It is currently Thu Nov 26, 2026 8:30 am
 Post subject: Apply Selection to Layer with LIVE PREVIEW
PostPosted: Wed Feb 07, 2024 1:29 am  (#1)
This plugin is a continuation of the changes to the plugin Grow-Shrink Live Preview:
viewtopic.php?f=9&t=20616
Displaying "only" the fill selection requires a few extra steps to apply it to the layer.
This version allows you to preview the live result for a layer.
Ver.2.0
Change:
- modification on a copy of the Top layer'
- remove selection fill (invert, color, opacity);
- change plugin name and name in menu (Now: Select ➤ Apply to Layer LP...);
- added operations for the top layer: scale, offsets.
Download:
https://www.gimpscripts.net/2024/02/app ... -live.html
 Post subject: Re: Apply Selection to Layer with LIVE PREVIEW
PostPosted: Wed Feb 07, 2024 5:54 am  (#2)
@MareroQ
When I click on the download button at https://www.gimpscripts.net/2024/02/app ... -live.html I get a 404 error.
Look forward to trying your latest version.
david.
PostPosted: Wed Feb 07, 2024 8:33 am  (#3)
I was just about to type "where's the download" before reading David's comment.
Please and thanks fix the download
PostPosted: Wed Feb 07, 2024 2:43 pm  (#4)
Thanks for reporting. Fixed and added a little more description.
PostPosted: Wed Feb 07, 2024 8:30 pm  (#5)
I'm making a GEGL based plugin of my own to mimic (grow, shrink, feather and distort). Stay tuned
Other then that your plugin is pretty cool I just wish it didn't break the undo ability. I enjoyed testing your plugin.
PostPosted: Thu Feb 08, 2024 9:25 am  (#6)
This plugin only works based on selection.
I am very curious how your Gegl plugin will work based on masks.
PostPosted: Sat Feb 10, 2024 4:54 am  (#7)
Small changes in ver. 2.1
- added opacity,
- if there is no selection, add a crop function on each side.
