It is currently Wed Nov 25, 2026 12:37 pm
 Post subject: GEGL vector layer plugin
PostPosted: Sun Jun 23, 2024 1:44 am  (#1)
Draw shapes in GIMP using GEGL
GIMP can draw non-destructive circles, ovals, squares, rectangles and diamonds and dividers using this plugin and in 2.99.19 it is non-destructive.
Download for Windows and Linux here
https://github.com/LinuxBeaver/Vector_L ... e/releases
LOCATION TO PUT BINARES
Windows
Linux
Then restart GIMP and go to GEGL Operations and search for "draw shapes" or if you use GIMP 2.99.16+ you will see it in filters>render>run
More previews of the plugin
Two limitations exist
1. It will render an oval on non 16:9 canvases. Though one can manually fix this using shape squeeze slider. This seems impossible to fix but I will investigate soon. The reason this impossible to fix is because native GIMP filter vignette has the same problem
2.It replaces everything on canvas because it uses the replace blend mode. Once I get around to it I will instruct the plugin to use the normal blend mode instead.
Remember if you use a fill or outline only with GEGL Effects or other plugins you can do all sorts of fancy shape styles
 Post subject: Re: GEGL vector layer plugin (destructive in GIMP 2.10)
PostPosted: Sun Jun 23, 2024 1:49 am  (#2)
Use it with other plugins of mine in GIMP 2.99.19 for all sorts of fun
https://github.com/LinuxBeaver/Gimp-Tex ... n/releases
https://github.com/LinuxBeaver/GEGL-Eff ... L/releases
Video of this plugins use is here
https://www.reddit.com/r/GIMP/comments/ ... 919_makes/
