It is currently Fri Nov 27, 2026 12:10 pm
 Post subject: Load As Layers Wire Initialization Error With Python
PostPosted: Sun Dec 31, 2023 10:18 pm  (#1)
Hello People,
Calling gimp-file-load-layers results in (python2:24932): LibGimpBase-ERROR **: 09:10:03.138: gimp_wire_write_msg: the wire protocol has not been initialized.
pdb.gimp_file_load_layers(RUN-NONINTERACTIVE, TheImage, "/Path/To/the_file.xcf").
The operations before the above statement to resize the image and the canvas work fine.
The plugin will not load unless I have that line commented. With it uncommented I see the same wire protocol error.
Various searches regarding the wire protocol have not resulted in anything useful.
What causes this?
How can I open a GIMP file as layers using python script?
GIMP 2.10.20
GIMP 2.10.20 Python Console
Python 2.7.5 (default, Apr 2 2020, 13:16:51)
[GCC 4.8.5 20150623 (Red Hat 4.8.5-39)]
Thanks
=thoth=
 Post subject: Re: Load As Layers Wire Initialization Error With Python
PostPosted: Mon Jan 01, 2024 3:49 am  (#2)
I never put "RUN-NONINTERACTIVE" in my scripts.
Maybe you just leave that out?
Regards
nelo
PostPosted: Mon Jan 01, 2024 4:48 am  (#3)
Thoth wrote:
Hello People,
What causes this?
GIMP 2.10.20
Thanks
=thoth=
In Python the "run mode" parameter is actually an optional named parameter:
pdb.gimp_file_save(exportImage,exportLayer,filePath,filePath,run_mode=RUN_INTERACTIVE)
And since it defaults to RUN_NONINTERACTIVE it can be left out in most cases.
PostPosted: Sat Jan 13, 2024 12:19 pm  (#4)
Hallo Nelo,
Leaving it out results in the wire initialization error as well.
pdb.gimp_file_load_layers(TheImage, "/Graphix/Templates/2023_isdi_xga2_04.xcf")
=thoth=
PostPosted: Sat Jan 13, 2024 12:23 pm  (#5)
Hi efnuts,
This also resulted in the Wire Initialization error.
pdb.gimp_file_load_layers(TheImage, "/Graphix/Templates/2023_isdi_xga2_04.xcf", run_mode=RUN_INTERACTIVE)
=thoth=
PostPosted: Sat Jan 13, 2024 12:24 pm  (#6)
Hi All,
I am going to try to reach out to the GIMP maintainers.
If I find a solution, I will post it here.
=thoth=
PostPosted: Sat Jan 13, 2024 7:35 pm  (#7)
Thoth wrote:
Hi All,
=thoth=
Can you show the full code? It looks like your plugin doesn't register properly.
