It is currently Thu Nov 26, 2026 2:21 am
 Post subject: Parchment texture
PostPosted: Fri Apr 05, 2024 1:00 pm  (#1)
I came across this on this site. it works in gimp 2.8 but no longer in 2.10.36. Can this still be repaired?
viewtopic.php?f=9&t=2149
parchmenttexturebynaeddyr_0.scm [17.84 KiB]
Downloaded 189 times
 Post subject: Re: Parchment texture
PostPosted: Tue Apr 09, 2024 7:50 am  (#2)
The script does not work well for all possible settings for Gimp-2.8 (uncheck the "Badger original image" option and you will get an error).
It works very slowly with a strange (for me) end result.
The good news is that the download is >15.
The bad news is that the downloaders will not release any patches for Gimp 2.10.
Tested only for Win with parameters (min, max, default).
Other errors possible.
parchmenttexturebynaeddyr_0.zip [5.3 KiB]
Downloaded 180 times
PostPosted: Tue Apr 09, 2024 11:10 am  (#3)
It works!
