It is currently Thu Nov 26, 2026 7:37 am
 Post subject: Path Scale Copy Rotate Shift Walk Version 0.06 Tabbed for Gimp 2.10
PostPosted: Thu Feb 08, 2024 9:51 am  (#1)
Online
This version revives version 0.04 from GimpLearn that was never made available on GimpChat and uses the tabbed dialog interface devised by Arakne.
It is basically a python version of the script by Brian Hahn's first published in 2011 here on GimpChat but with a number of extras.
Download and extract the plug-in and place it in your user plug-ins folder.
Copy_Rotate_Shift_Scale_Walk_v006_Tabbed.zip [14.04 KiB]
Downloaded 100 times
The menu shortcut is:
Filters>>Path Scale Copy Rotate Shift Walk v0.06 Tabbed…
A pdf version of this guide:
The plug-in takes a simple path like this one consisting of 4 points…
...and repeatedly transforms it to create a pattern like the outer ring in the image below. The other rings in this image were created by moving the lower un-joined point closer to the three joined points above and running the filter again.
The idea is to stroke a user path, transform the path by a small amount and stroke it again multiple times. Simple but strangely compelling to watch!
Create a new image, choose your colours and/or gradient.
Select the path tool and create a path (see below): Rename the path ‘walk’.
Create another simple path – this is the path that will be transformed along the walk path. The name is not important.
Optionally, you can add a background colour and add a new layer.
The plug-in will stroke the path to the currently active layer of your image.
Time to play, using the basic options from Tab 1 of the filter
Call up the filter dialog:
Choose a colour option to work with - I chose ‘Shade colours (FG to BG)’ - and click ‘OK’.
The default settings for the plug-in strokes the user path 20 times and rotates the path by 5 degrees for each new stroke.
Undo the filter output (or delete the contents of the layer) and call up the filter again.
Change the ‘Force rotation amount’ option to ‘Force one full revolution’ and click on ‘OK’.
Increase the ‘Stroke x offset’ option value to 1 and click on ‘OK’. As expected each new stroke is now rotated and also shifted by one pixel.
Increase the ‘Stroke y offset’ option value to 1 and click on ‘OK’. As expected each new stroke is now rotated and also moved by one pixel in both the x and y directions.
Have a play with the basic options and see what works well for your own paths. If you want to use wider paths I would also increase the angle of rotation to avoid the lines all melding into a single blob of colour.
Walking the paths (Tab1)
Make some new paths and try out some other colours or gradients.
The default option uses one repeat so that you can assess the path generated with the paths. It will position the pattern at the mid-point of the walk path.
Once you are happy with the basic pattern you can add more repeats.
Walking and Scaling the Paths (Tab 2)
The original user path with a dead-point generated this pattern…
For interest’s sake, without the dead-point the pattern would have been:
And then using a snaking walk path, ten repeats and a ‘Scale each pattern amount’ of just 0.2...
There is a ‘Scale compensation positioning’ option to try that gives a slightly different outcome...
Modifier Options (Tab 2)
I added these options on the principle that you can never have enough fun!
You can alter the stroke modifier values for x position, y position and the angle of rotation (small amounts to begin with warning) and select which of these to apply to a path from the ‘Pattern modifier options’.
My user path to stroke along a circular ‘walk’ path using a metallic gradient.
Outcome without modifiers:
Using the default modifier values and the Ripple style:
Using the default modifier values and the Ascend Jump style:
Using the default modifier values and the Descend Jump style:
Using the default modifier values and the Zigzag Large style:
Using the default modifier values and the Zigzag Small style:
Modifier Options Step Size (Tab 2)
Altering the step size can also influence the stroke pattern generated. The default value is set to 10 (before the modifier pattern begins again).
Example user path:
Using a step size of 20 and Ripple style.
Ripple and Ascend Jump styles:
Ripple and Descend Jump styles:
Ripple and Zigzag Large styles:
And finally you can always make a copy of the generated paths to use with other filters or with other programmes that can import SVG paths using ‘Merge generated paths at each repeat’ from the ‘Generated paths option’.
Edit to add an example path stroked with a brush...
Using a larger image to make it easier to use a bigger path size - which I later scaled down.
Have fun!
 Post subject: Re: Path Scale Copy Rotate Shift Walk Version 0.06 Tabbed for Gimp 2.1
PostPosted: Thu Feb 08, 2024 10:34 am  (#2)
Really interesting results. :)
PostPosted: Fri Feb 09, 2024 6:52 am  (#3)
Online
Thanks Lyle...
...we like a bit of play.
:tyspin
There was an old thread for plays in Gimp Art ...
Plays in Gimp Art
PostPosted: Fri Feb 09, 2024 7:58 am  (#4)
Too cool, :jumpclap :jumpclap I'll have to have a closer look at this in a couple days.
PostPosted: Sat Feb 10, 2024 5:28 am  (#5)
Online
Look forward to that Sallyanne. :bigthup
(Just added an example image to illustrate a path stroked with a brush to the end of the guide.)
PostPosted: Sun Feb 11, 2024 8:58 am  (#6)
Nice one Skinnyhouse, and thank you for that nostalgic link. I had forgotten all about that thread!
PostPosted: Sun Feb 11, 2024 4:39 pm  (#7)
Sadly it is not showing up in my menu or in the PY console. Some other python plugins work fine and I have had to fight to get the string art plugin working, which it finally is but I am having problems with this. I am using the latest Gimp in the Debian repositories with the gimp-python2-fuse-overlay-launcher-mx-linux21-1 appimage.
PostPosted: Sun Feb 11, 2024 11:30 pm  (#8)
Wowww, Skinnyhouse, that's a very nice plugin, your examples are outstanding :clap and motivating me :hehe
I'm studying your manual right now, then I'm gonna play :yes
Thank you Skinnyhouse :tyspin
Patrice
PostPosted: Mon Feb 12, 2024 2:36 am  (#9)
Online
Thanks Pix but kudos to Brian Hahn for the original script. :bigthup
Erisian: On Windows here - can look at posting the version without tabs if you think that might be the problem.
PostPosted: Mon Feb 12, 2024 7:24 am  (#10)
Thank you but it didn't solve it. I didn't expect it to because there are other py plugins that aren't showing and I can't understand why. I have two of Diego's and I have string art but none of the others seem to show.
PostPosted: Mon Feb 12, 2024 9:06 pm  (#11)
You might have forgotten to give the permission to execute, right click on the plugin >> Properties >> Tab permission >> Allow executing file as program. (SCM and GEGL don't need that, only python)
it happened to me when I installed this plugin and it took me few minutes to solve the "What's going on??" in my mind..
The past few months I did installed few plugins from Ofnuts, thus I did forgot this simple step after downloading :hehe
Also, if your python plugins are installed in their own directories, the directory should have the very same name than the plugin inside (without the extension), and unlike M$ Windows, on Linux it's very case sensitive about naming ;)
Patrice
PostPosted: Tue Feb 13, 2024 6:17 am  (#12)
All have permissions and all are in my config-Gimp-2.10-plugins folder, but no luck.
PostPosted: Tue Feb 13, 2024 6:37 am  (#13)
Quite strange that's not working, a question, though: Did you install the fuse-overlays for that appimage?
In Terminal:
sudo apt install fuse-overlayfs
Then re-start GIMP by double clicking that appimage
Patrice
PostPosted: Tue Feb 13, 2024 12:45 pm  (#14)
In Terminal:
Yep. Ran it again to make sure and got the following:
fuse-overlayfs is already the newest version (1.4.0-1)
