It is currently Thu Nov 26, 2026 4:16 am
 Post subject: Gimp 2.10.38 & 2.99.19 may break all my old GEGL plugins - update here
PostPosted: Wed Mar 13, 2024 2:03 am  (#1)
Gimp's team may block all GEGL plugins that use the namespace gegl in the next release. This is the fix before it happens. Other then that over 30 plugins of mine updated so they no longer clip when out of bounds when doing live text editing.
Download 60 something plugins here
windows_binaries_all_gegl_plugins.zip [2.75 MiB]
Downloaded 199 times
linux_binaries_all_gegl_plugins.zip [646.97 KiB]
Downloaded 87 times
code_of_all_GEGL_plugins.zip [810.67 KiB]
Downloaded 77 times
Location to put binaries
Windows
Linux
or get binaries individually on Github
https://github.com/LinuxBeaver?tab=repositories
OLD THINGS BEFORE THE LB: NAME SPACE WILL BREAK SOON
 Post subject: Re: Gimp 2.10.38 & 2.99.19 may break all my old GEGL plugins - update
PostPosted: Fri Mar 15, 2024 12:13 am  (#2)
Two days ago GEGL 0.4.49 master branch had an update that broke the gegl:bevel plugin of mine before August 2023 by using the name space gegl:bevel for the plugin of mine that was officially accpeted. But all old gegl: namespace plugins still work. (for now).
However because classic (may 2022-august 2023) gegl:bevel broke it means GEGL Effects from the same time will not have a proper bevel effect. So make sure to update with the links above.
