It is currently Thu Nov 26, 2026 6:25 am
 Post subject: GEGL plugin that outlines with a bevel and more
PostPosted: Fri Feb 23, 2024 11:38 am  (#1)
I made a new GEGL plugin targeting Gimp 2.99.19 non-destructive build. Specifically so users can combine an outline and bevel together in one 'layer effect' instead of putting it on a layer above. This plugin still requires the use of the 'normal' blend option if you don't want it on the layer above. I did this for flexibility so people can blend it with other blend modes if they want.
https://github.com/LinuxBeaver/Outline- ... n/releases
LOCATION TO PUT BINARIES
Windows
Linux
then restart Gimp and go to GEGL operation and look for Outline Deluxe, in 2.99.16+ it will be in filters>text styling
