It is currently Thu Nov 26, 2026 1:46 am
 Post subject: GEGL ROYAL TEXT plugin (download provided)
PostPosted: Sun Apr 14, 2024 11:30 am  (#1)
--UPDATE PLUGIN IS COMPLETE --
Download here
https://github.com/LinuxBeaver/Royal_Te ... n/releases
Hello, I am developing a new plugin called GEGL Royal Text
I'll keep everyone updated on its development.
In a alternative form
It does not include a dropshadow and will be extremely resource intensive.
 Post subject: Re: GEGL ROYAL TEXT plugin (coming soon)
PostPosted: Sun Apr 14, 2024 11:36 am  (#2)
You can test a live preview of this plugin now by downloading these plugins of mine and entering this code into Gimp's GEGL GRAPH filter
Install these three plugins if you don't already have them
https://github.com/LinuxBeaver/gimp-met ... L/releases
https://github.com/LinuxBeaver/GEGL-Eff ... L/releases
https://github.com/LinuxBeaver/GEGL_Thr ... n/releases
then put this code in GEGL Graph
color-overlay value=#f95dff
gaussian-blur std-dev-x=2 std-dev-y=1
id=1 screen  aux=[ ref=1  emboss  type=bumpmap azimuth=70  elevation=23 opacity value=4.5  ]
median-blur radius=0 abyss-policy=none
id=2
id=3 over aux=[ ref=3 lb:glassovertext ]
dst-over aux=[  ref=2  median-blur radius=10 alpha-percentile=100 abyss-policy=none ]
hue-chroma hue=-0
dst-over aux=[  ref=2  median-blur radius=20 alpha-percentile=100 abyss-policy=none
hue-chroma hue=129 lightness=-3 lb:metallic guichange=colormetal color=#ffe600 solar1=33 ]
id=3 gimp:layer-mode layer-mode=luminance blend-space=rgb-perceptual opacity=0.5 aux=[ ref=3 edge amount=3 ]
bloom strength=20
lb:threshold-alpha
levels in-low=0.11
PostPosted: Sun Apr 14, 2024 4:06 pm  (#3)
Unlike mosaic tiles which hasn't even started this filter has a working binary and code that IS INCOMPLETE. I got the whole thing ready in a few hours
Linux Only beta download here
Location to put binaries
Linux
Royal's source code
/* This file is an image processing operation for GEGL
* GEGL is free software; you can redistribute it and/or
* modify it under the terms of the GNU Lesser General Public
* License as published by the Free Software Foundation; either
* version 3 of the License, or (at your option) any later version.
* GEGL is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
* Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public
* License along with GEGL; if not, see <https://www.gnu.org/licenses/>.
* Copyright 2006 Øyvind Kolås <[email protected]>
* 2024 Beaver, Royal Text
Syntax to recreate plugin here
color-overlay value=#f95dff gaussian-blur std-dev-x=3 std-dev-y=1
id=1 screen  aux=[ ref=1  emboss  type=bumpmap azimuth=70  elevation=53 depth=23 opacity value=4.5  ]
id=2
hue-chroma hue=-0
hue-chroma hue=49 lightness=-3 lb:metallic guichange=colormetal color=#ffe600 solar1=6.2 ]
id=4 gimp:layer-mode layer-mode=luminance  opacity=0.5 aux=[ ref=4 edge amount=3.4 ]
bloom strength=20
lb:threshold-alpha
levels in-low=0.11
--end of syntax
#include "config.h"
#include <glib/gi18n-lib.h>
#ifdef GEGL_PROPERTIES
property_int (hue, _("Rotate Bevel's color"), 0)
    description (_("The bevel's color can be controlled by a limited hue rotation"))
    value_range (-45, 45)
    ui_meta ("unit", "degree")
property_double (azimuth, _("Azimuth of everything"), 67.0)
    description (_("The bevel and bevel outline's light angle (degrees)"))
    value_range (30, 90)
property_double (elevation, _("Elevation of everything"), 40.0)
    description (_("The bevel and bevel outline's elevation angle (degrees)"))
    value_range (7, 90)
property_int (depth, _("Depth/detail of everything"), 24)
    description (_("Brings out depth and or detail of both the bevel and bevel outline"))
    value_range (1, 100)
property_double (glass_azimuth, _("Glass light rotation"), 30.0)
    description (_("Glass light rotation (azimuith)"))
    value_range (0, 360)
    ui_meta ("direction", "ccw")
  ui_steps      (0.5, 0.50)
property_int (outline_hue, _("Rotate bevel outline color"), 0)
    description (_("The bevel outline's color can be controlled by a limited hue rotation"))
property_double (enhance, _("Shine enhance"), 3.0)
    description (_("Edge detect on luma to enhance the shine"))
    value_range (0.0, 7.0)
property_int (bloom, _("Bloom light"), 20)
    description (_("Bloom light strength"))
    value_range (10.0, 40.0)
property_int (outline_size, _("Outline Size"), 24)
    description (_("Size of the bevel outline"))
    value_range (10, 40)
property_double (tail, _("Extrusion length"), 0.0)
    description (_("Length of the extrusion. At 0.0 the extrusion is not noticable"))
    value_range (0.0, 0.020)
    ui_range    (0.0, 0.020)
    ui_gamma    (2.0)
property_double (x, _("Horizontal Extrusion control"), 0.0)
    value_range (-0.5, 0.5)
    ui_range    (-0.5, 0.5)
    description(_("Horizontal movability of the extrusion"))
property_double (y, _("Vertical Extrusion control"), 0.0)
    description(_("Vertical movability of the extrusion"))
#else
#define GEGL_OP_META
#define GEGL_OP_NAME     royal
#define GEGL_OP_C_SOURCE royal.c
#include "gegl-op.h"
static void attach (GeglOperation *operation)
  GeglNode *gegl = operation->node;
  GeglColor *basecolor = gegl_color_new ("#f95dff");
    GeglNode *input    = gegl_node_get_input_proxy (gegl, "input");
    GeglNode *output   = gegl_node_get_output_proxy (gegl, "output");
    GeglNode *hcolor    = gegl_node_new_child (gegl,
                                  "operation", "gegl:color-overlay", "value", basecolor,
                                  NULL);
    GeglNode *unequalblur    = gegl_node_new_child (gegl,
                                  "operation", "gegl:gaussian-blur", "std-dev-x", 3.0, "std-dev-y", 1.0,
                                  NULL);
    GeglNode *emboss    = gegl_node_new_child (gegl,
                                  "operation", "gegl:emboss", "type", 1,
                                  NULL);
    GeglNode *metallic    = gegl_node_new_child (gegl,
                                  "operation", "lb:metallic", "guichange", 1, "solar1", 6.0,
                                  NULL);
    GeglNode *idref1    = gegl_node_new_child (gegl,
                                  "operation", "gegl:nop",
                                  NULL);
    GeglNode *idref2    = gegl_node_new_child (gegl,
                                  NULL);
    GeglNode *idref3    = gegl_node_new_child (gegl,
                                  NULL);
    GeglNode *idref4    = gegl_node_new_child (gegl,
                                  NULL);
    GeglNode *behind1    = gegl_node_new_child (gegl,
                                  "operation", "gegl:dst-over",
                                  NULL);
    GeglNode *behind2    = gegl_node_new_child (gegl,
                                  NULL);
    GeglNode *screen    = gegl_node_new_child (gegl,
                                  "operation", "gegl:screen",
                                  NULL);
    GeglNode *bloom    = gegl_node_new_child (gegl,
                                  "operation", "gegl:bloom", "strength", 20.0,
                                  NULL);
    GeglNode *lightweak    = gegl_node_new_child (gegl,
                                  "operation", "gegl:levels", "in-low", 0.11,
                                  NULL);
    GeglNode *ta    = gegl_node_new_child (gegl,
                                  "operation", "lb:threshold-alpha",
                                  NULL);
    GeglNode *normal   = gegl_node_new_child (gegl,
                                  "operation", "gegl:over",
                                  NULL);
    GeglNode *edge   = gegl_node_new_child (gegl,
                                  "operation", "gegl:edge", "amount", 3.0,
                                  NULL);
    GeglNode *glassoverlay    = gegl_node_new_child (gegl,
                                  "operation", "lb:glassovertext",
                                  NULL);
    GeglNode *opacity    = gegl_node_new_child (gegl,
                                  "operation", "gegl:opacity", "value", 4.5,
                                  NULL);
    GeglNode *fix1    = gegl_node_new_child (gegl,
                                  "operation", "gegl:median-blur", "radius", 0, "abyss-policy", 0,
                                  NULL);
    GeglNode *fix2    = gegl_node_new_child (gegl,
                                  NULL);
    GeglNode *grow1    = gegl_node_new_child (gegl,
                                  "operation", "gegl:median-blur", "radius", 10, "alpha-percentile", 100.0, "abyss-policy", 0,
                                  NULL);
    GeglNode *grow2    = gegl_node_new_child (gegl,
                                  "operation", "gegl:median-blur", "radius", 20, "alpha-percentile", 100.0, "abyss-policy", 0,
                                  NULL);
    GeglNode *luma    = gegl_node_new_child (gegl,
                                  "operation", "gimp:layer-mode", "layer-mode", 56, "opacity", 0.5,
                                  NULL);
    GeglNode *extrusion   = gegl_node_new_child (gegl,
                                  "operation", "lb:extrusion",
                                  NULL);
    GeglNode *hue1   = gegl_node_new_child (gegl,
                                  "operation", "gegl:hue-chroma",
                                  NULL);
    GeglNode *hue2   = gegl_node_new_child (gegl,
                                  NULL);
  gegl_node_link_many (input, hcolor, unequalblur, idref1, screen, fix1, idref2, fix2, idref3, normal, behind1, hue1, behind2, idref4, luma, bloom, ta, lightweak, extrusion, output, NULL);
/*Screen with emboss is here*/
  gegl_node_connect (screen, "aux", opacity, "output");
  gegl_node_link_many (idref1, emboss, opacity, NULL);
/*Glass Overlay on normal blend mode is here*/
  gegl_node_link_many (idref3, glassoverlay, NULL);
  gegl_node_connect (normal, "aux", glassoverlay, "output");
/*The behind blend mode idref2 with median blur is here*/
  gegl_node_connect (behind1, "aux", grow1, "output");
  gegl_node_connect (behind2, "aux", hue2, "output");
  gegl_node_link_many (idref2, grow1,  NULL);
  gegl_node_link_many (idref2, grow2, metallic, hue2, NULL);
/*Luminance with edge detect*/
  gegl_node_connect (luma, "aux", edge, "output");
  gegl_node_link_many (idref4, edge, NULL);
  gegl_operation_meta_redirect (operation, "bloom",  bloom, "strength");
  gegl_operation_meta_redirect (operation, "enhance",  edge, "amount");
  gegl_operation_meta_redirect (operation, "outline_size",  grow2, "radius");
  gegl_operation_meta_redirect (operation, "glass_azimuth",  glassoverlay, "azimuth");
  gegl_operation_meta_redirect (operation, "azimuth",  emboss, "azimuth");
  gegl_operation_meta_redirect (operation, "depth",  emboss, "depth");
  gegl_operation_meta_redirect (operation, "elevation",  emboss, "elevation");
  gegl_operation_meta_redirect (operation, "tail",  extrusion, "factor");
  gegl_operation_meta_redirect (operation, "x",  extrusion, "center_x");
  gegl_operation_meta_redirect (operation, "y",  extrusion, "center_y");
  gegl_operation_meta_redirect (operation, "hue",  hue1, "hue");
  gegl_operation_meta_redirect (operation, "outline_hue",  hue2, "hue");
static void
gegl_op_class_init (GeglOpClass *klass)
  GeglOperationClass *operation_class;
  operation_class = GEGL_OPERATION_CLASS (klass);
  operation_class->attach = attach;
  gegl_operation_class_set_keys (operation_class,
    "name",        "lb:royal",
    "title",       _("Royal Text"),
    "reference-hash", "JillEscherAutismRedPill",
    "description", _("Text that appears as a fancy glossed stone which has a precious metal extruding border "),
    "gimp:menu-path", "<Image>/Filters/Text Styling",
    "gimp:menu-label", _("Royal Text..."),
    NULL);
#endif
Description:
Another Preview
PostPosted: Sun Apr 14, 2024 4:39 pm  (#4)
The filter should release tonight. In the mean time here is another preview
PostPosted: Sun Apr 14, 2024 6:23 pm  (#5)
The plugin is assumed complete and can be downloaded here. Below are locations to put the binaries
Windows
Linux
 Post subject: Re: GEGL ROYAL TEXT plugin (download provided)
PostPosted: Sun Apr 14, 2024 9:24 pm  (#6)
source_code_of_royal_text.zip [26.75 KiB]
Downloaded 66 times
royal_linux_binaries.zip [49.53 KiB]
Downloaded 62 times
royal_windows_binaries.zip [208.49 KiB]
Downloaded 79 times
Windows
Linux
PostPosted: Sun Apr 14, 2024 9:31 pm  (#7)
Nice!
Was it made for both GIMP 2.10 and 2.99?
I ask, because it did brake the "Chrome" filter on my GIMP 2.10
Patrice
PostPosted: Sun Apr 14, 2024 9:42 pm  (#8)
PixLab wrote:
Nice!
yes... the reason mosaic tiles won't is because it will use Gimp 2.99.19's native bevel
PostPosted: Sun Apr 14, 2024 9:48 pm  (#9)
PixLab wrote:
Nice!
What did chrome say when you launched it? I hope not "FATAL ERROR"
If it is "fatal error" then I strongly suggest you remove all plugins of mine and download this along with Royal
https://github.com/LinuxBeaver/LinuxBea ... lugins.zip
If not just reinstall chrome text
https://github.com/LinuxBeaver/GEGL---C ... r/releases
If you are using an old version of chrome text before mid 2023 this is explainable.
PostPosted: Sun Apr 14, 2024 10:17 pm  (#10)
No fatal error :bigthup
It was just not shiny anymore
It's all for Microsoft Windows :mrgreen: , do you have the same compilation for Linux?
This download did it, It's working again after install :bigthup
:tyspin contrast_
Patrice
PostPosted: Mon Apr 15, 2024 10:03 am  (#11)
The binary download for Royal forgot two binaries for extrusion which means the extrusion sliders in it won't work. The update now fixes that.
If you already have these plugins you may notice extrusion works
This is the error you get for missing binaries
GEGL WARNING
Failed to set operation type lb:bevel, using a passthrough op instead
GEGL WARNING
Failed to set operation type lb:edgesmooth, using a passthrough op instead
PostPosted: Mon Apr 15, 2024 9:12 pm  (#12)
And Chrome works better as well (or is it my mind?)
In all case :tyspin
Patrice
