It is currently Wed Nov 25, 2026 11:06 am
 Post subject: Custom Font Selection Highlight v0.1 for Gimp 2.10
PostPosted: Sat Jul 13, 2024 7:03 am  (#1)
This is a simple plug-in to create new highlights or to enhance existing highlights for custom fonts. It works by selecting the outline of each character and shrinking this selection by the required amount and filling this with colour.
A PDF copy of this guide:
Custom Font Selection Highlight Guide.pdf [1.14 MiB]
Downloaded 107 times
Download, unzip and install in your user Plug-ins folder.
Custom_Font_Selection_Highlight_v01.zip [5.07 KiB]
Downloaded 73 times
The dialog showing the default settings:
Open up the custom font that you want to add a highlight to and call up the plug-in dialog from the menu location:
Filters>>Custom Fonts>>Decorating Tools>>Custom Font Selection Highlight v 0.1…
Since there is no preview option it is probably more useful to work with a single character image: Copy a character ((Ctrl + C)) and paste it as a new image (Ctrl + Shift + V).
The options are mostly self-explanatory.
Highlight Size:
Enter the value for the highlight you want to create and click on ‘OK’.
New Mode to use with highlight:
Select the mode you want to apply the highlight with.
The blur and opacity options can also be used to good effect here.
X and Y offset options:
These options allow you to adjust the position of the highlight over the character and to add overlapping highlights.
Potential speed problems
When working with a full set of wide custom font characters it can take a while to add highlights so I have added a step option that can be used to speed things up.
Unexpected size of highlights
This can occur with some of the diagonal characters in thinner custom fonts as shown in the characters in the example image below:
The highlight on the letter ‘W’ appears much larger than on other characters.
The solution is to add any characters affected to the text box provided and to provide a new value for the ‘Alternative highlight size’. The plug-in can then be used on another version of the original custom font if you feel the results are too obvious to live with.
The alternative size value of 2.0 was used to create the next set of characters. Note the insertion of the ‘W’ in the ‘Characters to add a different size of highlight’ text box option.
An example
I had used Custom Font Highlights to add an emboss and highlight to this custom font but I wanted something with a little more impact using over-lapping highlights.
Step 1:
Add the first highlight using Grain merge mode and X and Y offsets of -8:
Step 2:
Add a second highlight (I used my background colour with grain merge mode) with X and Y offsets of 8.
Step 3:
I reduced the highlight size to 20% and used white foreground in linear light mode and set the X and Y offsets to zero.
Now I had the pop that I wanted with my highlight effect; job done!
Have fun...
 Post subject: Re: Custom Font Selection Highlight v0.1 for Gimp 2.10
PostPosted: Sat Jul 13, 2024 7:32 am  (#2)
:wow
Thanks so much Skinnyhouse :clap super cool plugin and tuto, :coolthup
:yr so much!!
Patrice
PostPosted: Sat Jul 13, 2024 8:19 am  (#3)
:tyspin Patrice
Practise makes perfect as they say!
