It is currently Thu Nov 26, 2026 9:50 am
 Post subject: My filters of the year 2024: 2) Water Sketch
PostPosted: Thu Jan 18, 2024 3:21 am  (#1)
last news:
have a look here viewtopic.php?f=11&t=20719&start=100, post#119, image 3
Glad to release my second "filter of the year 2024"
As I said when releasing my first one, during this year I will try to post various filters, either completely new or as a reshuffling of old existing code.
As usual I benefit from the support of my co-teamer Issabella, for the tests (before publishing it) and for the presentation of the various possible outcomes (after publishing it).
Thanks a lot my precious friend. :tyspin :tyspin :tyspin
This filter gives to the user the possibility to apply to an image an effect which I called "WaterSketch", using G'mic fiters.
The user can choose among many options (see next post).
Here the code, zipped.
DIEGO_ARTISTIC_WaterSketch2024.7z [7.6 KiB]
Downloaded 156 times
Note for the users who do not have an high performance computer:
the process is slow, about 3 minutes run, but it depends from the source inage:
- for images having a size of 3500 (width+height) and more, the runtime is stable, because the fiter uses a working image of 3500 (width+height)
- for images having a size < 3500, the runtime is proportionally reduced, because the filter uses the original size
During my tests I used often small images.
 Post subject: Re: My filters of the year 2024: 2) Water Sketch
PostPosted: Thu Jan 18, 2024 3:24 am  (#2)
Options used by the filter.
continues
PostPosted: Thu Jan 18, 2024 3:28 am  (#3)
(continues)
(C2G is the layer converted in B&W using GEGL C2G)
note: the DIVIDE mode can sometimes give interesting results, just try it, but we believe it can be used rarely
PostPosted: Thu Jan 25, 2024 11:24 am  (#4)
Just a little note for those who do not have downloaded this filter:
- did you have a deep look into the outcomes created by Issabella with this filter?
Some are so impressive for their proximity to real paintings, and modern in style.
PostPosted: Tue Jan 30, 2024 2:41 am  (#5)
I really had expected some outcomes done by the friends who downloaded the filter, after having seen -among the outcomes of Issabella- how many nice results you could achieve.
PostPosted: Mon Feb 05, 2024 3:18 pm  (#6)
31 downloads of your filter, Dinasset!! wow :jumpclap :jumpclap :jumpclap
Sure someone more will post their outcomes. :paint
