It is currently Thu Nov 26, 2026 2:32 am
 Post subject: Roller 5
PostPosted: Wed Jan 24, 2024 2:53 pm  (#1)
You are welcome to Roller 5.02, a GIMP 2.10 plug-in for making image compositions like wallpaper. The plug-in requires Python 2.7 to be installed.
File comment: This is a snapshot of Roller 5's main window on Windows 10.
File comment: Fixes and improves previous version.
Roller 5.02.zip [4.69 MiB]
Downloaded 101 times
Charles
 Post subject: Re: Roller 5
PostPosted: Wed Jan 24, 2024 2:59 pm  (#2)
In this demo, I wanted to illustrate the various models that Roller 5 offers. I used the Plaque option to create the black cells, and the Caption option to make the smiles.
File comment: This is the expected output of the included preset.
File comment: This has a Roller 5 preset file and install instructions.
Demo.zip [15.62 KiB]
Downloaded 84 times
Charles
PostPosted: Sat Mar 02, 2024 3:39 am  (#3)
This demo is made with Roller 5.01. I wanted to illustrate the new Backdrop Style, Roof Top. Corner Tape had a small problem that was fixed with the update.
File comment: Made with Roller 5.01 and a preset.
File comment: This folder has the files necessary to reproduce the above image using GIMP 2.10 and Roller 5.01.
Demo.zip [1.41 MiB]
Downloaded 73 times
Charles
PostPosted: Sat Mar 02, 2024 5:27 pm  (#4)
The demo image is quite good but why is the 'art' presented as an image of 'art'? Why not cut-out the middleman and have the graphic as a stand-alone image?
BTW I'm not trying to be negative here just opinionated :bigthup
PostPosted: Sun Mar 03, 2024 4:26 am  (#5)
Personally, I like to make wallpaper, so I'll take an image and scale it into a composition. I also like a wallpaper to be unique, so that is why I randomize things, and since I do this for myself, I don't worry too much about color harmony, the art's theme, lighting, balance or other critical aspects when creating a composition.
Cheers,
Charles
PostPosted: Tue Apr 02, 2024 10:43 pm  (#6)
In this demonstration preset, Roller 5.02 is using a Backdrop Style, Acrylic Sky with two Table models and a Cell model. The Cell model has a Netting Plaque with a Rounded Corners Cut-out Mask and a Border Line Frame. The Table models are using ellipse shaped cells with Per Color Plaques. Lastly, Tim's lightly modified Wobble script is used to make the Plaque Frames.
File comment: Expect this output from the preset.
File comment: Includes the preset file for creating this image and instructions on how-to create it.
Demo.zip [8.83 KiB]
Downloaded 65 times
Charles
PostPosted: Wed Apr 03, 2024 2:25 am  (#7)
As ever full of intriguing ideas Charles - looks like very creative stuff (technical term).
:kpix
cron
