It is currently Mon Aug 10, 2026 1:26 pm
 Post subject: GMIC -New Artistic Filter : "BW Steampunk Pencil"
PostPosted: Tue Jun 28, 2011 6:15 pm  (#1)
This filter perfectly emulate the effect of Steampunk Pencil. :yes
Here nobody can't proof me wrong since i just invented the concept of Steampunk Pencil :mrgreen:
Anyway this is the B&W Steampunk Pencil...a Colour Steampunk Pencil will follow soon
Gmic " Steampunk Pencil" by PhotoComiX, on Flickr
Maybe i should have called Steampunk Sponge because the effect is more close to a sponge then to a pencil, anyway since this filter is based on "pencil" i left the name
Controls
1 Size
2 Amplitude
Control Size and Amplitude of the pencil(exactly as for the built-in "pencil" filter , that is in the "Artistic" Menu of gimp)
3"Steam Pression"
control the spreading, the chose is between 4 different preset of the Kuwahara filter)
4 "Lubrification"
For lubrification is used a very slight amount of gaussian blur (from 0 to 1.8, default is less than 1, i suggest higher amount only on very large image
5 ) Quick contrast FX
Optionally you may call from here some preset to modify the contrast
the FIRST option...is skip and do nothing,
option 2 correspond to apply a Contrast mask
option 3 is the contrary of 2 the mask is used to Boost
option 4 apply a Fast Tone Map preset
option 5 use a personal preset of Local Normalization
option 6 use the default of Local Normalization
6 Add A Painter Touch
For a more "painted and smoot effect" :
it will enable the last 3 sliders allowing to apply "Anistropic Smoothing "
Possible Request (i mean request that i may satisfy painlessy )
1
kuwahara-STEAM PRESSION
You may have noticed that i didn't allow much control on kuwahara (steam pression),
this because i found that only few values give the effects i like (radius of 2 or 3 with 1 or 2 iterations)
BUT if for any reason you would like a broader range of values just let me know, i may do quickly
i may even replace the dropdown list with the original Kuwahara control (Size and iteration)
2 Fast Contrast FX
That basically call preset, if you have some other good preset , i may add it easily
have fun
The filter is already available by refreshing the filters (IF you have my source enabled )
 Post subject: Re: GMIC -New Artistic Filter : "BW Steampunk Pencil"
PostPosted: Tue Jun 28, 2011 6:21 pm  (#2)
Humm my orthographic corrector report " Pression" and "Lubrification" as mistakes ..ARE mistakes ?
If so what would be the correct words ?
PostPosted: Tue Jun 28, 2011 6:23 pm  (#3)
Sorry don't know your answer to your question, but I can't wait for the color version!
I'm back I think
PostPosted: Tue Jun 28, 2011 6:33 pm  (#4)
Hi PC probably just pressure (as in steam pressure) and lubrication (as is used for oiling and greasing of moving parts in an engine ) are the words you are looking for.
PostPosted: Tue Jun 28, 2011 6:35 pm  (#5)
Thank wbool !
PostPosted: Tue Jun 28, 2011 8:49 pm  (#6)
I like "Pression" and "Lubrification" better, lol
PostPosted: Tue Jun 28, 2011 9:25 pm  (#7)
well for a italian lubrication sound as a dirty word derived by "lubrico" (word that a old professor would use for " sexually dirty and/or pervers") :hehe
i forgot to add a before/after,
BEFORE
Beautiful old lady from Darap(Sikkim) village by Sukanto Debnath, on Flickr
AFTER
Beautiful old lady from Darap (B&W) by PhotoComiX, on Flickr
TIP
i want the effect be a little flou (usually i tend more to oversharpen) but if you want less fuzzy just work at bigger scale and than scale down
PostPosted: Tue Jun 28, 2011 11:41 pm  (#8)
Nice sig. I'm in a gold period myself.
PostPosted: Wed Jun 29, 2011 1:36 pm  (#9)
:bump I made a new version but i didn't delete the previous (they will not conflict )
The basic difference is that in the previous version i was trying to guide to what i consider the most reasonable setting,but that was also somehow limiting user option
On the contrary in the new i left you free to experiment what the best for you and the images you are editing :paint
here the new filter
Screenshot - 29_06_2011 , 20_14_13 by PhotoComiX, on Flickr
The new control "Steam iterations" correspond to kuwahara "iteration"
A quick tip
Apparently gmic has nothing equivalent to the automatic option of gimp level,but you use it as last step if the final result looks too bleach (or you may use curve, or one of the equivalent gmic filters)
Let me know what version you prefer ,temporary i will left both while waiting for comments and suggestions
PostPosted: Wed Jun 29, 2011 4:31 pm  (#10)
It's not showing up in mine. I have v1.4.9.3. I have refreshed several times.
PostPosted: Wed Jun 29, 2011 5:01 pm  (#11)
It shows in mine. Go figure....... I just refreshed and it was there. woo hoo........I will trade you for that wave script....
PostPosted: Wed Jun 29, 2011 6:06 pm  (#12)
cant get this to work either
PostPosted: Wed Jun 29, 2011 6:10 pm  (#13)
Do you have PhotoComix activated? then refresh Akky
PostPosted: Wed Jun 29, 2011 6:20 pm  (#14)
Solved ?
PostPosted: Wed Jun 29, 2011 6:37 pm  (#15)
no not solved...and yes I do have PhotoComix activated but when I refresh I get an error message...I've tried each time I open gimp since this was announced
PostPosted: Wed Jun 29, 2011 6:49 pm  (#16)
@ Oregonian
you have a too old version of gmic but that will explain a error message not the script not showing up
Anyway David did some changes in 1.4.9.4 to the Kuwahara filter that my script use, no relevant changes but will cause a error
Again that don't explain why the filter don't show up, but i suspect updating gmic may anyway solve
PostPosted: Wed Jun 29, 2011 6:54 pm  (#17)
@Akky
what version of gmic you have ?
and do you use Mac , correct ?
Check the addional filter list, if you see "Gentlemanbeggar" source uncheck it and try to refresh again
A little error was creating problems, it is solved now by a new gmic version that should be already available
(if not now tomorrow )
PostPosted: Wed Jun 29, 2011 6:58 pm  (#18)
I'm using the 1.5.0.0 version for Snow Leopard and yes I use mac...but I just found there is an updated version posted 17 hours ago so am about to try that...
just give me a few to get it installed
PostPosted: Wed Jun 29, 2011 6:59 pm  (#19)
ok still got the same message!! and its not in the new list either
PostPosted: Wed Jun 29, 2011 7:03 pm  (#20)
ok so now GIMP is crashing on me after several attempts...cant get it to open...just crash after crash
