modify
# it under the terms of the GNU General Public License as published by
# the Free Software Foundation, either version 3 of the License, or
# (at your option) any later version.
# This program is distributed in the hope that it will be useful,
# but WITHOUT ANY WARRANTY# without even the implied warranty of
# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
# GNU General Public License for more details.
# To view a copy of the GNU General Public License
# visit: http://www.gnu.org/licenses/gpl.html
#| Change Log |
# Rel 1: Initial release
from gimpfu import *
import random
import math
def get4Points(vectors):
   num_strokes,stroke_ids = pdb.gimp_vectors_get_strokes(vectors)
   #gets first stroke, assuming it has 4 points
   _type,num_points,controlpoints,closed = pdb.gimp_vectors_stroke_get_points(vectors,stroke_ids[0])
   #get 4 points
   fourpoints = []
   i = 1 #first point is at index 1 because control points are indexed 0,1,2 then 3,4,5 then 6,7,8 then 9,10,11
   for l in range(0,4):
      index = i*2 #because it's x and y index so we jump by 2
      fourpoints = fourpoints + [controlpoints[index],controlpoints[index+1]] #[x,y]
      i += 3 #jump by 3 controlpoints at a time
   #fourpoints should now contain 8 items (4 * [x,y])
   #we will swap the last two points because we're dealing with perspective transform so it doesn't go around
   #the square but it jumps from left to right corners.
   tempx = fourpoints[4]
   tempy = fourpoints[5]
   fourpoints[4] = fourpoints[6]
   fourpoints[5] = fourpoints[7]
   fourpoints[6] = tempx
   fourpoints[7] = tempy
   return fourpoints
def python_map_transform(image, layer):
   # pdb.gimp_image_undo_group_start(image)
   # pdb.gimp_context_push()
   #YOUR CODE BEGINS=======================
   ovectors = pdb.gimp_image_get_active_vectors(image) #original vector
   #pdb.gimp_message(ovectors.name)
   for v in image.vectors:
      if v.name != ovectors.name: #if the name is different from original vector, we do work on it
         layer_copy = pdb.gimp_layer_copy(layer,TRUE) #copy layer with TRUE alpha channel
         pdb.gimp_image_insert_layer(image,layer_copy,None,0)
         pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,ovectors) #select the original vector area to apply perspective to.
         fourpoints = get4Points(v) #get the 4 points to use as perpective transform
         transform_item = pdb.gimp_item_transform_perspective(layer_copy,*fourpoints) # *fourpoints is to unpack the array and passing it in as parameters
         pdb.gimp_floating_sel_anchor(transform_item) #anchors the transform floating selection so that it's a layer
   #pdb.gimp_message(get4Points(ovectors))
   #YOUR CODE ENDS ========================
   # pdb.gimp_context_pop()
   # pdb.gimp_image_undo_group_end(image)
   pdb.gimp_displays_flush()
    #return
register(
   "python_fu_map_transform",
   "Perspective Transforms Using Paths",
   "TT",
   "TT",
   "2023.12.29",
   "<Image>/Python-Fu/Map Transform...",
   "*",      # Create a new image, don't work on an existing one
   #INPUT BEGINS
   #INPUT ENDS
   python_map_transform)
main()
#           (PF_INT, "p0", "_INT:", 0), # PF_INT8, PF_INT16, PF_INT32  similar but no difference in Python.
#           (PF_FLOAT, "p02", "_FLOAT:", 3.141),
#           (PF_STRING, "p03", "_STRING:", "foo"),  # alias PF_VALUE
#           (PF_TEXT, "p04", "TEXT:", "bar"),
#           # PF_VALUE
#           # Pick one from set of choices
#           (PF_OPTION,"p1",   "OPTION:", 0, ["0th","1st","2nd"]), # initially 0th is choice
#           (PF_RADIO, "p16", "RADIO:", 0, (("0th", 1),("1st",0))), # note bool indicates initial setting of buttons
#           # PF_RADIO is usually called a radio button group.
#           # SLIDER, ADJUSTMENT types require the extra parameter of the form (min, max, step).
#           (PF_TOGGLE, "p2",   "TOGGLE:", 1), # initially True, checked.  Alias PF_BOOL
#           # PF_TOGGLE is usually called a checkbox.
#           (PF_SLIDER, "p3", "SLIDER:", 0, (0, 100, 10)),
#           (PF_SPINNER, "p4", "SPINNER:", 21, (1, 1000, 50)),  # alias PF_ADJUSTMENT
#           # Pickers ie combo boxes ie choosers from lists of existing Gimp objects
#           (PF_COLOR, "p14", "_COLOR:", (100, 21, 40) ), # extra param is RGB triple
#           # PF_COLOUR is an alias by aussie PyGimp author lol
#           (PF_IMAGE, "p15", "IMAGE:", None), # should be type gimp.image, but None works
#           (PF_FONT, "p17", "FONT:", 0),
#           (PF_FILE, "p18", "FILE:", 0),
#           (PF_BRUSH, "p19", "BRUSH:", 0),
#           (PF_PATTERN, "p20", "PATTERN:", 0),
#           (PF_GRADIENT, "p21", "GRADIENT:", 0),
#           (PF_PALETTE, "p22", "PALETTE:", 0),
#           (PF_LAYER, "p23", "LAYER:", None),
#           (PF_CHANNEL, "p24", "CHANNEL:", None),  # ??? Usually empty, I don't know why.
#           (PF_DRAWABLE, "p25", "DRAWABLE:", None),
#           # Mostly undocumented, but work
#           (PF_VECTORS, "p26", "VECTORS:", None),
#           (PF_FILENAME, "p27", "FILENAME:", 0),
#           (PF_DIRNAME, "p28", "DIRNAME:", 0)
#           # PF_REGION might work but probably of little use.  See gimpfu.py.
 Post subject: Re: Map Transform - using Template
PostPosted: Fri Dec 29, 2023 8:15 am  (#2)
WOW you're good! Thank you.
PostPosted: Fri Dec 29, 2023 8:17 am  (#3)
Here's another sample using the above .xcf circular texture that fit within the 'original' (4-point) vector.
PostPosted: Fri Dec 29, 2023 8:28 am  (#4)
Thanks, my hope is that we can share templates and have some fun :D
PostPosted: Wed Jan 24, 2024 11:20 am  (#5)
here's updated version that allows you to draw your other paths in the same path
other than the 'original' active path.
# map-transform.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
   controlpoints = []
   num_points = 0
   for z in range(0,num_strokes):
      _type,nps,cps,closed = pdb.gimp_vectors_stroke_get_points(vectors,stroke_ids[z])
      controlpoints = controlpoints + list(cps)
   num_points = len(controlpoints)
   #get 4 points
   farray = []
   for p in range(0,num_points/24):
      fourpoints = []
         index = i*2+(p*24) #because it's x and y index so we jump by 2
      farray.append(fourpoints)
   return farray
         farray = get4Points(v) #get the 4 points to use as perpective transform
         for p2 in range(0,len(farray)):
            fourpoints = farray[p2]
    #return
register(
   "TT",
   "TT",
   "2023.12.29",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
brick-wall-template2.xcf [2.07 MiB]
Downloaded 73 times
PostPosted: Wed Jan 24, 2024 2:10 pm  (#6)
another template that I made
namoamidabuddhapeople.xcf [2.64 MiB]
Downloaded 76 times
PostPosted: Thu Jan 25, 2024 9:13 am  (#7)
This version only uses 2 points each [rectangle] because I only needed rectangle for this one.
Don't need original, it's driven from active layer's width and height (so your active layer should only contain what you want scaled).
# map-transform2.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
def get2Points(vectors,w,h):
   controlpoints = []
   num_points = 0
   farray = []
   for p in range(0,num_points/12):
      fourpoints = []
      for l in range(0,2):
         index = i*2+(p*12) #because it's x and y index so we jump by 2
      fourpoints2 = [0,0,0,0,0,0,0,0]
      newheight = fourpoints[3]-fourpoints[1]; #get new height
      #set y
      fourpoints2[1] = fourpoints[1];
      fourpoints2[3] = fourpoints[1];
      fourpoints2[5] = fourpoints[3];
      fourpoints2[7] = fourpoints[3];
      newwidth = newheight*w/h
      #set x
      fourpoints2[0] = fourpoints[0]-newwidth/2;
      fourpoints2[2] = fourpoints[0]+newwidth/2;
      fourpoints2[4] = fourpoints[2]-newwidth/2;
      fourpoints2[6] = fourpoints[2]+newwidth/2;
      farray.append(fourpoints2)
   return farray
def python_map_transform(image,layer):
      farray = get2Points(v,layer.width,layer.height) #get the 4 points to use as perpective transform
         pdb.gimp_image_select_item(image,CHANNEL_OP_REPLACE,layer_copy) #select the original vector area to apply perspective to.
         pdb.gimp_floating_sel_to_layer(transform_item) #anchors the transform floating selection so that it's a layer
         pdb.gimp_image_remove_layer(image,layer_copy)
register(
   "python_fu_map_transform2",
   "Perspective Transforms Using Paths 2 Points based on active layer.width and layer.height",
   "TT",
   "TT",
   "2024.1.25",
   "<Image>/Python-Fu/Map Transform 2 Points...",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
PostPosted: Sun Feb 25, 2024 9:17 pm  (#8)
Decided to make plug-in to take paths that are composed of many strokes.
I'll use "original" path to map to all other paths.
Have the layer you want to map active (and it'll hide it make it invisible once it's done mapping to paths).
# map-transform.py
# Created by TT
# License: GPLv3
#| Change Log |
import random
import math
   #get 4 points
   fourpoints = []
   return fourpoints
def get4MultiPoints(vectors):
   cp = []
   for i in range(0,len(stroke_ids)):
      _type,num_points,controlpoints,closed = pdb.gimp_vectors_stroke_get_points(vectors,stroke_ids[i])
      cp = cp + list(controlpoints)
   #get 4 points
   arrof4points = []
   #cp = controlpoints[:]
   paths = len(cp)/24
   for j in range(0,paths):
      controlpoints = cp[j*24:j*24+24] #every 24 coordinate which represents a 4 point path
      fourpoints = []
      arrof4points.append(fourpoints)
   return arrof4points
   #ovectors = pdb.gimp_image_get_active_vectors(image) #original vector
   originallayername = "original"
   ovectors = pdb.gimp_image_get_vectors_by_name(image,originallayername)
      if v.name != originallayername: #if the name is different from original vector, we do work on it
         arrpoints = get4MultiPoints(v) #get the 4 points to use as perpective transform
         pdb.gimp_message(arrpoints);
         for fourpoints in arrpoints:
   pdb.gimp_item_set_visible(layer,FALSE)
    #return
register(
   "python_fu_map_transform_1",
   "TT",
   "TT",
   "2023.12.29",
   "<Image>/Python-Fu/Map Transform 1...",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
vitruvian-man-2.xcf [2.66 MiB]
Downloaded 47 times
PostPosted: Sun Feb 25, 2024 9:49 pm  (#9)
I thought it would be run to use unsplash.com images to map to paths instead of same texture all the time.
# map-transform.py
# Created by TT
# License: GPLv3
#| Change Log |
import requests
def download_image(url, save_path):
    response = requests.get(url)
    if response.status_code == 200:
        with open(save_path, 'wb') as f:
            f.write(response.content)
        print("Image downloaded successfully!")
    else:
        print("Failed to download image. Status code:", response.status_code)
import random
import math
   #get 4 points
   fourpoints = []
   return fourpoints
   cp = []
   #get 4 points
   arrof4points = []
   paths = len(cp)/24
      fourpoints = []
   return arrof4points
   ofourpoints = get4Points(ovectors)
         #pdb.gimp_message(arrpoints);
            url = "https://source.unsplash.com/800x800"
            save_path = "image.jpg"  # Provide the path where you want to save the image
            layer_copy = pdb.gimp_file_load_layer(image,save_path)
            #layer_copy = pdb.gimp_layer_copy(layer,TRUE) #copy layer with TRUE alpha channel
            pdb.gimp_layer_add_alpha(layer_copy) #add this so it's not filled with alpha background
            transform_item = pdb.gimp_item_transform_perspective(layer_copy,*ofourpoints) # *fourpoints is to unpack the array and passing it in as parameters
    #return
register(
   "TT",
   "TT",
   "2023.12.29",
   #INPUT BEGINS
   #INPUT ENDS
main()
#           # PF_VALUE
vitruvian-man-3.xcf [4.65 MiB]
Downloaded 59 times
PostPosted: Mon Feb 26, 2024 8:17 am  (#10)
Sphere composed from squares.
This version of code allows you to use keyword(s) for unsplash.com images retrieval.
# map-transform.py
# Created by TT
# License: GPLv3
#| Change Log |
import requests
    else:
import random
import math
   #get 4 points
   fourpoints = []
   return fourpoints
   cp = []
   #get 4 points
   arrof4points = []
   paths = len(cp)/24
      fourpoints = []
   return arrof4points
def python_map_transform(image, layer, keywords):
            url = "https://source.unsplash.com/800x800?" + keywords.replace(" ","%20")
    #return
register(
   "TT",
   "TT",
   "2023.12.29",
   #INPUT BEGINS
   (PF_STRING, "keywords", "Keywords:", "blue"),  # alias PF_VALUE
   #INPUT ENDS
main()
#           # PF_VALUE
sphere.xcf [16.96 KiB]
Downloaded 45 times
PostPosted: Mon Feb 26, 2024 10:41 am  (#11)
