It is currently Wed Nov 25, 2026 5:02 pm
 Post subject: 2.99.19 GEGL plugin update here! - 39 plugins of mine crash GIMP 3
PostPosted: Fri May 24, 2024 12:49 am  (#1)
This is an emergency update that only applies for GIMP 2.99.18-19/GIMP 3. 2.10 users can ignore this and update whenever they feel like. 39 plugins of mine crashed GIMP 2.99.19 on close, this happens once and a while. The update I am providing here with Windows and Linux binaries fixes it.
39 plugins updated but 41 binaries exist because GEGL Effects as a whole had to be included in the update, but the source code only contains the plugins that updated.
It would actually be in my best interest if 2.10 users updated anyway as you'll get the latest version of 39 plugins of mine and won't have to update later when GIMP 3 releases.
 Post subject: Re: 2.99.19 GEGL plugin update here! - 39 plugins of mine crash GIMP 3
PostPosted: Fri Jun 21, 2024 3:23 pm  (#2)
39 plugins updated to prevent a crash on close in GIMP 2.99.19
Emergency update - Overwrite all these GEGL Plugins with the latest version or GIMP 2.99.19/3 will crash when it is being closed.
Contains Windows binaries, Linux Binaries and Source code
june_19th2024__gegl_plugin_fix_crash_on_close.zip [2.15 MiB]
Downloaded 83 times
Location to put binaries
Windows
Linux
then restart GIMP and go to GEGL operation to find the new plugins or if on 2.99.19 look in the menu
