It is currently Wed Nov 25, 2026 9:36 am
 Post subject: PGEI.FREE
PostPosted: Wed Aug 07, 2024 5:23 am  (#1)
I want to install this, but am unsure if it is safe.
 Post subject: Re: PGEI.FREE
PostPosted: Wed Aug 07, 2024 5:46 am  (#2)
I believe i have heard of this from Davies Media Design. (On YouTube)
Personally i believe your better off sticking with normal Gimp 2.10.38 and if you want Gimp to act more like PhotoShop you can change the keyboard shortcuts and dock everything to look and feel like Photoshop.
I don't believe Gimp Photoshop is much different than Gimp itself other than more brush dynamics and mypaint brushes (which are already part of Gimp now).
I wouldn't trust anything not distributed by a reputable source.
PostPosted: Wed Aug 07, 2024 9:36 am  (#3)
So out of 60 or 70 anti-virus listed in that website which did "test" that application, there one > Jiangmin, an unknown Chinese "anti-virus", which tells you that it is infected, but the 60 or 70 other ones, a lot more well known and with a better reputation (arguably), are telling you that's OK, and you won't trust them, the more well known anti-virus, but instead trust Jiangmin, which is something you never heard about and the only one who has (pseudo) detected something?
I mean 60-70 against 1, and that 1 nobody heard about it... :puzzled :puzzled
For me it would be a very simple decision. Now it's your computer and nobody can take that decision for you.
Patrice
PostPosted: Wed Aug 07, 2024 10:28 am  (#4)
Thanks for responding: Rod I'm not going to install it anyway. Pixlab... indeed never heard of it either.(Jiaminn) But that's why I asked.
