I just found an alternative method to make an inner glow and inverted inner glow
Here is what is going on
id=1 is the bookmark of the original text that will be used as a mask for a blend mode later
Gaussian Blur is the blur radius of the inner glow
Translate is the movability X and Y of inner glow. The same thing as the X and Y that moves drop shadow.
Color Overlay is the color of the Inner Glow
Opacity is the hyper opacity of the inner glow that goes above 100%
src-out/src-in are GEGL exclusive blend modes that erase content outside a input mask which in this case is the text. So imagine a text mask knocking out the red gaussian blur puff outside. Src-out does exactly that, and src-in does that but with inverted transparency. ref=1 is the bookmark of the original text being called
Inner GlowAttachment:
id=1
gaussian-blur std-dev-x=10 std-dev-y=10 abyss-policy=none clip-extent=false
translate x=0 y=0
src-out aux=[ ref=1 ]
color-overlay value=#ff032f
opacity value=1.3
Inverted Inner GlowAttachment:
id=1
translate x=0 y=0
src-in aux=[ ref=1 ]
opacity value=1.3
I am discussing technical ways to revamp and perfect my existing plugins and others have yet to begin making a GEGL plugin
